[geos-commits] r2473 - in trunk/source: headers/geos/index/chain
index/chain
svn_geos at osgeo.org
Wed May 6 11:31:32 EDT 2009
Author: strk
Date: 2009-05-06 11:31:32 -0400 (Wed, 06 May 2009)
New Revision: 2473
trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h
trunk/source/index/chain/MonotoneChainBuilder.cpp
Port MonotoneChainBuilder up to JTS-1.10. Tweak some signatures to use stricter signedness.
Modified: trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h
--- trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h 2009-05-06 14:55:06 UTC (rev 2472)
+++ trunk/source/headers/geos/index/chain/MonotoneChainBuilder.h 2009-05-06 15:31:32 UTC (rev 2473)
@@ -13,7 +13,7 @@
- * Last port: index/chain/MonotoneChainBuilder.java rev 1.9
+ * Last port: index/chain/MonotoneChainBuilder.java rev 1.12 (JTS-1.10)
@@ -39,11 +39,10 @@
namespace chain { // geos::index::chain
/** \brief
- * A MonotoneChainBuilder implements functions to determine the monotone chains
- * in a sequence of points.
+ * Constructs {@link MonotoneChain}s
+ * for sequences of {@link Coordinate}s.
- * TODO: use vector<const Coordinate*> instead
+ * TODO: use vector<const Coordinate*> instead ?
class MonotoneChainBuilder {
@@ -77,17 +76,28 @@
/** \brief
* Fill the given vector with start/end indexes of the monotone chains
* for the given CoordinateSequence.
- * The last entry in the array points to the end point of the point array,
+ * The last entry in the array points to the end point of the point
+ * array,
* for use as a sentinel.
- static void getChainStartIndices(const geom::CoordinateSequence *pts,
- std::vector<int>& startIndexList);
+ static void getChainStartIndices(const geom::CoordinateSequence& pts,
+ std::vector<std::size_t>& startIndexList);
- /** \brief
+private:
+ * Finds the index of the last point in a monotone chain
+ * starting at a given point.
+ * Any repeated points (0-length segments) will be included
+ * in the monotone chain returned.
* @return the index of the last point in the monotone chain
- * starting at <code>start</code>.
+ * starting at <code>start</code>.
+ * NOTE: aborts if 'start' is >= pts.getSize()
- static int findChainEnd(const geom::CoordinateSequence *pts, int start);
+ static size_t findChainEnd(const geom::CoordinateSequence& pts,
+ size_t start);
} // namespace geos::index::chain
Modified: trunk/source/index/chain/MonotoneChainBuilder.cpp
--- trunk/source/index/chain/MonotoneChainBuilder.cpp 2009-05-06 14:55:06 UTC (rev 2472)
+++ trunk/source/index/chain/MonotoneChainBuilder.cpp 2009-05-06 15:31:32 UTC (rev 2473)
@@ -13,7 +13,7 @@
@@ -55,8 +55,8 @@
MonotoneChainBuilder::getChains(const CoordinateSequence* pts, void* context,
vector<MonotoneChain*>& mcList)
- vector<int> startIndex;
- getChainStartIndices(pts, startIndex);
+ vector<size_t> startIndex;
+ getChainStartIndices(*pts, startIndex);
size_t nindexes = startIndex.size();
if (nindexes > 0)
@@ -69,63 +69,64 @@
- * Return an array containing lists of start/end indexes of the monotone chains
- * for the given list of coordinates.
- * for use as a sentinel.
+/* static public */
void
-MonotoneChainBuilder::getChainStartIndices(const CoordinateSequence *pts,
- vector<int>& startIndexList)
+MonotoneChainBuilder::getChainStartIndices(const CoordinateSequence& pts,
+ vector<size_t>& startIndexList)
// find the startpoint (and endpoints) of all monotone chains
// in this edge
- int start = 0;
+ size_t start = 0;
startIndexList.push_back(start);
- const std::size_t n = pts->getSize() - 1;
+ const size_t n = pts.getSize() - 1;
do
- int last = findChainEnd(pts, start);
+ size_t last = findChainEnd(pts, start);
startIndexList.push_back(last);
start = last;
- } while (static_cast<std::size_t>(start) < n);
+ } while (start < n);
-/* public static */
-int
-MonotoneChainBuilder::findChainEnd(const CoordinateSequence *pts, int start)
+/* private static */
+size_t
+MonotoneChainBuilder::findChainEnd(const CoordinateSequence& pts, size_t start)
- std::size_t safeStart = start;
- std::size_t npts = pts->getSize();
+ const size_t npts = pts.getSize(); // cache
+ assert(start < npts);
+ assert(npts); // should be implied by the assertion above,
+ // 'start' being unsigned
+ size_t safeStart = start;
// skip any zero-length segments at the start of the sequence
// (since they cannot be used to establish a quadrant)
while ( safeStart < npts - 1
- && pts->getAt(safeStart).equals2D(pts->getAt(safeStart+1)) )
+ && pts[safeStart].equals2D(pts[safeStart+1]) )
++safeStart;
// check if there are NO non-zero-length segments
if (safeStart >= npts - 1) {
- return static_cast<int>(npts - 1);
+ return npts - 1;
// determine overall quadrant for chain
- int chainQuad = Quadrant::quadrant(pts->getAt(safeStart),
- pts->getAt(safeStart + 1));
- std::size_t last = start + 1;
+ // (which is the starting quadrant)
+ int chainQuad = Quadrant::quadrant(pts[safeStart],
+ pts[safeStart + 1]);
+ size_t last = start + 1;
while (last < npts)
- // skip a zero-length segnments
- if (! pts->getAt(last - 1).equals2D( pts->getAt(last) ) )
+ // skip zero-length segments, but include them in the chain
+ if (! pts[last - 1].equals2D( pts[last] ) )
// compute quadrant for next possible segment in chain
- int quad = Quadrant::quadrant(pts->getAt(last-1),
- pts->getAt(last));
+ int quad = Quadrant::quadrant( pts[last - 1],
+ pts[last] );
if (quad != chainQuad) break;
++last;
@@ -134,7 +135,7 @@
std::cerr<<"MonotoneChainBuilder::findChainEnd() returning"<<std::endl;
#endif
- return static_cast<int>(last - 1);
+ return last - 1;
} // namespace geos.index.chain
More information about the geos-commits
