[geos-commits] r2495 - in trunk/source:
headers/geos/operation/distance operation/distance
svn_geos at osgeo.org
Fri May 8 08:09:24 EDT 2009
Author: strk
Date: 2009-05-08 08:09:23 -0400 (Fri, 08 May 2009)
New Revision: 2495
trunk/source/headers/geos/operation/distance/DistanceOp.h
trunk/source/operation/distance/DistanceOp.cpp
Don't wipe out closest locations after computing them (doh). Fixes bug #236. Takes the chance to make the GeometryLocation retrival function private as we don't install GeometryLocation.h header anyway (for future cleanups), and to rename a function to follow current JTS naming (more renames to come for proper sync)
Modified: trunk/source/headers/geos/operation/distance/DistanceOp.h
--- trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 10:10:47 UTC (rev 2494)
+++ trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 12:09:23 UTC (rev 2495)
@@ -149,26 +149,29 @@
geom::CoordinateSequence* closestPoints();
+private:
* Report the locations of the closest points in the input geometries.
- * The locations are presented in the same order as the input Geometries.
+ * The locations are presented in the same order as the input
+ * Geometries.
* @return a pair of {@link GeometryLocation}s for the closest points.
* Ownership of returned object is left to this instance and
- * it's reference will be invalidated by next call
- * to distance()
+ * it's reference will be alive for the whole lifetime of it.
+ * NOTE: this is public in JTS, but we aim at API reduction here...
std::vector<GeometryLocation*>* closestLocations();
-private:
// input (TODO: use two references instead..)
std::vector<geom::Geometry const*> geom;
double terminateDistance;
- // working (TODO: use two auto_ptr, or to concrete types)
+ // working
algorithm::PointLocator ptLocator;
+ // TODO: use auto_ptr
std::vector<GeometryLocation*> *minDistanceLocation;
double minDistance;
@@ -176,9 +179,11 @@
std::vector<geom::Coordinate *> newCoords;
- void updateMinDistance(double dist);
- void updateMinDistance(std::vector<GeometryLocation*> *locGeom, bool flip);
+ void updateMinDistance(std::vector<GeometryLocation*>& locGeom,
+ bool flip);
void computeMinDistance();
void computeContainmentDistance();
void computeInside(std::vector<GeometryLocation*> *locs,
@@ -189,7 +194,11 @@
const geom::Polygon *poly,
std::vector<GeometryLocation*> *locPtPoly);
- void computeLineDistance();
+ * Computes distance between facets (lines and points)
+ * of input geometries.
+ void computeFacetDistance();
void computeMinDistanceLines(
const std::vector<const geom::LineString*>& lines0,
Modified: trunk/source/operation/distance/DistanceOp.cpp
--- trunk/source/operation/distance/DistanceOp.cpp 2009-05-08 10:10:47 UTC (rev 2494)
+++ trunk/source/operation/distance/DistanceOp.cpp 2009-05-08 12:09:23 UTC (rev 2495)
@@ -38,7 +38,12 @@
#include <geos/geom/util/PointExtracter.h>
#include <vector>
+#include <iostream>
+#ifndef GEOS_DEBUG
+#define GEOS_DEBUG 0
+#endif
using namespace std;
using namespace geos::geom;
//using namespace geos::algorithm;
@@ -132,33 +137,31 @@
-* Report the coordinates of the closest points in the input geometries.
-* The points are presented in the same order as the input Geometries.
-* @return a pair of Coordinate s of the closest points
+/* public */
CoordinateSequence*
DistanceOp::closestPoints()
- assert(0 != minDistanceLocation);
- std::vector<GeometryLocation*>& locs = *minDistanceLocation;
+ // lazily creates minDistanceLocation
+ computeMinDistance();
- computeMinDistance();
+ assert(0 != minDistanceLocation);
+ std::vector<GeometryLocation*>& locs = *minDistanceLocation;
- // FIXME: This code (refactored to make the bug visible) causes
- // crash reported in Ticket #236
- // NOTE: In order to reproduce, uncomment test case test<17>
- // in tests/unit/operation/distance/DistanceOpTest.cpp
- GeometryLocation* loc0 = locs[0];
- GeometryLocation* loc1 = locs[1];
- // Assertion fails, so...
- assert(0 != loc0 && 0 != loc1);
- // ...accesss violation is thrown.
- Coordinate& c0 = loc0->getCoordinate();
- Coordinate& c1 = loc1->getCoordinate();
+ // Empty input geometries result in this behaviour
+ if ( locs[0] == 0 || locs[1] == 0 )
+ // either both or none are set..
+ assert(locs[0] == 0 && locs[1] == 0);
- CoordinateSequence* closestPts = new CoordinateArraySequence();
+ return 0;
+ GeometryLocation* loc0 = locs[0];
+ GeometryLocation* loc1 = locs[1];
+ const Coordinate& c0 = loc0->getCoordinate();
+ const Coordinate& c1 = loc1->getCoordinate();
+ CoordinateSequence* closestPts = new CoordinateArraySequence();
closestPts->add(c0);
closestPts->add(c1);
@@ -176,33 +179,60 @@
return minDistanceLocation;
-void DistanceOp::updateMinDistance(double dist) {
- if (dist<minDistance)
- minDistance=dist;
+void
+DistanceOp::updateMinDistance(vector<GeometryLocation*>& locGeom, bool flip)
+ assert(minDistanceLocation);
-void DistanceOp::updateMinDistance(vector<GeometryLocation*> *locGeom, bool flip){
// if not set then don't update
- if ((*locGeom)[0]==NULL) return;
+ if (locGeom[0]==NULL)
+#if GEOS_DEBUG
+std::cerr << "updateMinDistance called with loc[0] == null and loc[1] == " << locGeom[1] << std::endl;
+#endif
+ assert(locGeom[1] == NULL);
+ return;
delete (*minDistanceLocation)[0];
delete (*minDistanceLocation)[1];
if (flip) {
- (*minDistanceLocation)[0]=(*locGeom)[1];
- (*minDistanceLocation)[1]=(*locGeom)[0];
+ (*minDistanceLocation)[0]=locGeom[1];
+ (*minDistanceLocation)[1]=locGeom[0];
} else {
- (*minDistanceLocation)[0]=(*locGeom)[0];
- (*minDistanceLocation)[1]=(*locGeom)[1];
+ (*minDistanceLocation)[0]=locGeom[0];
+ (*minDistanceLocation)[1]=locGeom[1];
-void DistanceOp::computeMinDistance() {
- if (minDistanceLocation!=NULL) return;
- minDistanceLocation = new vector<GeometryLocation*>(2);
- computeContainmentDistance();
- if (minDistance <= terminateDistance) return;
- computeLineDistance();
+/*private*/
+void
+DistanceOp::computeMinDistance()
+ // only compute once!
+ if (minDistanceLocation) return;
+#if GEOS_DEBUG
+ std::cerr << "---Start: " << geom[0]->toString() << " - " << geom[1]->toString() << std::endl;
+#endif
+ minDistanceLocation = new vector<GeometryLocation*>(2);
+ computeContainmentDistance();
+ if (minDistance <= terminateDistance)
+ return;
+ computeFacetDistance();
+#if GEOS_DEBUG
+ std::cerr << "---End " << std::endl;
+#endif
+/*private*/
void
DistanceOp::computeContainmentDistance()
@@ -213,14 +243,25 @@
PolygonExtracter::getPolygons(*(geom[0]), polys0);
PolygonExtracter::getPolygons(*(geom[1]), polys1);
+#if GEOS_DEBUG
+ std::cerr << "PolygonExtracter found " << polys0.size() << " polygons in geometry 1 and " << polys1.size() << " polygons in geometry 2 " << std::endl;
+#endif
+ // NOTE:
+ // Expected to fill minDistanceLocation items
+ // if minDistance <= terminateDistance
vector<GeometryLocation*> *locPtPoly = new vector<GeometryLocation*>(2);
// test if either geometry is wholely inside the other
- if (polys1.size()>0) {
- vector<GeometryLocation*> *insideLocs0 = ConnectedElementLocationFilter::getLocations(geom[0]);
+ if ( ! polys1.empty() )
+ vector<GeometryLocation*> *insideLocs0 =
+ ConnectedElementLocationFilter::getLocations(geom[0]);
computeInside(insideLocs0, polys1, locPtPoly);
if (minDistance <= terminateDistance) {
+ assert( (*locPtPoly)[0] );
+ assert( (*locPtPoly)[1] );
(*minDistanceLocation)[0] = (*locPtPoly)[0];
(*minDistanceLocation)[1] = (*locPtPoly)[1];
delete locPtPoly;
@@ -240,11 +281,15 @@
delete (*insideLocs0)[i];
delete insideLocs0;
- if (polys0.size()>0) {
+ if ( ! polys0.empty() )
vector<GeometryLocation*> *insideLocs1 = ConnectedElementLocationFilter::getLocations(geom[1]);
computeInside(insideLocs1, polys0, locPtPoly);
// flip locations, since we are testing geom 1 VS geom 0
(*minDistanceLocation)[0] = (*locPtPoly)[1];
(*minDistanceLocation)[1] = (*locPtPoly)[0];
delete locPtPoly;
@@ -264,7 +309,13 @@
delete (*insideLocs1)[i];
delete insideLocs1;
delete locPtPoly;
+ // If minDistance <= terminateDistance we must have
+ // set minDistanceLocations to some non-null item
+ assert( minDistance > terminateDistance ||
+ ( (*minDistanceLocation)[0] && (*minDistanceLocation)[1] ) );
@@ -304,7 +355,7 @@
/*private*/
void
-DistanceOp::computeLineDistance()
+DistanceOp::computeFacetDistance()
using geom::util::LinearComponentExtracter;
using geom::util::PointExtracter;
@@ -321,38 +372,65 @@
LinearComponentExtracter::getLines(*(geom[0]), lines0);
LinearComponentExtracter::getLines(*(geom[1]), lines1);
+#if GEOS_DEBUG
+ std::cerr << "LinearComponentExtracter found "
+ << lines0.size() << " lines in geometry 1 and "
+ << lines1.size() << " lines in geometry 2 "
+ << std::endl;
+#endif
Point::ConstVect pts0;
Point::ConstVect pts1;
PointExtracter::getPoints(*(geom[0]), pts0);
PointExtracter::getPoints(*(geom[1]), pts1);
+#if GEOS_DEBUG
+ std::cerr << "PointExtracter found "
+ << pts0.size() << " points in geometry 1 and "
+ << pts1.size() << " points in geometry 2 "
+ << std::endl;
+#endif
// bail whenever minDistance goes to zero, since it can't get any less
computeMinDistanceLines(lines0, lines1, locGeom);
- updateMinDistance(&locGeom, false);
+ updateMinDistance(locGeom, false);
+#if GEOS_DEBUG
+ std::cerr << "Early termination after line-line distance" << std::endl;
+#endif
return;
locGeom[0]=NULL;
locGeom[1]=NULL;
computeMinDistanceLinesPoints(lines0, pts1, locGeom);
+#if GEOS_DEBUG
+ std::cerr << "Early termination after lines0-points1 distance" << std::endl;
+#endif
return;
locGeom[0]=NULL;
locGeom[1]=NULL;
computeMinDistanceLinesPoints(lines1, pts0, locGeom);
- updateMinDistance(&locGeom, true);
+ updateMinDistance(locGeom, true);
if (minDistance <= terminateDistance){
+#if GEOS_DEBUG
+ std::cerr << "Early termination after lines1-points0 distance" << std::endl;
+#endif
return;
locGeom[0]=NULL;
locGeom[1]=NULL;
computeMinDistancePoints(pts0, pts1, locGeom);
+#if GEOS_DEBUG
+ std::cerr << "termination after pts-pts distance" << std::endl;
+#endif
/*private*/
@@ -380,25 +458,33 @@
const Point::ConstVect& points1,
vector<GeometryLocation*>& locGeom)
- for (size_t i=0, ni=points0.size(); i<ni; ++i) {
- const Point *pt0=points0[i];
- //Geometry *pt0=(*points0)[i];
- for (size_t j=0, nj=points1.size(); j<nj; ++j) {
- const Point *pt1=points1[j];
- //Geometry *pt1=(*points1)[j];
- double dist=pt0->getCoordinate()->distance(*(pt1->getCoordinate()));
- if (dist < minDistance) {
+ for (size_t i=0, ni=points0.size(); i<ni; ++i)
+ const Point *pt0 = points0[i];
+ for (size_t j=0, nj=points1.size(); j<nj; ++j)
+ const Point *pt1 = points1[j];
+ double dist = pt0->getCoordinate()->distance(*(pt1->getCoordinate()));
+#if GEOS_DEBUG
+ std::cerr << "Distance "
+ << pt0->toString() << " - "
+ << pt1->toString() << ": "
+ << dist << ", minDistance: " << minDistance
+ << std::endl;
+#endif
+ if (dist < minDistance)
minDistance = dist;
// this is wrong - need to determine closest points on both segments!!!
+ delete locGeom[0];
locGeom[0] = new GeometryLocation(pt0, 0, *(pt0->getCoordinate()));
+ delete locGeom[1];
locGeom[1] = new GeometryLocation(pt1, 0, *(pt1->getCoordinate()));
if (minDistance<=terminateDistance) return;
- if ( i<points0.size()-1 || j<points1.size()-1)
- delete locGeom[0]; locGeom[0]=NULL;
- delete locGeom[1]; locGeom[1]=NULL;
@@ -410,17 +496,14 @@
const Point::ConstVect& points,
- for (size_t i=0;i<lines.size();i++) {
+ for (size_t i=0;i<lines.size();i++)
const LineString *line=lines[i];
- for (size_t j=0;j<points.size();j++) {
+ for (size_t j=0;j<points.size();j++)
const Point *pt=points[j];
computeMinDistance(line,pt,locGeom);
- if ( i<lines.size()-1 || j<points.size()-1)
@@ -462,15 +545,13 @@
newCoords.push_back(c1);
newCoords.push_back(c2);
delete closestPt;
locGeom[0] = new GeometryLocation(line0, i, *c1);
locGeom[1] = new GeometryLocation(line1, j, *c2);
- if ( i<npts0-1 || j<npts1-1)
More information about the geos-commits
