[geos-commits] r2497 - trunk/tests/unit/operation/distance
svn_geos at osgeo.org
Fri May 8 08:27:23 EDT 2009
Author: strk
Date: 2009-05-08 08:27:23 -0400 (Fri, 08 May 2009)
New Revision: 2497
trunk/tests/unit/operation/distance/DistanceOpTest.cpp
Add the complete set of tests for closedPoints
Modified: trunk/tests/unit/operation/distance/DistanceOpTest.cpp
--- trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2009-05-08 12:11:52 UTC (rev 2496)
+++ trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2009-05-08 12:27:23 UTC (rev 2497)
@@ -31,6 +31,7 @@
geos::io::WKTReader wktreader;
typedef geos::geom::Geometry::AutoPtr GeomPtr;
+ typedef std::auto_ptr<geos::geom::CoordinateSequence> CSPtr;
test_distanceop_data()
: gf(), wktreader(&gf)
@@ -50,6 +51,7 @@
void object::test<1>()
using geos::operation::distance::DistanceOp;
+ using geos::geom::Coordinate;
std::string wkt0("POINT(0 0)");
std::string wkt1("POINT(10 0)");
@@ -60,11 +62,9 @@
ensure_equals(dist.distance(), 10);
- // TODO: test closestPoints() and
- // closestLocations()
- geos::geom::CoordinateSequence* coords = dist.closestPoints();
- ensure(0 != coords);
- delete coords;
+ CSPtr cs ( dist.closestPoints());
+ ensure_equals(cs->getAt(0), Coordinate(0, 0));
+ ensure_equals(cs->getAt(1), Coordinate(10, 0));
template<>
@@ -72,6 +72,7 @@
void object::test<2>()
std::string wkt1("MULTIPOINT(10 0, 50 30)");
@@ -82,8 +83,9 @@
@@ -92,6 +94,7 @@
void object::test<3>()
std::string wkt0("POINT(3 0)");
std::string wkt1("LINESTRING(0 10, 50 10, 100 50)");
@@ -102,8 +105,9 @@
+ ensure_equals(cs->getAt(0), Coordinate(3, 0));
+ ensure_equals(cs->getAt(1), Coordinate(3, 10));
@@ -112,6 +116,7 @@
void object::test<4>()
std::string wkt1("MULTILINESTRING((34 54, 60 34),(0 10, 50 10, 100 50))");
@@ -122,8 +127,9 @@
@@ -132,6 +138,7 @@
void object::test<5>()
std::string wkt0("POINT(35 60)");
std::string wkt1("POLYGON((34 54, 60 34, 60 54, 34 54),(50 50, 52 50, 52 48, 50 48, 50 50))");
@@ -142,8 +149,9 @@
ensure_equals(dist.distance(), 6);
+ ensure_equals(cs->getAt(0), Coordinate(35, 60));
+ ensure_equals(cs->getAt(1), Coordinate(35, 54));
@@ -152,6 +160,7 @@
void object::test<6>()
std::string wkt1("MULTIPOLYGON(((34 54, 60 34, 60 54, 34 54),(50 50, 52 50, 52 48, 50 48, 50 50)),( (100 100, 150 100, 150 150, 100 150, 100 100),(120 120, 120 130, 130 130, 130 120, 120 120)) ))");
@@ -162,8 +171,9 @@
@@ -172,6 +182,7 @@
void object::test<7>()
@@ -185,9 +196,9 @@
template<>
@@ -195,6 +206,7 @@
void object::test<8>()
@@ -208,9 +220,7 @@
ensure_equals(dist.distance(), DoubleInfinity);
+ ensure_equals(dist.closestPoints(), (void*)0);
template<>
@@ -218,6 +228,7 @@
void object::test<9>()
std::string wkt0("MULTIPOINT(10 0, 50 30)");
@@ -228,8 +239,9 @@
ensure_equals(dist.distance(), 0);
+ ensure_equals(cs->getAt(0), Coordinate(10, 0));
@@ -238,6 +250,7 @@
void object::test<10>()
std::string wkt1("MULTIPOINT(0 0, 150 30)");
@@ -248,8 +261,9 @@
+ ensure_equals(cs->getAt(1), Coordinate(0, 0));
@@ -258,6 +272,7 @@
void object::test<11>()
std::string wkt0("MULTIPOINT(3 0, 200 30)");
@@ -268,8 +283,9 @@
@@ -278,6 +294,7 @@
void object::test<12>()
std::string wkt0("MULTIPOINT(3 0, -50 30)");
@@ -288,8 +305,9 @@
@@ -298,6 +316,7 @@
void object::test<13>()
std::string wkt0("MULTIPOINT(-100 0, 35 60)");
@@ -308,8 +327,9 @@
@@ -318,6 +338,7 @@
void object::test<14>()
@@ -328,9 +349,9 @@
template<>
@@ -338,6 +359,7 @@
void object::test<15>()
@@ -351,8 +373,9 @@
@@ -361,6 +384,7 @@
void object::test<16>()
@@ -374,8 +398,7 @@
@@ -386,6 +409,7 @@
void object::test<17>()
std::string wkt0("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))");
std::string wkt1("POLYGON((1.25 0.25, 1.25 0.75, 1.75 0.75, 1.75 0.25, 1.25 0.25))");
@@ -396,11 +420,41 @@
DistanceOp dist(g0.get(), g1.get());
ensure_equals(dist.distance(), 0.25);
- // FIXME: This operation crashes becasue of both GeometryLocation's are NULL
- // in DistanceOp::closestPoints()
- //geos::geom::CoordinateSequence* cs dist.closestPoints();
+ ensure_equals(cs->getAt(0), Coordinate(1, 0.25));
+ ensure_equals(cs->getAt(1), Coordinate(1.25, 0.25));
+ // Test for isWithinDistance
+ template<>
+ template<>
+ void object::test<18>()
+ using geos::operation::distance::DistanceOp;
+ std::string wkt0("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))");
+ std::string wkt1("POLYGON((1.25 0.25, 1.25 0.75, 1.75 0.75, 1.75 0.25, 1.25 0.25))");
+ GeomPtr g0(wktreader.read(wkt0));
+ GeomPtr g1(wktreader.read(wkt1));
+ ensure_equals(DistanceOp::distance(*g0, *g1), 0.25);
+ ensure(DistanceOp::isWithinDistance(*g0, *g1, 0.26));
+ ensure(!DistanceOp::isWithinDistance(*g0, *g1, 0.24));
+ wkt0 = "LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)";
+ wkt1 = "LINESTRING(2 0, 10 1, 10 10)";
+ g0.reset(wktreader.read(wkt0));
+ g1.reset(wktreader.read(wkt1));
+ ensure_equals(DistanceOp::distance(*g0, *g1), 1);
+ ensure(DistanceOp::isWithinDistance(*g0, *g1, 2));
+ ensure(!DistanceOp::isWithinDistance(*g0, *g1, 0.8));
+ // TODO: test closestPoints
// TODO: finish the tests by adding:
// LINESTRING - *all*
// MULTILINESTRING - *all*
More information about the geos-commits
