[geos-commits] r2472 - in trunk/source: headers/geos/index/chain
index/chain
svn_geos at osgeo.org
Wed May 6 10:55:06 EDT 2009
Author: strk
Date: 2009-05-06 10:55:06 -0400 (Wed, 06 May 2009)
New Revision: 2472
trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h
trunk/source/index/chain/MonotoneChainBuilder.cpp
Port to 1.9, fixing an out of boundary access in findEdgeEnd
Modified: trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h
--- trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h 2009-05-06 14:42:12 UTC (rev 2471)
+++ trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h 2009-05-06 14:55:06 UTC (rev 2472)
@@ -13,7 +13,7 @@
- * Last port: index/chain/MonotoneChainBuilder.java rev 1.8
+ * Last port: index/chain/MonotoneChainBuilder.java rev 1.9
Modified: trunk/source/index/chain/MonotoneChainBuilder.cpp
--- trunk/source/index/chain/MonotoneChainBuilder.cpp 2009-05-06 14:42:12 UTC (rev 2471)
+++ trunk/source/index/chain/MonotoneChainBuilder.cpp 2009-05-06 14:55:06 UTC (rev 2472)
@@ -13,7 +13,7 @@
@@ -93,38 +93,47 @@
- * @return the index of the last point in the monotone chain starting
- * at <code>start</code>.
+/* public static */
int
MonotoneChainBuilder::findChainEnd(const CoordinateSequence *pts, int start)
- std::size_t npts = pts->getSize();
+ std::size_t safeStart = start;
- // skip any zero-length segments at start of sequence
- while ( pts->getAt( start).equals2D( pts->getAt( start + 1) ) )
- if ( ++start >= ( npts - 1 ) )
- // bail if there are no non-zero-length segments
- return npts - 1;
- // determine quadrant for chain
- int chainQuad=Quadrant::quadrant(pts->getAt(start),pts->getAt(start + 1));
- std::size_t last=start+1;
+ std::size_t npts = pts->getSize();
+ // skip any zero-length segments at the start of the sequence
+ // (since they cannot be used to establish a quadrant)
+ while ( safeStart < npts - 1
+ && pts->getAt(safeStart).equals2D(pts->getAt(safeStart+1)) )
+ ++safeStart;
+ // check if there are NO non-zero-length segments
+ if (safeStart >= npts - 1) {
+ return static_cast<int>(npts - 1);
+ // determine overall quadrant for chain
+ int chainQuad = Quadrant::quadrant(pts->getAt(safeStart),
+ pts->getAt(safeStart + 1));
+ std::size_t last = start + 1;
while (last < npts)
// skip a zero-length segnments
- if (! pts->getAt( last - 1).equals2D( pts->getAt( last) ) )
+ if (! pts->getAt(last - 1).equals2D( pts->getAt(last) ) )
// compute quadrant for next possible segment in chain
- int quad=Quadrant::quadrant(pts->getAt(last-1),pts->getAt(last));
- if (quad!=chainQuad) break;
+ int quad = Quadrant::quadrant(pts->getAt(last-1),
+ pts->getAt(last));
+ if (quad != chainQuad) break;
- last++;
+ ++last;
#if GEOS_DEBUG
std::cerr<<"MonotoneChainBuilder::findChainEnd() returning"<<std::endl;
#endif
return static_cast<int>(last - 1);
More information about the geos-commits
