[geos-commits] r2503 - trunk/source/operation/buffer
svn_geos at osgeo.org
Tue May 12 12:48:06 EDT 2009
Author: strk
Date: 2009-05-12 12:48:06 -0400 (Tue, 12 May 2009)
New Revision: 2503
trunk/source/operation/buffer/SubgraphDepthLocater.cpp
Have DepthSegment hold a real LineSegment, not a reference. SubgraphDepthLocater was passing the same LineSegment reference to multiple DepthSegments, messing everything up. This fixes bug #244.
Modified: trunk/source/operation/buffer/SubgraphDepthLocater.cpp
--- trunk/source/operation/buffer/SubgraphDepthLocater.cpp 2009-05-12 15:38:23 UTC (rev 2502)
+++ trunk/source/operation/buffer/SubgraphDepthLocater.cpp 2009-05-12 16:48:06 UTC (rev 2503)
@@ -55,7 +55,7 @@
private:
- geom::LineSegment& upwardSeg;
+ geom::LineSegment upwardSeg;
* Compare two collinear segments for left-most ordering.
@@ -80,7 +80,8 @@
int leftDepth;
- DepthSegment(geom::LineSegment &seg, int depth)
+ /// @param seg will be copied to private space
+ DepthSegment(const geom::LineSegment &seg, int depth)
upwardSeg(seg),
leftDepth(depth)
More information about the geos-commits
