[geos-commits] r2496 - trunk/source/headers/geos/operation/distance
svn_geos at osgeo.org
Fri May 8 08:11:52 EDT 2009
Author: strk
Date: 2009-05-08 08:11:52 -0400 (Fri, 08 May 2009)
New Revision: 2496
trunk/source/headers/geos/operation/distance/DistanceOp.h
Document semantic of a null return from closestPoints
Modified: trunk/source/headers/geos/operation/distance/DistanceOp.h
--- trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 12:09:23 UTC (rev 2495)
+++ trunk/source/headers/geos/operation/distance/DistanceOp.h 2009-05-08 12:11:52 UTC (rev 2496)
@@ -97,13 +97,18 @@
* Compute the the closest points of two geometries.
* The points are presented in the same order as the input Geometries.
* @param g0 a {@link Geometry}
* @param g1 another {@link Geometry}
- * @return the closest points in the geometries, ownership to caller
+ * @return the closest points in the geometries, ownership to caller.
+ * A NULL return means one of the geometries is empty.
- static geom::CoordinateSequence* closestPoints(geom::Geometry *g0, geom::Geometry *g1);
+ static geom::CoordinateSequence* closestPoints(
+ const geom::Geometry *g0,
+ const geom::Geometry *g1);
/// @deprecated use the one taking references
DistanceOp(const geom::Geometry *g0, const geom::Geometry *g1);
More information about the geos-commits
