[geos-commits] r2474 - in trunk/source: headers/geos/index/chain
index/chain
svn_geos at osgeo.org
Wed May 6 11:47:06 EDT 2009
Author: strk
Date: 2009-05-06 11:47:06 -0400 (Wed, 06 May 2009)
New Revision: 2474
trunk/source/headers/geos/index/chain/MonotoneChain.h
trunk/source/index/chain/MonotoneChain.cpp
Port MonotoneChain up to JTS-1.10, plus minor dox improvement (memory-oriented)
Modified: trunk/source/headers/geos/index/chain/MonotoneChain.h
--- trunk/source/headers/geos/index/chain/MonotoneChain.h 2009-05-06 15:31:32 UTC (rev 2473)
+++ trunk/source/headers/geos/index/chain/MonotoneChain.h 2009-05-06 15:47:06 UTC (rev 2474)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: index/chain/MonotoneChain.java rev. 1.15 (JTS-1.10)
#ifndef GEOS_IDX_CHAIN_MONOTONECHAIN_H
@@ -38,22 +42,23 @@
namespace chain { // geos::index::chain
/** \brief
- * MonotoneChains are a way of partitioning the segments of a linestring to
+ * Monotone Chains are a way of partitioning the segments of a linestring to
* allow for fast searching of intersections.
* They have the following properties:
- * - the segments within a monotone chain will never intersect each other
- * - the envelope of any contiguous subset of the segments in a monotone chain
- * is equal to the envelope of the endpoints of the subset.
+ * - the segments within a monotone chain never intersect each other
+ * - the envelope of any contiguous subset of the segments in a monotone
+ * chain is equal to the envelope of the endpoints of the subset.
- * Property 1 means that there is no need to test pairs of segments from within
- * the same monotone chain for intersection.
- * Property 2 allows
- * binary search to be used to find the intersection points of two monotone chains.
- * For many types of real-world data, these properties eliminate a large number of
- * segment comparisons, producing substantial speed gains.
+ * Property 1 means that there is no need to test pairs of segments from
+ * within the same monotone chain for intersection.
+ * Property 2 allows an efficient binary search to be used to find the
+ * intersection points of two monotone chains.
+ * For many types of real-world data, these properties eliminate
+ * a large number of segment comparisons, producing substantial speed gains.
* One of the goals of this implementation of MonotoneChains is to be
* as space and time efficient as possible. One design choice that aids this
* is that a MonotoneChain is based on a subarray of a list of points.
@@ -74,28 +79,33 @@
* returned by the query.
* However, it does mean that the queries are not thread-safe.
- * Last port: index/chain/MonotoneChain.java rev. 1.13 (JTS-1.7)
class MonotoneChain
public:
- MonotoneChain(const geom::CoordinateSequence *newPts,
- int nstart, int nend, void* nContext);
+ MonotoneChain(const geom::CoordinateSequence* pts,
+ size_t start, size_t end, void* context);
~MonotoneChain();
+ /// Returned envelope is owned by this class
geom::Envelope* getEnvelope();
- int getStartIndex() { return start; }
+ size_t getStartIndex() { return start; }
- int getEndIndex() { return end; }
+ size_t getEndIndex() { return end; }
+ /// Set given LineSegment with points of the segment starting
+ /// at the given index.
void getLineSegment(unsigned int index, geom::LineSegment *ls);
* Return the subsequence of coordinates forming this chain.
* Allocates a new CoordinateSequence to hold the Coordinates
+ * TODO: return by auto_ptr
geom::CoordinateSequence* getCoordinates();
@@ -125,13 +135,22 @@
void computeOverlaps(int start0, int end0, MonotoneChain* mc,
int start1, int end1, MonotoneChainOverlapAction* mco);
+ /// Externally owned (could be a reference)
const geom::CoordinateSequence* pts;
- geom::Envelope* env;
+ /// Owned by this class, lazely created
+ geom::Envelope* env;
/// user-defined information
void* context;
- int start;
- int end;
- /// useful for optimizing chain comparisons
+ /// Index of chain start vertex into the CoordinateSequence, 0 based.
+ size_t start;
+ /// Index of chain end vertex into the CoordinateSequence, 0 based.
+ size_t end;
+ /// useful for optimizing chain comparisons
int id;
Modified: trunk/source/index/chain/MonotoneChain.cpp
--- trunk/source/index/chain/MonotoneChain.cpp 2009-05-06 15:31:32 UTC (rev 2473)
+++ trunk/source/index/chain/MonotoneChain.cpp 2009-05-06 15:47:06 UTC (rev 2474)
@@ -14,7 +14,7 @@
@@ -32,7 +32,7 @@
namespace chain { // geos.index.chain
MonotoneChain::MonotoneChain(const geom::CoordinateSequence *newPts,
+ size_t nstart, size_t nend, void* nContext)
: pts(newPts), env(0), context(nContext), start(nstart), end(nend), id(-1)
More information about the geos-commits
