[geos-commits] r2494 - in trunk/source:
headers/geos/operation/distance operation/distance
svn_geos at osgeo.org
Fri May 8 06:10:47 EDT 2009
Author: strk
Date: 2009-05-08 06:10:47 -0400 (Fri, 08 May 2009)
New Revision: 2494
trunk/source/headers/geos/operation/distance/DistanceOp.h
trunk/source/operation/distance/DistanceOp.cpp
Add isWithinDistance() to DistanceOp, reaching rev 1.17 of JTS
Modified: trunk/source/headers/geos/operation/distance/DistanceOp.h
--- trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 09:39:39 UTC (rev 2493)
+++ trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 10:10:47 UTC (rev 2494)
@@ -13,7 +13,7 @@
- * Last port: operation/distance/DistanceOp.java rev 1.16
+ * Last port: operation/distance/DistanceOp.java rev 1.17
@@ -46,32 +46,56 @@
namespace operation { // geos::operation
namespace distance { // geos::operation::distance
-/** \brief
- * Computes the distance and
- * closest points between two {@link Geometry}s.
+ * \brief
+ * Find two points on two {@link Geometry}s which lie
+ * within a given distance, or else are the nearest points
+ * on the geometries (in which case this also
+ * provides the distance between the geometries).
- * The distance computation finds a pair of points in the input geometries
- * which have minimum distance between them. These points may
- * not be vertices of the geometries, but may lie in the interior of
- * a line segment. In this case the coordinate computed is a close
+ * The distance computation also finds a pair of points in the
+ * input geometries which have the minimum distance between them.
+ * If a point lies in the interior of a line segment,
+ * the coordinate computed is a close
* approximation to the exact point.
* The algorithms used are straightforward O(n^2)
* comparisons. This worst-case performance could be improved on
- * by using Voronoi techniques.
+ * by using Voronoi techniques or spatial indexes.
class DistanceOp {
public:
+ * \brief
* Compute the distance between the closest points of two geometries.
* @param g0 a {@link Geometry}
* @param g1 another {@link Geometry}
* @return the distance between the geometries
- static double distance(const geom::Geometry *g0, const geom::Geometry *g1);
+ static double distance(const geom::Geometry& g0,
+ const geom::Geometry& g1);
+ /// @deprecated, use the version taking references
+ static double distance(const geom::Geometry *g0,
+ const geom::Geometry *g1);
+ * \brief
+ * Test whether two geometries lie within a given distance of
+ * each other.
+ * @param g0 a {@link Geometry}
+ * @param g1 another {@link Geometry}
+ * @param distance the distance to test
+ * @return true if g0.distance(g1) <= distance
+ static bool isWithinDistance(const geom::Geometry& g0,
+ const geom::Geometry& g1,
+ double distance);
* Compute the the closest points of two geometries.
* The points are presented in the same order as the input Geometries.
@@ -81,12 +105,32 @@
static geom::CoordinateSequence* closestPoints(geom::Geometry *g0, geom::Geometry *g1);
+ /// @deprecated use the one taking references
+ DistanceOp(const geom::Geometry *g0, const geom::Geometry *g1);
- * Constructs a DistanceOp that computes the distance and closest points between
- * the two specified geometries.
+ * \brief
+ * Constructs a DistanceOp that computes the distance and
+ * closest points between the two specified geometries.
+ * @param g0 a Geometry
+ * @param g1 a Geometry
- DistanceOp(const geom::Geometry *g0, const geom::Geometry *g1);
+ DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1);
+ * \brief
+ * Constructs a DistanceOp that computes the distance and nearest
+ * points between the two specified geometries.
+ * @param terminateDistance the distance on which to terminate
+ * the search
+ DistanceOp(const geom::Geometry& g0, const geom::Geometry& g1,
+ double terminateDistance);
~DistanceOp();
@@ -119,11 +163,19 @@
private:
+ // input (TODO: use two references instead..)
+ std::vector<geom::Geometry const*> geom;
+ double terminateDistance;
+ // working (TODO: use two auto_ptr, or to concrete types)
algorithm::PointLocator ptLocator;
- std::vector<geom::Geometry const*> geom;
- std::vector<geom::Coordinate *> newCoords;
std::vector<GeometryLocation*> *minDistanceLocation;
double minDistance;
+ // memory management
+ std::vector<geom::Coordinate *> newCoords;
void updateMinDistance(double dist);
void updateMinDistance(std::vector<GeometryLocation*> *locGeom, bool flip);
void computeMinDistance();
Modified: trunk/source/operation/distance/DistanceOp.cpp
--- trunk/source/operation/distance/DistanceOp.cpp 2009-05-08 09:39:39 UTC (rev 2493)
+++ trunk/source/operation/distance/DistanceOp.cpp 2009-05-08 10:10:47 UTC (rev 2494)
@@ -14,7 +14,7 @@
@@ -50,7 +50,7 @@
using namespace geom;
//using namespace geom::util;
-/*public static*/
+/*public static (deprecated)*/
double
DistanceOp::distance(const Geometry *g0, const Geometry *g1)
@@ -59,6 +59,14 @@
/*public static*/
+double
+DistanceOp::distance(const Geometry& g0, const Geometry& g1)
+ DistanceOp distOp(g0,g1);
+ return distOp.distance();
+/*public static*/
CoordinateSequence*
DistanceOp::closestPoints(Geometry *g0,Geometry *g1)
@@ -67,14 +75,36 @@
DistanceOp::DistanceOp(const Geometry *g0, const Geometry *g1):
- geom(2)
+ geom(2),
+ terminateDistance(0.0),
+ minDistanceLocation(0),
+ minDistance(DoubleInfinity)
- geom[0]=g0;
- geom[1]=g1;
- minDistance=DoubleInfinity;
- minDistanceLocation=NULL;
+ geom[0] = g0;
+ geom[1] = g1;
+DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1):
+ geom(2),
+ geom[0] = &g0;
+ geom[1] = &g1;
+DistanceOp::DistanceOp(const Geometry& g0, const Geometry& g1, double tdist)
+ geom(2),
+ terminateDistance(tdist),
+ geom[0] = &g0;
+ geom[1] = &g1;
DistanceOp::~DistanceOp()
size_t i;
@@ -169,7 +199,7 @@
if (minDistanceLocation!=NULL) return;
minDistanceLocation = new vector<GeometryLocation*>(2);
computeContainmentDistance();
- if (minDistance<=0.0) return;
+ if (minDistance <= terminateDistance) return;
computeLineDistance();
@@ -190,7 +220,7 @@
if (polys1.size()>0) {
vector<GeometryLocation*> *insideLocs0 = ConnectedElementLocationFilter::getLocations(geom[0]);
computeInside(insideLocs0, polys1, locPtPoly);
- if (minDistance <= 0.0) {
+ if (minDistance <= terminateDistance) {
(*minDistanceLocation)[0] = (*locPtPoly)[0];
(*minDistanceLocation)[1] = (*locPtPoly)[1];
delete locPtPoly;
@@ -213,7 +243,7 @@
if (polys0.size()>0) {
vector<GeometryLocation*> *insideLocs1 = ConnectedElementLocationFilter::getLocations(geom[1]);
computeInside(insideLocs1, polys0, locPtPoly);
// flip locations, since we are testing geom 1 VS geom 0
(*minDistanceLocation)[0] = (*locPtPoly)[1];
(*minDistanceLocation)[1] = (*locPtPoly)[0];
@@ -250,7 +280,7 @@
for (size_t j=0, nj=polys.size(); j<nj; ++j)
computeInside(loc, polys[j], locPtPoly);
+ if (minDistance<=terminateDistance) return;
@@ -299,7 +329,7 @@
// bail whenever minDistance goes to zero, since it can't get any less
computeMinDistanceLines(lines0, lines1, locGeom);
updateMinDistance(&locGeom, false);
return;
@@ -307,7 +337,7 @@
locGeom[1]=NULL;
computeMinDistanceLinesPoints(lines0, pts1, locGeom);
return;
@@ -315,7 +345,7 @@
locGeom[1]=NULL;
computeMinDistanceLinesPoints(lines1, pts0, locGeom);
updateMinDistance(&locGeom, true);
- if (minDistance <= 0.0){
+ if (minDistance <= terminateDistance){
return;
@@ -338,7 +368,7 @@
for (size_t j=0, nj=lines1.size(); j<nj; ++j) {
const LineString *line1=lines1[j];
computeMinDistance(line0, line1, locGeom);
@@ -363,7 +393,7 @@
locGeom[0] = new GeometryLocation(pt0, 0, *(pt0->getCoordinate()));
locGeom[1] = new GeometryLocation(pt1, 0, *(pt1->getCoordinate()));
if ( i<points0.size()-1 || j<points1.size()-1)
delete locGeom[0]; locGeom[0]=NULL;
@@ -385,7 +415,7 @@
for (size_t j=0;j<points.size();j++) {
const Point *pt=points[j];
computeMinDistance(line,pt,locGeom);
if ( i<lines.size()-1 || j<points.size()-1)
@@ -435,7 +465,7 @@
locGeom[0] = new GeometryLocation(line0, i, *c1);
locGeom[1] = new GeometryLocation(line1, j, *c2);
if ( i<npts0-1 || j<npts1-1)
@@ -478,10 +508,20 @@
delete locGeom[1];
locGeom[1] = new GeometryLocation(pt, 0, *coord);
+/* public static */
+bool
+DistanceOp::isWithinDistance(const geom::Geometry& g0,
+ double distance)
+ DistanceOp distOp(g0, g1, distance);
+ return distOp.distance() <= distance;
} // namespace geos.operation.distance
} // namespace geos
More information about the geos-commits
