[geos-commits] r2504 - in trunk/tests/xmltester: . tests
svn_geos at osgeo.org
Tue May 12 12:49:42 EDT 2009
Author: strk
Date: 2009-05-12 12:49:42 -0400 (Tue, 12 May 2009)
New Revision: 2504
Added:
trunk/tests/xmltester/tests/bug244.xml
trunk/tests/xmltester/Makefile.am
Never fail bug #244 again (regression testcase added)
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-05-12 16:48:06 UTC (rev 2503)
+++ trunk/tests/xmltester/Makefile.am 2009-05-12 16:49:42 UTC (rev 2504)
@@ -16,6 +16,7 @@
$(srcdir)/tests/TestIsValid.xml \
$(srcdir)/tests/robustness.xml \
$(srcdir)/tests/bug188.xml \
+ $(srcdir)/tests/bug244.xml \
$(srcdir)/tests/general/TestBoundary.xml \
$(srcdir)/tests/general/TestBuffer.xml \
$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Added: trunk/tests/xmltester/tests/bug244.xml
--- trunk/tests/xmltester/tests/bug244.xml (rev 0)
+++ trunk/tests/xmltester/tests/bug244.xml 2009-05-12 16:49:42 UTC (rev 2504)
@@ -0,0 +1,23 @@
+<run>
+ <desc>
+http://trac.osgeo.org/geos/ticket/244
+ </desc>
+ <precisionModel type="FLOATING" />
+ <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+ </desc>
+ <a>
+ MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.44833326339722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.02916669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149.965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.769714355469 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.60055541992188,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.356628417969 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2.74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,150.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.164703369141 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442)),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.51025390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,146.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.844604492188 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.36861038208008,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.244110107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.65750026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,144.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.806549072266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.01055717468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.543975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.31583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.314147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.32250022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.3671875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.3347225189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.6783332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.780822753906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.60472202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,147.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.715240478516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.30138969421387,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.604125976562 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.38500022888184,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.880798339844 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.8266658782959,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -10.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.369110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150.031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.6100001335144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.002197265625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.558013916016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.53027772903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,153.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.031646728516 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.574981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.071350097656 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.611358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.123291015625 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.55129909515381,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.15777778625488,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.473297119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.43805503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.543579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.250823974609 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,147.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.642761230469 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.46833324432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.201629638672 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148.017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.008026123047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.566070556641 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143.756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219 -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.641357421875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.993011474609 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.48749923706055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150.571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.200531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.874969482422 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.009979248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,153.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
+ </a>
+<test>
+ <op name='buffer' arg1='A' arg2='0.0' arg3='1'>
+ MULTIPOLYGON(((144.520538330078 -1.12083339691162,144.516387939453 -1.12083339691162,144.514434814453 -1.11611104011536,144.514984130859 -1.10305547714233,144.517211914062 -1.09833335876465,144.521362304688 -1.09972214698792,144.522491455078 -1.10527777671814,144.523315429688 -1.11138892173767,144.522491455078 -1.11611104011536,144.520538330078 -1.12083339691162)),((149.731903076172 -1.60333347320557,149.715515136719 -1.57861113548279,149.7099609375 -1.57027792930603,149.703308105469 -1.56361126899719,149.699127197266 -1.56083345413208,149.681915283203 -1.55722236633301,149.680541992188 -1.56277775764465,149.681915283203 -1.57527780532837,149.681365966797 -1.5813889503479,149.678588867188 -1.58555555343628,149.673034667969 -1.58694458007812,149.663299560547 -1.58277773857117,149.659423828125 -1.58000016212463,149.558013916016 -1.50055575370789,149.533325195312 -1.469722032547,149.530548095703 -1.46555542945862,149.527770996094 -1.45444440841675,149.528594970703 -1.44833326339722,149.542755126953 -1.41472220420837,149.544982910156 -1.41000008583069,149.564147949219 -1.37027788162231,149.579956054688 -1.35527777671814,149.622467041016 -1.35944437980652,149.627166748047 -1.36138892173767,149.663299560547 -1.38666677474976,149.710784912109 -1.42166662216187,149.716918945312 -1.42916655540466,149.719696044922 -1.43333315849304,149.790252685547 -1.57666683197021,149.790802001953 -1.5813889503479,149.731903076172 -1.60333347320557)),((144.517761230469 -1.39833331108093,144.506103515625 -1.38944435119629,144.503326416016 -1.38555550575256,144.505554199219 -1.38055562973022,144.516387939453 -1.38194441795349,144.519989013672 -1.38555550575256,144.521911621094 -1.39555549621582,144.517761230469 -1.39833331108093)),((142.818298339844 -1.73333311080933,142.813598632812 -1.73277759552002,142.812194824219 -1.72722220420837,142.812744140625 -1.72111105918884,142.818298339844 -1.69972205162048,142.821075439453 -1.69583320617676,142.832183837891 -1.69361114501953,142.863006591797 -1.69444441795349,142.866363525391 -1.69777774810791,142.866912841797 -1.70944428443909,142.864410400391 -1.71361112594604,142.859405517578 -1.71555542945862,142.852752685547 -1.70861101150513,142.847198486328 -1.70722222328186,142.841644287109 -1.70861101150513,142.837463378906 -1.71138882637024,142.818298339844 -1.73333311080933)),((147.391937255859 -1.96083331108093,147.399993896484 -1.96638870239258,147.430816650391 -1.9902777671814,147.434417724609 -1.99361109733582,147.44580078125 -2.00944471359253,147.448028564453 -2.01416683197021,147.447204589844 -2.0188889503479,147.439697265625 -2.06083345413208,147.437744140625 -2.06555557250977,147.426086425781 -2.06777811050415,147.275268554688 -2.1211109161377,147.255554199219 -2.14916658401489,147.239135742188 -2.16694450378418,147.22802734375 -2.17638874053955,147.212188720703 -2.18805551528931,147.207458496094 -2.19027757644653,147.201904296875 -2.19166660308838,146.980529785156 -2.1991662979126,146.893035888672 -2.18944406509399,146.8388671875 -2.18194437026978,146.798309326172 -2.16888904571533,146.793579101562 -2.16694450378418,146.726348876953 -2.16083335876465,146.571624755859 -2.23472213745117,146.568023681641 -2.23666667938232,146.563293457031 -2.23472213745117,146.5283203125 -2.20111131668091,146.524993896484 -2.19083309173584,146.518035888672 -2.1497220993042,146.518859863281 -2.14361143112183,146.578308105469 -2.00194454193115,146.580535888672 -1.99722218513489,146.583862304688 -1.99361109733582,146.638580322266 -1.97861099243164,146.844970703125 -1.95055556297302,146.857177734375 -1.94916653633118,146.869689941406 -1.94916653633118,147.093566894531 -1.96638870239258,147.099975585938 -1.96694445610046,147.118286132812 -1.96888875961304,147.164428710938 -1.98333311080933,147.203308105469 -2.003333568573,147.300811767578 -2.02527761459351,147.417755126953 -2.05055570602417,147.419982910156 -2.04583358764648,147.422760009766 -2.03472232818604,147.422760009766 -2.02916669845581,147.420532226562 -2.01083374023438,147.418579101562 -2.00583362579346,147.391937255859 -1.96083331108093)),((147.756927490234 -2.35249996185303,147.766662597656 -2.32388925552368,147.795532226562 -2.26500034332275,147.815246582031 -2.24361133575439,147.832458496094 -2.24555540084839,147.877746582031 -2.28944444656372,147.879119873047 -2.29361152648926,147.856353759766 -2.3313889503479,147.848297119141 -2.33666658401489,147.829132080078 -2.34555530548096,147.824127197266 -2.34777784347534,147.81884765625 -2.34916639328003,147.812469482422 -2.34972190856934,147.756927490234 -2.35249996185303)),((150.367736816406 -2.68666648864746,150.356353759766 -2.66805553436279,150.347473144531 -2.66333341598511,150.341064453125 -2.66249990463257,150.273315429688 -2.67277765274048,150.257476806641 -2.6777777671814,150.242462158203 -2.68305540084839,150.190521240234 -2.68583297729492,150.184143066406 -2.68527746200562,150.109405517578 -2.625,149.972473144531 -2.50111150741577,149.965789794922 -2.4941668510437,149.949127197266 -2.47638845443726,149.948577880859 -2.47166633605957,149.951354980469 -2.46749973297119,149.960784912109 -2.46000003814697,150.079956054688 -2.41416645050049,150.189697265625 -2.37722206115723,150.206085205078 -2.37444448471069,150.216369628906 -2.37777757644653,150.248016357422 -2.39000034332275,150.417205810547 -2.46055555343628,150.443298339844 -2.47583293914795,150.446075439453 -2.47972202301025,150.467193603516 -2.54472255706787,150.468017578125 -2.55777788162231,150.459686279297 -2.64833354949951,150.458312988281 -2.6536111831665,150.448852539062 -2.66472196578979,150.443298339844 -2.66611099243164,150.41943359375 -2.66249990463257,150.406921386719 -2.66388893127441,150.4013671875 -2.6652774810791,150.371887207031 -2.68388891220093,150.367736816406 -2.68666648864746)),((152.659423828125 -3.84277772903442,152.670837402344 -3.85989284515381,152.701080322266 -3.88305521011353,152.739685058594 -3.89611101150513,152.769714355469 -3.90027761459351,152.919128417969 -4.0041675567627,152.989685058594 -4.07583332061768,153.006927490234 -4.09361171722412,153.118560791016 -4.23916625976562,153.12939453125 -4.25555610656738,153.131622314453 -4.26027870178223,153.134429931641 -4.27138900756836,153.132171630859 -4.37861061096191,153.130798339844 -4.39083385467529,153.128021240234 -4.39500045776367,153.121337890625 -4.40194416046143,153.108856201172 -4.40999984741211,153.092468261719 -4.42083358764648,153.080810546875 -4.43000030517578,153.066375732422 -4.44277763366699,153.063018798828 -4.44638824462891,153.0546875 -4.45861148834229,153.04052734375 -4.48527717590332,153.039154052734 -4.49749946594238,153.039703369141 -4.50361156463623,153.041076660156 -4.5091667175293,153.043304443359 -4.51388931274414,153.046630859375 -4.51722240447998,153.059692382812 -4.52555561065674,153.066375732422 -4.53222274780273,153.077453613281 -4.54861068725586,153.079406738281 -4.58916664123535,153.077453613281 -4.60055541992188,152.980255126953 -4.7605562210083,152.974670410156 -4.76666641235352,152.910247802734 -4.82333374023438,152.891662597656 -4.82250022888184,152.743560791016 -4.67305564880371,152.735504150391 -4.66083335876465,152.733306884766 -4.6561107635498,152.693023681641 -4.55833339691162,152.681365966797 -4.5222225189209,152.664978027344 -4.4688892364502,152.662750244141 -4.4572229385376,152.666381835938 -4.45388889312744,152.678588867188 -4.44555473327637,152.681365966797 -4.44138813018799,152.692199707031 -4.39361190795898,152.69775390625 -4.36499977111816,152.69775390625 -4.35805511474609,152.694427490234 -4.19138813018799,152.693572998047 -4.18527698516846,152.691650390625 -4.18055534362793,152.603302001953 -4.00611114501953,152.581909179688 -3.96583318710327,152.538726806641 -3.90009546279907,152.512176513672 -3.8687310218811,152.491577148438 -3.85225462913513,152.374969482422 -3.7277774810791,152.359954833984 -3.70472240447998,152.357177734375 -3.69361114501953,152.356628417969 -3.6875,152.358001708984 -3.66166639328003,152.355224609375 -3.65055561065674,152.349700927734 -3.64249992370605,152.289428710938 -3.57944440841675,152.282470703125 -3.57277774810791,152.190521240234 -3.50888919830322,152.182464599609 -3.50361156463623,152.156372070312 -3.48861122131348,152.151641845703 -3.48638868331909,152.146087646484 -3.4850001335144,152.136657714844 -3.48916673660278,152.131072998047 -3.49055576324463,152.124969482422 -3.49000024795532,151.984405517578 -3.46444463729858,151.956359863281 -3.45833349227905,151.934967041016 -3.44555521011353,151.758331298828 -3.32444477081299,151.708862304688 -3.28055572509766,151.688293457031 -3.25305557250977,151.620513916016 -3.17722225189209,151.6171875 -3.17388916015625,151.608306884766 -3.16916656494141,151.574676513672 -3.1594443321228,151.532745361328 -3.14499998092651,151.493011474609 -3.13000011444092,151.483581542969 -3.12583303451538,151.462188720703 -3.11305570602417,151.455535888672 -3.1061110496521,151.452758789062 -3.10194444656372,151.450531005859 -3.09722232818604,151.449981689453 -3.08416652679443,151.448577880859 -3.07888889312744,151.44384765625 -3.06972217559814,151.438293457031 -3.06361103057861,151.417205810547 -3.05055570602417,151.369689941406 -3.02250003814697,151.281372070312 -2.97416639328003,151.237457275391 -2.95361137390137,151.214965820312 -2.94194412231445,151.150543212891 -2.89527797698975,151.122467041016 -2.86861085891724,151.119689941406 -2.86444473266602,151.113586425781 -2.8502779006958,151.110778808594 -2.84611082077026,151.106628417969 -2.84333324432373,151.004425048828 -2.78916692733765,150.999694824219 -2.78722238540649,150.930541992188 -2.76861095428467,150.923583984375 -2.76861095428467,150.903045654297 -2.77138900756836,150.876342773438 -2.77611112594604,150.861907958984 -2.78249979019165,150.832458496094 -2.78722238540649,150.819427490234 -2.7877779006958,150.754425048828 -2.77083349227905,150.750274658203 -2.76805543899536,150.729675292969 -2.74055576324463,150.730529785156 -2.7344446182251,150.733856201172 -2.7311110496521,150.747467041016 -2.71749973297119,150.752471923828 -2.71527767181396,150.763305664062 -2.7180552482605,150.824401855469 -2.71527767181396,150.874969482422 -2.71250009536743,150.88720703125 -2.71111106872559,150.891357421875 -2.70833349227905,150.894989013672 -2.70499992370605,150.896942138672 -2.70027780532837,150.885650634766 -2.6851110458374,150.884307861328 -2.67811107635498,150.876983642578 -2.65594434738159,150.875640869141 -2.65294456481934,150.873641967773 -2.65094447135925,150.867797851562 -2.64844417572021,150.861633300781 -2.64977788925171,150.856292724609 -2.65261125564575,150.853134155273 -2.65344452857971,150.838012695312 -2.64277791976929,150.831909179688 -2.64222240447998,150.822204589844 -2.6380558013916,150.792755126953 -2.61666631698608,150.805816650391 -2.56666660308838,150.807739257812 -2.56333351135254,150.811370849609 -2.55999994277954,150.817474365234 -2.559166431427,150.834686279297 -2.57083368301392,150.838012695312 -2.57416677474976,150.906524658203 -2.63594436645508,150.964691162109 -2.68722200393677,150.968841552734 -2.69000005722046,151.086639404297 -2.75027799606323,151.190246582031 -2.82611131668091,151.280822753906 -2.87083339691162,151.311370849609 -2.86999988555908,151.419128417969 -2.89805555343628,151.427185058594 -2.9036111831665,151.464416503906 -2.93499994277954,151.598022460938 -3.02750015258789,151.641937255859 -3.04805564880371,151.717742919922 -3.11555576324463,151.72607421875 -3.12805557250977,151.815246582031 -3.19777774810791,151.820526123047 -3.1991662979126,151.825531005859 -3.1972222328186,151.833587646484 -3.19166660308838,151.855529785156 -3.18611097335815,151.861907958984 -3.18694448471069,151.921905517578 -3.20333337783813,151.948852539062 -3.21083354949951,152.055816650391 -3.24777793884277,152.054412841797 -3.26000022888184,152.054412841797 -3.27361106872559,152.057739257812 -3.28388929367065,152.164703369141 -3.41111087799072,152.204406738281 -3.45444440841675,152.210510253906 -3.46055555343628,152.238006591797 -3.47833299636841,152.252471923828 -3.4844446182251,152.277191162109 -3.49472236633301,152.306640625 -3.50638914108276,152.327178955078 -3.51999998092651,152.355224609375 -3.54000043869019,152.361907958984 -3.54666709899902,152.367462158203 -3.55499982833862,152.392211914062 -3.59861087799072,152.411926269531 -3.63361120223999,152.488006591797 -3.64916658401489,152.493011474609 -3.64861106872559,152.496917724609 -3.65138864517212,152.503051757812 -3.6588888168335,152.511383056641 -3.67111110687256,152.553314208984 -3.74583339691162,152.556640625 -3.756667137146,152.555816650391 -3.76944446563721,152.549713134766 -3.78388929367065,152.546356201172 -3.79416704177856,152.549133300781 -3.79833364486694,152.573852539062 -3.8216667175293,152.577758789062 -3.82444477081299,152.582733154297 -3.82638883590698,152.603302001953 -3.83305549621582,152.659423828125 -3.84277772903442)),((149.6640625 -10.3398141860962,149.639434814453 -10.3413887023926,149.572204589844 -10.3413887023926,149.566925048828 -10.3413887023926,149.536651611328 -10.361665725708,149.335784912109 -10.307222366333,149.224975585938 -10.2761116027832,149.186645507812 -10.2600002288818,149.176361083984 -10.2563896179199,149.161102294922 -10.2511119842529,149.139984130859 -10.2449989318848,149.093292236328 -10.2341651916504,149.049407958984 -10.2424983978271,149.03857421875 -10.2449989318848,148.993835449219 -10.2605571746826,148.981628417969 -10.268611907959,148.934967041016 -10.2672233581543,148.79443359375 -10.2391662597656,148.723297119141 -10.1869449615479,148.680267333984 -10.1494445800781,148.677459716797 -10.1533336639404,148.642486572266 -10.1863880157471,148.637481689453 -10.1883344650269,148.468292236328 -10.2038879394531,148.462738037109 -10.2038879394531,148.4033203125 -10.2005558013916,148.372467041016 -10.1919441223145,148.3369140625 -10.1797218322754,148.332733154297 -10.176944732666,148.327178955078 -10.1688899993896,148.322479248047 -10.1599998474121,148.314971923828 -10.1405563354492,148.312194824219 -10.1363887786865,148.3046875 -10.130277633667,148.157562255859 -10.0737085342407,148.154418945312 -10.0791664123535,148.150543212891 -10.0952777862549,148.148315429688 -10.0999984741211,148.115509033203 -10.1216659545898,148.10302734375 -10.1297206878662,148.0888671875 -10.1358337402344,148.083312988281 -10.1372222900391,148.055236816406 -10.1433334350586,147.999694824219 -10.1519451141357,147.952453613281 -10.1458339691162,147.940795898438 -10.1211109161377,147.923034667969 -10.0980548858643,147.872192382812 -10.0475006103516,147.86328125 -10.0427780151367,147.857727050781 -10.0427780151367,147.781097412109 -10.0508327484131,147.775543212891 -10.0522232055664,147.766082763672 -10.0561103820801,147.619964599609 -9.9908332824707,147.612457275391 -9.98472213745117,147.601348876953 -9.97527694702148,147.574127197266 -9.94833374023438,147.51025390625 -9.87861061096191,147.504150390625 -9.87138748168945,147.501373291016 -9.86722183227539,147.499389648438 -9.85583305358887,147.501373291016 -9.85111045837402,147.503601074219 -9.83944320678711,147.503601074219 -9.8125,147.499389648438 -9.79638862609863,147.490509033203 -9.77138900756836,147.48828125 -9.76666641235352,147.386932373047 -9.63555717468262,147.316375732422 -9.55527877807617,147.296600341797 -9.53412532806396,147.248565673828 -9.50583457946777,147.12939453125 -9.44361114501953,147.080001831055 -9.43415546417236,147.099975585938 -9.44972229003906,147.102752685547 -9.45388793945312,147.102752685547 -9.48361015319824,147.101348876953 -9.48888778686523,147.09912109375 -9.49110984802246,147.094421386719 -9.49305534362793,147.0888671875 -9.49166679382324,147.062194824219 -9.47333335876465,147.055236816406 -9.46666526794434,147.008026123047 -9.39833450317383,147.001922607422 -9.3841667175293,146.926635742188 -9.28277778625488,146.91748046875 -9.28750038146973,146.911376953125 -9.28694534301758,146.901092529297 -9.28333282470703,146.896942138672 -9.28083419799805,146.893585205078 -9.27722358703613,146.891662597656 -9.27250099182129,146.888885498047 -9.1833324432373,146.905044555664 -9.13727760314941,146.905868530273 -9.13410949707031,146.907043457031 -9.13127708435059,146.909881591797 -9.13077735900879,146.915374755859 -9.13361072540283,146.918548583984 -9.13444423675537,146.969696044922 -9.09138870239258,146.977172851562 -9.07444381713867,146.981353759766 -9.05944442749023,146.981048583984 -9.05097389221191,146.974395751953 -9.03388977050781,146.972473144531 -9.02916717529297,146.969116210938 -9.02833366394043,146.951080322266 -9.03388977050781,146.94580078125 -9.04194450378418,146.944427490234 -9.04722213745117,146.94580078125 -9.05277824401855,146.951904296875 -9.06027793884277,146.954681396484 -9.06833267211914,146.953308105469 -9.07361030578613,146.925262451172 -9.09999847412109,146.91748046875 -9.10610961914062,146.844604492188 -9.09577751159668,146.840911865234 -9.09627723693848,146.83757019043 -9.09544467926025,146.630523681641 -9.0302791595459,146.621612548828 -9.02555656433105,146.586639404297 -8.99916648864746,146.578308105469 -8.9869441986084,146.55859375 -8.9416675567627,146.545532226562 -8.90250015258789,146.546081542969 -8.89777946472168,146.555816650391 -8.85972213745117,146.559143066406 -8.85638809204102,146.567474365234 -8.8075008392334,146.541351318359 -8.76361274719238,146.517486572266 -8.72500038146973,146.441345214844 -8.62472152709961,146.431915283203 -8.61388778686523,146.419982910156 -8.60499954223633,146.403594970703 -8.59444427490234,146.379104614258 -8.58470821380615,146.372192382812 -8.57805633544922,146.351623535156 -8.55777740478516,146.318572998047 -8.50889015197754,146.275543212891 -8.44305610656738,146.269439697266 -8.42888832092285,146.268035888672 -8.42361068725586,146.263305664062 -8.38750076293945,146.264709472656 -8.37527656555176,146.264709472656 -8.36861038208008,146.262481689453 -8.35972213745117,146.243286132812 -8.29472351074219,146.238555908203 -8.28583335876465,146.229675292969 -8.27444458007812,146.218566894531 -8.26472282409668,146.111083984375 -8.16388893127441,146.110229492188 -8.13472366333008,146.089691162109 -8.09111022949219,145.998016357422 -8.05444526672363,145.987731933594 -8.05111122131348,145.930816650391 -8.04111099243164,145.918579101562 -8.03972244262695,145.898590087891 -8.03888893127441,145.880798339844 -8.04166793823242,145.835510253906 -8.02805709838867,145.797760009766 -8.00777816772461,145.786376953125 -7.99888896942139,145.718292236328 -7.96777820587158,145.649993896484 -7.9597225189209,145.630798339844 -7.94472217559814,145.616912841797 -7.93777751922607,145.528045654297 -7.93777751922607,145.502471923828 -7.9399995803833,145.484130859375 -7.94861030578613,145.465515136719 -7.95083332061768,145.443572998047 -7.94944381713867,145.432739257812 -7.94805526733398,145.422485351562 -7.94472217559814,145.244110107422 -7.86861038208008,145.19807434082 -7.82955169677734,145.182723999023 -7.81383991241455,145.168106079102 -7.81822443008423,145.162994384766 -7.82626342773438,145.164459228516 -7.83649444580078,145.161529541016 -7.84489870071411,145.155685424805 -7.84599494934082,145.044967651367 -7.82041692733765,144.995513916016 -7.81555557250977,144.879669189453 -7.78250026702881,144.844696044922 -7.75722312927246,144.838562011719 -7.74972152709961,144.840515136719 -7.74499988555908,144.850250244141 -7.74111080169678,144.871337890625 -7.70777797698975,144.873565673828 -7.7030553817749,144.874114990234 -7.69694423675537,144.874114990234 -7.6899995803833,144.862457275391 -7.61055564880371,144.844696044922 -7.60777759552002,144.833862304688 -7.67722225189209,144.831085205078 -7.68111133575439,144.824127197266 -7.68805503845215,144.819427490234 -7.6899995803833,144.787750244141 -7.69138813018799,144.783599853516 -7.69138813018799,144.599395751953 -7.6602783203125,144.588287353516 -7.65750026702881,144.584411621094 -7.65472221374512,144.552185058594 -7.6119441986084,144.547210693359 -7.60305500030518,144.547210693359 -7.5963888168335,144.545806884766 -7.57472229003906,144.536376953125 -7.52694511413574,144.534973144531 -7.52166652679443,144.530822753906 -7.51222229003906,144.525268554688 -7.5038890838623,144.520538330078 -7.50194454193115,144.514984130859 -7.50194454193115,144.51025390625 -7.5038890838623,144.508880615234 -7.50944519042969,144.508331298828 -7.61472225189209,144.508331298828 -7.62138843536377,144.424682617188 -7.53305530548096,144.418579101562 -7.52583312988281,144.410247802734 -7.52027797698975,144.406921386719 -7.51944446563721,144.412200927734 -7.56583309173584,144.435516357422 -7.68000030517578,144.467742919922 -7.74305534362793,144.395812988281 -7.75583362579346,144.378021240234 -7.75333404541016,144.363006591797 -7.74777793884277,144.358856201172 -7.74499988555908,144.356628417969 -7.74027729034424,144.354125976562 -7.72944450378418,144.354125976562 -7.72277736663818,144.356628417969 -7.70499992370605,144.359680175781 -7.69416618347168,144.360229492188 -7.68249988555908,144.319122314453 -7.62083339691162,144.315795898438 -7.61749935150146,144.310791015625 -7.61666584014893,144.260803222656 -7.63777828216553,144.250549316406 -7.65472221374512,144.243560791016 -7.66694450378418,144.255249023438 -7.73416614532471,144.263031005859 -7.74027729034424,144.272491455078 -7.76749992370605,144.271911621094 -7.77361106872559,144.268310546875 -7.77694511413574,144.224395751953 -7.79333305358887,144.219116210938 -7.79472255706787,144.213012695312 -7.79527759552002,144.147216796875 -7.77888870239258,144.121612548828 -7.77166652679443,143.911926269531 -7.69694423675537,143.899719238281 -7.68861103057861,143.848037719727 -7.63533353805542,143.838531494141 -7.62833404541016,143.829193115234 -7.61733341217041,143.822525024414 -7.60766696929932,143.812713623047 -7.58883380889893,143.810211181641 -7.58316707611084,143.806549072266 -7.57049989700317,143.773040771484 -7.51555633544922,143.768310546875 -7.506667137146,143.758605957031 -7.50250053405762,143.664825439453 -7.46764850616455,143.691345214844 -7.51222229003906,143.755126953125 -7.58950042724609,143.839416503906 -7.71527767181396,143.845520019531 -7.73611068725586,143.852447509766 -7.77027797698975,143.85302734375 -7.78305530548096,143.851898193359 -7.79527759552002,143.85302734375 -7.80749988555908,143.854400634766 -7.81305503845215,143.896362304688 -7.88027763366699,143.901641845703 -7.88833332061768,143.9580078125 -7.97862243652344,143.957183837891 -7.98472213745117,143.955230712891 -7.9894437789917,143.893585205078 -8.03694534301758,143.889434814453 -8.03972244262695,143.884704589844 -8.04166793823242,143.847747802734 -8.04583358764648,143.833862304688 -8.04583358764648,143.755249023438 -8.04111099243164,143.750274658203 -8.03888893127441,143.743560791016 -8.03222274780273,143.738006591797 -8.02416801452637,143.724395751953 -8.01055717468262,143.719421386719 -8.00833511352539,143.661376953125 -7.99138832092285,143.631896972656 -7.98666667938232,143.618835449219 -7.98611068725586,143.597473144531 -7.99222183227539,143.588562011719 -7.99694442749023,143.568908691406 -8.0041675567627,143.56575012207 -8.00483322143555,143.546081542969 -8.00638961791992,143.501647949219 -7.9961109161377,143.485778808594 -7.99138832092285,143.481628417969 -7.98888874053955,143.474975585938 -7.98194408416748,143.473571777344 -7.97305583953857,143.460510253906 -7.93861103057861,143.454406738281 -7.92416667938232,143.444122314453 -7.91333389282227,143.439971923828 -7.91055583953857,143.435241699219 -7.90861129760742,143.424133300781 -7.90722274780273,143.362457275391 -7.8997220993042,143.358306884766 -7.90250015258789,143.356903076172 -7.90805530548096,143.356903076172 -7.91333389282227,143.360504150391 -7.91694450378418,143.446624755859 -7.98055553436279,143.538635253906 -8.05216693878174,143.541458129883 -8.05333423614502,143.543975830078 -8.05500030517578,143.547958374023 -8.05900001525879,143.628295898438 -8.19361114501953,143.630523681641 -8.19833374023438,143.632446289062 -8.20999908447266,143.631896972656 -8.21611022949219,143.629669189453 -8.22749900817871,143.625518798828 -8.2369441986084,143.622192382812 -8.24055480957031,143.611907958984 -8.24388885498047,143.56884765625 -8.24722099304199,143.554962158203 -8.24722099304199,143.512481689453 -8.2458324432373,143.469421386719 -8.24527740478516,143.382446289062 -8.25,143.373565673828 -8.25055694580078,143.338562011719 -8.2538890838623,143.234954833984 -8.27500152587891,143.178039550781 -8.28666687011719,143.080810546875 -8.30833435058594,143.069976806641 -8.31083297729492,143.049407958984 -8.31777763366699,143.034149169922 -8.32305526733398,143.023864746094 -8.3266658782959,143 -8.33666610717773,142.991058349609 -8.34138870239258,142.979949951172 -8.34416580200195,142.973297119141 -8.34416580200195,142.967193603516 -8.3436107635498,142.961639404297 -8.34222221374512,142.94580078125 -8.33749961853027,142.941070556641 -8.33527755737305,142.908874511719 -8.31916618347168,142.882171630859 -8.30500030517578,142.865509033203 -8.29416656494141,142.845794677734 -8.28666687011719,142.799987792969 -8.27500152587891,142.776641845703 -8.27083396911621,142.696350097656 -8.26749992370605,142.654693603516 -8.27361106872559,142.638031005859 -8.27777862548828,142.595794677734 -8.29000091552734,142.575256347656 -8.29666709899902,142.565521240234 -8.30083274841309,142.548309326172 -8.31083297729492,142.540802001953 -8.31694412231445,142.533874511719 -8.32388877868652,142.529968261719 -8.3266658782959,142.521087646484 -8.33138847351074,142.511383056641 -8.33527755737305,142.505828857422 -8.33666610717773,142.485229492188 -8.33666610717773,142.466918945312 -8.33611106872559,142.442749023438 -8.33277702331543,142.437469482422 -8.33138847351074,142.427764892578 -8.32722282409668,142.419708251953 -8.32194519042969,142.411926269531 -8.31583404541016,142.403213500977 -8.28638935089111,142.396194458008 -8.26155567169189,142.395050048828 -8.25055599212646,142.394195556641 -8.23922157287598,142.39453125 -8.23155498504639,142.394195556641 -8.2278881072998,142.386657714844 -8.19361114501953,142.383880615234 -8.18972206115723,142.379943847656 -8.18694496154785,142.338562011719 -8.16638946533203,142.327758789062 -8.16388893127441,142.316925048828 -8.16388893127441,142.221618652344 -8.1733341217041,142.2119140625 -8.17722320556641,142.140808105469 -8.22222137451172,142.13720703125 -8.22555541992188,142.13525390625 -8.23027801513672,142.135803222656 -8.23638725280762,142.144714355469 -8.23916625976562,142.155822753906 -8.24055480957031,142.163879394531 -8.23638725280762,142.172210693359 -8.23083305358887,142.182464599609 -8.22083282470703,142.186645507812 -8.21805572509766,142.195526123047 -8.21333312988281,142.223571777344 -8.20027732849121,142.228302001953 -8.19833374023438,142.309143066406 -8.18083381652832,142.314147949219 -8.18000030517578,142.324401855469 -8.1833324432373,142.338012695312 -8.19027709960938,142.355224609375 -8.19916725158691,142.361358642578 -8.20638847351074,142.374572753906 -8.26111125946045,142.377410888672 -8.2746114730835,142.377075195312 -8.28644466400146,142.377410888672 -8.29327774047852,142.382446289062 -8.31916618347168,142.388031005859 -8.32722282409668,142.408599853516 -8.34749984741211,142.439422607422 -8.37138748168945,142.44970703125 -8.37472152709961,142.466918945312 -8.37805557250977,142.473022460938 -8.37888717651367,142.486633300781 -8.37888717651367,142.493011474609 -8.37805557250977,142.512756347656 -8.37194442749023,142.522491455078 -8.36805534362793,142.5263671875 -8.36527633666992,142.540252685547 -8.35166549682617,142.548309326172 -8.34611129760742,142.556640625 -8.34083366394043,142.590240478516 -8.3266658782959,142.619689941406 -8.31500053405762,142.635528564453 -8.31027793884277,142.641662597656 -8.31083297729492,142.734680175781 -8.32250022888184,142.771636962891 -8.33194351196289,142.776641845703 -8.33388900756836,142.783325195312 -8.34083366394043,142.788879394531 -8.3488883972168,142.799133300781 -8.35916519165039,142.807464599609 -8.36444473266602,142.906097412109 -8.42361068725586,142.917205810547 -8.42611122131348,142.9580078125 -8.43166732788086,143.01025390625 -8.44111061096191,143.04443359375 -8.44777870178223,143.049987792969 -8.44916725158691,143.086364746094 -8.45999908447266,143.096618652344 -8.4636116027832,143.110229492188 -8.47027778625488,143.213012695312 -8.5494441986084,143.220520019531 -8.55555534362793,143.239135742188 -8.57138824462891,143.246063232422 -8.57805633544922,143.249389648438 -8.58138847351074,143.281646728516 -8.61861038208008,143.374664306641 -8.741943359375,143.392761230469 -8.77027893066406,143.395263671875 -8.7813892364502,143.406921386719 -8.96194458007812,143.405548095703 -8.96749877929688,143.403045654297 -8.97138786315918,143.384429931641 -8.99388885498047,143.3671875 -9.01083374023438,143.363006591797 -9.01361274719238,143.331634521484 -9.02833366394043,143.321899414062 -9.03250122070312,143.316650390625 -9.03388977050781,143.310241699219 -9.03305625915527,143.299407958984 -9.02361106872559,143.289154052734 -9.02027893066406,143.283050537109 -9.01972198486328,143.269989013672 -9.02027893066406,143.248016357422 -9.02555656433105,143.232177734375 -9.0302791595459,143.174133300781 -9.04861068725586,143.047210693359 -9.09000015258789,143.04248046875 -9.09194374084473,143.039154052734 -9.09527778625488,143.030822753906 -9.10750007629395,143.023864746094 -9.11416625976562,142.902770996094 -9.19750022888184,142.842468261719 -9.2327766418457,142.807464599609 -9.25222396850586,142.797760009766 -9.25638961791992,142.788299560547 -9.26027870178223,142.769134521484 -9.2672233581543,142.752471923828 -9.27138900756836,142.723846435547 -9.28333282470703,142.66552734375 -9.32055473327637,142.654693603516 -9.32999992370605,142.638885498047 -9.3347225189209,142.625244140625 -9.3347225189209,142.582733154297 -9.33083343505859,142.571624755859 -9.32805633544922,142.543029785156 -9.30916595458984,142.532470703125 -9.29888916015625,142.5244140625 -9.28694534301758,142.521087646484 -9.28333282470703,142.517486572266 -9.28000068664551,142.497741699219 -9.26527786254883,142.477172851562 -9.25166702270508,142.425811767578 -9.22805595397949,142.2099609375 -9.16500091552734,142.203033447266 -9.16500091552734,142.054412841797 -9.18722152709961,141.944702148438 -9.20694351196289,141.721343994141 -9.21444511413574,141.615783691406 -9.23611068725586,141.608856201172 -9.23611068725586,141.522491455078 -9.22111129760742,141.509429931641 -9.21388816833496,141.501922607422 -9.20777702331543,141.495788574219 -9.20027732849121,141.48828125 -9.19416618347168,141.460784912109 -9.17388916015625,141.448577880859 -9.16583442687988,141.429412841797 -9.15750122070312,141.388305664062 -9.14416694641113,141.375244140625 -9.14333343505859,141.323028564453 -9.14999961853027,141.312194824219 -9.15277862548828,141.307464599609 -9.15500068664551,141.294982910156 -9.16305541992188,141.284698486328 -9.17305564880371,141.266387939453 -9.18888854980469,141.226623535156 -9.21722221374512,141.213592529297 -9.22472190856934,141.176361083984 -9.23388862609863,141.160797119141 -9.23749923706055,141.122467041016 -9.23194313049316,141.117462158203 -9.22999954223633,141.109405517578 -9.22472190856934,141.090789794922 -9.20916557312012,141.033874511719 -9.15694427490234,141.013305664062 -9.13666725158691,141.007019042969 -9.12846755981445,141.006134033203 -6.90478563308716,141.006134033203 -6.89328384399414,140.998565673828 -6.89388942718506,140.990509033203 -6.89944458007812,140.983581542969 -6.9061107635498,140.978851318359 -6.90694427490234,140.949401855469 -6.9036111831665,140.902770996094 -6.85583305358887,140.875244140625 -6.79611110687256,140.871063232422 -6.7863883972168,140.859405517578 -6.72861099243164,140.858856201172 -6.6783332824707,140.863006591797 -6.63138866424561,140.891082763672 -6.60333347320557,140.895263671875 -6.60055541992188,140.898040771484 -6.59666728973389,140.947204589844 -6.5,140.951354980469 -6.48361110687256,140.950805664062 -6.47749996185303,140.948577880859 -6.47277736663818,140.94580078125 -6.4686107635498,140.928039550781 -6.45083332061768,140.932189941406 -6.43444442749023,140.963592529297 -6.3386116027832,140.967742919922 -6.33583354949951,140.973297119141 -6.33444499969482,140.985504150391 -6.33305549621582,141.006134033203 -6.33292484283447,141.006103515625 -6,141.006103515625 -4.90555477142334,141.006103515625 -2.61388921737671,141.002471923828 -2.60708522796631,141.029968261719 -2.59277772903442,141.034698486328 -2.59083318710327,141.039428710938 -2.59000015258789,141.046356201172 -2.59000015258789,141.199127197266 -2.61805534362793,141.204681396484 -2.61944437026978,141.214141845703 -2.62222194671631,141.270538330078 -2.64555549621582,141.273864746094 -2.65583324432373,141.278045654297 -2.6652774810791,141.284149169922 -2.67277765274048,141.345794677734 -2.70777797698975,141.369689941406 -2.7180552482605,141.380798339844 -2.72083330154419,141.410797119141 -2.72499990463257,141.426635742188 -2.72972202301025,141.436370849609 -2.73388910293579,141.568572998047 -2.79388904571533,141.608856201172 -2.8125,141.704132080078 -2.86250019073486,141.840515136719 -2.93694448471069,141.881622314453 -2.96444463729858,141.889984130859 -2.96999979019165,141.894714355469 -2.9719443321228,141.913879394531 -2.9719443321228,141.931091308594 -2.9686107635498,141.935791015625 -2.96638870239258,141.962463378906 -2.95888900756836,141.973571777344 -2.95611095428467,141.991912841797 -2.95416688919067,142.003601074219 -2.95611095428467,142.011932373047 -2.96166658401489,142.066070556641 -3.00833368301392,142.076904296875 -3.01777791976929,142.077758789062 -3.02055549621582,142.124969482422 -3.05944442749023,142.252471923828 -3.10472249984741,142.551910400391 -3.21833324432373,142.663604736328 -3.24777793884277,142.946624755859 -3.33249998092651,142.992462158203 -3.34833335876465,143.032745361328 -3.36277770996094,143.041076660156 -3.36416673660278,143.073181152344 -3.36020636558533,143.087738037109 -3.35583353042603,143.093841552734 -3.35500001907349,143.106079101562 -3.35388898849487,143.123840332031 -3.35388898849487,143.172760009766 -3.35722255706787,143.194702148438 -3.3600001335144,143.209686279297 -3.3652777671814,143.2138671875 -3.36805534362793,143.229400634766 -3.37972211837769,143.23828125 -3.38444471359253,143.255554199219 -3.3880558013916,143.336364746094 -3.40166664123535,143.346069335938 -3.40166664123535,143.370788574219 -3.40166664123535,143.384429931641 -3.40305519104004,143.408325195312 -3.40638875961304,143.442749023438 -3.41194438934326,143.516082763672 -3.43444442749023,143.520812988281 -3.43666648864746,143.529144287109 -3.44194412231445,143.536651611328 -3.44805526733398,143.569427490234 -3.47555541992188,143.598846435547 -3.51444482803345,143.602172851562 -3.5247220993042,143.605804443359 -3.54194450378418,143.609130859375 -3.54527807235718,143.61328125 -3.54805564880371,143.648864746094 -3.56722259521484,143.731079101562 -3.60416698455811,143.768310546875 -3.61083364486694,143.790802001953 -3.61083364486694,143.794982910156 -3.61222219467163,143.798858642578 -3.61500024795532,143.949127197266 -3.73333311080933,143.955230712891 -3.73944425582886,143.9580078125 -3.74361133575439,143.964691162109 -3.7572226524353,143.966064453125 -3.76277780532837,143.976348876953 -3.77972221374512,143.981903076172 -3.78805589675903,143.988861083984 -3.79500007629395,143.993011474609 -3.79777812957764,144.016937255859 -3.81055545806885,144.243011474609 -3.87277746200562,144.249114990234 -3.87361097335815,144.253875732422 -3.87138891220093,144.255249023438 -3.86611127853394,144.253875732422 -3.86194467544556,144.253875732422 -3.85500001907349,144.258026123047 -3.84555530548096,144.275268554688 -3.809166431427,144.278594970703 -3.80583333969116,144.284973144531 -3.80527782440186,144.338287353516 -3.80249977111816,144.375244140625 -3.80249977111816,144.511657714844 -3.82083368301392,144.515808105469 -3.82361125946045,144.532196044922 -3.84611082077026,144.534973144531 -3.8502779006958,144.549987792969 -3.87611103057861,144.552185058594 -3.88111114501953,144.547210693359 -3.8938889503479,144.545257568359 -3.90416669845581,144.54248046875 -3.93444442749023,144.543853759766 -3.95361137390137,144.547210693359 -3.96388912200928,144.551361083984 -3.9719443321228,144.571350097656 -3.99194431304932,144.591064453125 -4.00611114501953,144.608306884766 -4.0130558013916,144.613861083984 -4.01444530487061,144.653594970703 -4.0130558013916,144.673309326172 -4.01361179351807,144.678863525391 -4.01500034332275,144.729675292969 -4.0313892364502,144.766662597656 -4.04638862609863,144.850250244141 -4.09305572509766,144.858306884766 -4.09833335876465,144.876342773438 -4.11361122131348,144.978302001953 -4.22277736663818,144.981628417969 -4.22638893127441,144.986633300781 -4.23499965667725,144.991333007812 -4.24388885498047,144.994689941406 -4.25277805328369,144.996063232422 -4.26250076293945,145.004974365234 -4.28166675567627,145.033050537109 -4.33555603027344,145.036651611328 -4.33888912200928,145.054962158203 -4.35194396972656,145.089965820312 -4.37166595458984,145.094696044922 -4.37388896942139,145.157196044922 -4.38277721405029,145.228576660156 -4.3880558013916,145.253051757812 -4.37861061096191,145.293579101562 -4.37666606903076,145.305236816406 -4.37722206115723,145.333862304688 -4.38944435119629,145.338012695312 -4.39222240447998,145.451080322266 -4.49416637420654,145.459411621094 -4.50444507598877,145.527191162109 -4.59249973297119,145.614135742188 -4.70027828216553,145.620513916016 -4.70777797698975,145.675811767578 -4.76194477081299,145.679412841797 -4.76527786254883,145.69384765625 -4.77694511413574,145.735504150391 -4.80277729034424,145.780822753906 -4.92777729034424,145.813598632812 -5.06555557250977,145.813598632812 -5.07250022888184,145.786926269531 -5.23138904571533,145.765808105469 -5.26361179351807,145.738861083984 -5.30527782440186,145.724395751953 -5.41222190856934,145.723846435547 -5.42527770996094,145.725250244141 -5.430832862854,145.734130859375 -5.4491662979126,145.747741699219 -5.46972179412842,145.754699707031 -5.47638893127441,145.766387939453 -5.48527717590332,145.782745361328 -5.4894437789917,145.787750244141 -5.48999977111816,145.793029785156 -5.48999977111816,145.872467041016 -5.48611068725586,145.930816650391 -5.47722244262695,145.935516357422 -5.47638893127441,145.963592529297 -5.47305583953857,145.976623535156 -5.47638893127441,146.082183837891 -5.51250076293945,146.174682617188 -5.55138874053955,146.194702148438 -5.55888843536377,146.289154052734 -5.58888912200928,146.376342773438 -5.59916687011719,146.439971923828 -5.59861087799072,146.445526123047 -5.59861087799072,146.465240478516 -5.60472202301025,146.47021484375 -5.60666751861572,146.474090576172 -5.60944557189941,146.531188964844 -5.65468120574951,146.580535888672 -5.69472217559814,146.605224609375 -5.71777820587158,146.640808105469 -5.74388885498047,146.653045654297 -5.75194454193115,146.662750244141 -5.75611114501953,146.688873291016 -5.76416683197021,146.714691162109 -5.76972198486328,146.770782470703 -5.79138946533203,146.775787353516 -5.79361248016357,146.783843994141 -5.79889011383057,146.786071777344 -5.80388927459717,146.796310424805 -5.83441781997681,146.875213623047 -5.82555675506592,146.894958496094 -5.82888984680176,146.923004150391 -5.84194564819336,146.930511474609 -5.84805679321289,146.946319580078 -5.86638927459717,146.953826904297 -5.88611221313477,146.956604003906 -5.89027881622314,146.962707519531 -5.897780418396,146.992156982422 -5.91611289978027,147.014129638672 -5.92833518981934,147.041625976562 -5.94222354888916,147.046325683594 -5.94416904449463,147.102722167969 -5.96611404418945,147.112152099609 -5.96667003631592,147.228820800781 -5.97223472595215,147.234924316406 -5.97140216827393,147.24658203125 -5.96251487731934,147.269683837891 -5.93807125091553,147.274658203125 -5.93612670898438,147.284942626953 -5.93529415130615,147.423278808594 -5.96058177947998,147.466613769531 -5.97085952758789,147.476867675781 -5.97419261932373,147.484375 -5.98030376434326,147.573303222656 -6.05527782440186,147.590515136719 -6.07222270965576,147.641937255859 -6.13694477081299,147.786651611328 -6.30249977111816,147.826354980469 -6.3372220993042,147.830261230469 -6.34694480895996,147.850250244141 -6.41166687011719,147.863861083984 -6.45916652679443,147.866638183594 -6.47000026702881,147.869964599609 -6.65472221374512,147.869415283203 -6.66083335876465,147.866058349609 -6.67083358764648,147.845520019531 -6.69138813018799,147.838562011719 -6.69805526733398,147.819427490234 -6.71305561065674,147.810516357422 -6.71777820587158,147.770812988281 -6.72611141204834,147.759155273438 -6.72805595397949,147.568023681641 -6.75194454193115,147.416381835938 -6.73499965667725,147.305541992188 -6.74583339691162,147.219696044922 -6.74638843536377,147.199981689453 -6.74583339691162,147.188873291016 -6.74305534362793,147.180816650391 -6.74027729034424,147.174682617188 -6.73555564880371,147.166381835938 -6.72333335876465,147.160247802734 -6.71722221374512,147.149993896484 -6.71388912200928,147.0888671875 -6.71444511413574,146.971069335938 -6.74305534362793,146.961364746094 -6.74722194671631,146.948577880859 -6.79805564880371,146.944976806641 -6.81527709960938,146.943023681641 -6.84027767181396,146.941650390625 -6.90444469451904,146.944976806641 -6.95388889312744,146.946350097656 -6.95944499969482,146.948577880859 -6.96416664123535,146.955230712891 -6.97111129760742,147.0244140625 -7.03694438934326,147.037475585938 -7.04444408416748,147.130798339844 -7.20361137390137,147.140258789062 -7.22111129760742,147.144439697266 -7.23083305358887,147.146362304688 -7.24916648864746,147.145812988281 -7.26194477081299,147.141662597656 -7.27166652679443,147.140258789062 -7.27694511413574,147.137481689453 -7.29472255706787,147.139709472656 -7.32527828216553,147.1533203125 -7.38305473327637,147.154693603516 -7.38861179351807,147.178588867188 -7.46388912200928,147.210784912109 -7.49027729034424,147.216369628906 -7.49166679382324,147.297210693359 -7.5038890838623,147.303314208984 -7.50472259521484,147.320526123047 -7.50527858734131,147.332183837891 -7.50333404541016,147.3369140625 -7.50527858734131,147.418579101562 -7.56722259521484,147.457733154297 -7.5977783203125,147.641357421875 -7.77555561065674,147.666656494141 -7.79111099243164,147.670806884766 -7.79388904571533,147.693298339844 -7.82583332061768,147.696075439453 -7.83527755737305,147.701629638672 -7.87055492401123,147.701629638672 -7.8841667175293,147.700805664062 -7.89027786254883,147.701629638672 -7.90333366394043,147.703033447266 -7.90861129760742,147.710510253906 -7.92166614532471,147.715240478516 -7.92916679382324,147.718566894531 -7.93249988555908,147.731628417969 -7.9399995803833,147.741333007812 -7.94388866424561,147.756927490234 -7.94861030578613,147.776916503906 -7.93638801574707,147.782470703125 -7.93527698516846,147.804412841797 -7.93527698516846,147.854949951172 -7.93527698516846,147.866638183594 -7.93722152709961,147.876342773438 -7.94111061096191,147.888031005859 -7.94999980926514,147.911926269531 -7.96722221374512,147.935791015625 -7.98277759552002,147.939422607422 -7.98472213745117,147.974395751953 -7.99610900878906,147.979675292969 -8.03694534301758,147.982452392578 -8.04777908325195,147.985229492188 -8.05194473266602,147.9921875 -8.0586109161377,148.004425048828 -8.06666564941406,148.009979248047 -8.06666564941406,148.0263671875 -8.06277847290039,148.114685058594 -8.05527877807617,148.13525390625 -8.06611061096191,148.194976806641 -8.25194549560547,148.19970703125 -8.26749992370605,148.205810546875 -8.29527854919434,148.206634521484 -8.30138969421387,148.207183837891 -8.31083297729492,148.207183837891 -8.32055473327637,148.206634521484 -8.34000015258789,148.210784912109 -8.39305686950684,148.220245361328 -8.51027870178223,148.222198486328 -8.53388977050781,148.230529785156 -8.55972290039062,148.235229492188 -8.56861114501953,148.2421875 -8.57527732849121,148.271087646484 -8.59444427490234,148.300537109375 -8.61138916015625,148.318298339844 -8.60861015319824,148.327178955078 -8.60638809204102,148.331359863281 -8.60638809204102,148.347198486328 -8.61138916015625,148.351898193359 -8.61333274841309,148.376617431641 -8.62944412231445,148.443023681641 -8.67500114440918,148.44580078125 -8.67888832092285,148.478576660156 -8.73305511474609,148.479949951172 -8.73861122131348,148.479949951172 -8.75889015197754,148.489685058594 -8.84027671813965,148.494415283203 -8.86666488647461,148.530822753906 -8.99305534362793,148.534698486328 -9.00277900695801,148.536926269531 -9.00750160217285,148.5888671875 -9.07027816772461,148.604125976562 -9.08250045776367,148.614410400391 -9.0858325958252,148.695251464844 -9.10222244262695,148.719970703125 -9.10472106933594,148.725250244141 -9.10472106933594,148.753601074219 -9.10416603088379,148.782196044922 -9.10138893127441,148.842468261719 -9.09055519104004,149.067199707031 -9.04111099243164,149.071350097656 -9.03861236572266,149.137756347656 -9.00666809082031,149.221343994141 -8.99860954284668,149.255828857422 -8.99777793884277,149.259979248047 -8.99916648864746,149.309967041016 -9.01694488525391,149.314697265625 -9.01889038085938,149.316650390625 -9.02166748046875,149.322204589844 -9.03777885437012,149.338012695312 -9.12972068786621,149.328308105469 -9.15277862548828,149.325531005859 -9.15694427490234,149.316070556641 -9.16777801513672,149.311920166016 -9.17055511474609,149.291351318359 -9.18388938903809,149.181640625 -9.34916687011719,149.1796875 -9.35361099243164,149.178863525391 -9.35972213745117,149.178863525391 -9.37333297729492,149.181091308594 -9.38500022888184,149.184417724609 -9.39500045776367,149.208312988281 -9.45249938964844,149.219970703125 -9.47472190856934,149.227752685547 -9.48749923706055,149.231079101562 -9.49110984802246,149.234405517578 -9.49444389343262,149.243286132812 -9.49916648864746,149.266662597656 -9.51000022888184,149.271636962891 -9.5119457244873,149.2783203125 -9.5119457244873,149.28857421875 -9.50861167907715,149.301635742188 -9.50777816772461,149.307189941406 -9.5091667175293,149.348846435547 -9.52194595336914,149.437469482422 -9.57138824462891,149.439422607422 -9.59111022949219,149.440795898438 -9.59638786315918,149.444122314453 -9.59972190856934,149.454406738281 -9.60305404663086,149.662200927734 -9.60722160339355,149.739410400391 -9.60166549682617,149.746337890625 -9.60166549682617,149.758026123047 -9.6038875579834,149.764984130859 -9.60916519165039,149.771087646484 -9.61666488647461,149.775268554688 -9.61944389343262,149.780548095703 -9.6208324432373,149.874389648438 -9.6422233581543,149.880798339844 -9.64305686950684,149.9033203125 -9.64361190795898,149.910247802734 -9.64361190795898,149.94580078125 -9.6422233581543,149.956634521484 -9.63972282409668,149.960784912109 -9.6369457244873,149.982727050781 -9.63138771057129,150.008880615234 -9.63138771057129,150.049133300781 -9.67944526672363,150.051361083984 -9.68416595458984,150.053314208984 -9.68888854980469,150.056915283203 -9.70999908447266,150.056915283203 -9.71527671813965,150.055541992188 -9.72055435180664,150.051910400391 -9.72416687011719,149.988861083984 -9.75111198425293,149.926635742188 -9.76944541931152,149.863586425781 -9.78222274780273,149.857452392578 -9.78277778625488,149.852752685547 -9.78222274780273,149.841644287109 -9.77944564819336,149.835510253906 -9.77888870239258,149.808013916016 -9.7813892364502,149.769714355469 -9.7902774810791,149.764984130859 -9.79222297668457,149.739410400391 -9.80777740478516,149.727172851562 -9.81583404541016,149.720245361328 -9.82277679443359,149.717468261719 -9.8266658782959,149.716369628906 -9.83222198486328,149.717468261719 -9.83749961853027,149.721069335938 -9.84749984741211,149.723022460938 -9.85249900817871,149.76220703125 -9.90166664123535,149.873840332031 -10.0169448852539,149.914154052734 -10.0488891601562,149.926635742188 -10.0569438934326,149.935516357422 -10.0616655349731,149.982727050781 -10.081111907959,149.98828125 -10.0825004577637,149.994415283203 -10.0819444656372,150.003326416016 -10.0772228240967,150.013610839844 -10.0736103057861,150.019714355469 -10.073055267334,150.184143066406 -10.0933322906494,150.189147949219 -10.0952777862549,150.236358642578 -10.1283321380615,150.259704589844 -10.1527786254883,150.29052734375 -10.1830558776855,150.298583984375 -10.1883344650269,150.308319091797 -10.1924991607666,150.352752685547 -10.1999988555908,150.382171630859 -10.2047214508057,150.400268554688 -10.2072219848633,150.579681396484 -10.2411098480225,150.61328125 -10.2755565643311,150.618011474609 -10.2775001525879,150.63525390625 -10.280834197998,150.641357421875 -10.2813892364502,150.647491455078 -10.280834197998,150.775543212891 -10.2613906860352,150.780548095703 -10.2591667175293,150.803588867188 -10.2486095428467,150.815521240234 -10.2397212982178,150.81884765625 -10.2363872528076,150.824981689453 -10.2316665649414,150.829681396484 -10.2294454574585,150.844116210938 -10.2247219085693,150.862731933594 -10.2227764129639,150.869415283203 -10.2227764129639,150.877746582031 -10.2283334732056,150.878295898438 -10.2316665649414,150.870788574219 -10.2377777099609,150.861907958984 -10.2424983978271,150.727752685547 -10.3125,150.641937255859 -10.3494434356689,150.636383056641 -10.3508319854736,150.631072998047 -10.3508319854736,150.602172851562 -10.3502769470215,150.596069335938 -10.3494434356689,150.547485351562 -10.3355560302734,150.496063232422 -10.3186111450195,150.438568115234 -10.3036117553711,150.421905517578 -10.3011112213135,150.415802001953 -10.3002777099609,150.406372070312 -10.3044452667236,150.369110107422 -10.3219451904297,150.358306884766 -10.3313884735107,150.356353759766 -10.3361110687256,150.348571777344 -10.3758316040039,150.346618652344 -10.3875007629395,150.352172851562 -10.3952789306641,150.356903076172 -10.3975009918213,150.568572998047 -10.4627780914307,150.6494140625 -10.4755554199219,150.657745361328 -10.4811115264893,150.663299560547 -10.4891662597656,150.689971923828 -10.5502777099609,150.691925048828 -10.5550003051758,150.691345214844 -10.5611114501953,150.688568115234 -10.5652770996094,150.680267333984 -10.5774993896484,150.675537109375 -10.5794448852539,150.568023681641 -10.6219444274902,150.556365966797 -10.6238880157471,150.522766113281 -10.6191654205322,150.492736816406 -10.6191654205322,150.481628417969 -10.6219444274902,150.477447509766 -10.6244430541992,150.47412109375 -10.6277770996094,150.44384765625 -10.6588897705078,150.428314208984 -10.6877784729004,150.424133300781 -10.6905555725098,150.369964599609 -10.6872215270996,150.268585205078 -10.6886119842529,150.209686279297 -10.7005558013916,150.113006591797 -10.6674995422363,150.099975585938 -10.6575012207031,150.059417724609 -10.6258316040039,150.028045654297 -10.5894432067871,150.016937255859 -10.5733337402344,150.013031005859 -10.5705547332764,150.007476806641 -10.5691661834717,149.91552734375 -10.5577774047852,149.898590087891 -10.5597229003906,149.896362304688 -10.5625,149.893585205078 -10.5633344650269,149.888305664062 -10.5619449615479,149.862182617188 -10.5544452667236,149.852752685547 -10.5502777099609,149.850524902344 -10.5469455718994,149.875244140625 -10.5100002288818,149.878570556641 -10.5066680908203,149.883331298828 -10.5044460296631,149.901916503906 -10.5025005340576,149.942474365234 -10.5025005340576,149.964416503906 -10.5025005340576,149.968292236328 -10.5052795410156,149.971069335938 -10.5094451904297,149.97802734375 -10.5161113739014,149.989685058594 -10.5180568695068,150.016937255859 -10.5113906860352,150.022491455078 -10.5100002288818,150.031372070312 -10.5052795410156,150.039703369141 -10.5,150.078857421875 -10.4627780914307,150.064422607422 -10.4561100006104,149.990234375 -10.4372215270996,149.866363525391 -10.3980560302734,149.806091308594 -10.3677768707275,149.785522460938 -10.3583335876465,149.758026123047 -10.3461112976074,149.747741699219 -10.3427772521973,149.723846435547 -10.3394432067871,149.683868408203 -10.3380546569824,149.6640625 -10.3398141860962)),((152.004425048828 -2.67000007629395,151.972747802734 -2.66888904571533,151.961090087891 -2.66805553436279,151.957733154297 -2.66472196578979,151.955535888672 -2.65999984741211,151.953582763672 -2.64833354949951,151.954406738281 -2.64222240447998,151.958312988281 -2.63249969482422,151.972747802734 -2.60583353042603,151.979675292969 -2.59888887405396,151.983856201172 -2.59611082077026,151.995239257812 -2.59555530548096,152.000823974609 -2.5969443321228,152.010528564453 -2.60111141204834,152.018585205078 -2.60638904571533,152.022216796875 -2.6100001335144,152.035247802734 -2.63111114501953,152.037200927734 -2.63583326339722,152.038024902344 -2.64222240447998,152.029693603516 -2.66111087799072,152.026916503906 -2.6652774810791,152.022216796875 -2.66750001907349,152.004425048828 -2.67000007629395)),((151.959136962891 -2.84611082077026,151.946624755859 -2.84472227096558,151.941345214844 -2.84333324432373,151.937194824219 -2.8405556678772,151.931640625 -2.83249998092651,151.921905517578 -2.80777788162231,151.920806884766 -2.80222225189209,151.928863525391 -2.7186107635498,151.9296875 -2.71250009536743,151.932464599609 -2.70833349227905,151.939147949219 -2.70833349227905,151.944702148438 -2.70972204208374,151.985778808594 -2.72499990463257,151.989959716797 -2.72749996185303,151.996612548828 -2.7344446182251,152.006378173828 -2.74555540084839,152.009155273438 -2.74944448471069,152.009704589844 -2.75583362579346,152.011932373047 -2.79055595397949,152.011932373047 -2.81805562973022,152.009704589844 -2.82277774810791,152.002197265625 -2.82888889312744,151.959136962891 -2.84611082077026)),((152.063873291016 -3.00222253799438,152.059143066406 -3,152.035247802734 -2.98277759552002,152.0283203125 -2.97555541992188,151.960510253906 -2.88722229003906,151.959686279297 -2.8808331489563,151.959686279297 -2.86861085891724,151.960510253906 -2.86250019073486,151.963287353516 -2.85833358764648,151.973571777344 -2.84805536270142,151.978302001953 -2.84611082077026,151.984954833984 -2.84611082077026,152.072204589844 -2.92138910293579,152.078857421875 -2.9283332824707,152.083862304688 -2.93694448471069,152.087188720703 -2.9472222328186,152.089141845703 -2.95888900756836,152.088562011719 -2.96527767181396,152.086639404297 -2.96999979019165,152.073577880859 -2.99805545806885,152.069976806641 -3.00138902664185,152.063873291016 -3.00222253799438)),((150.773590087891 -2.98555564880371,150.768035888672 -2.9844446182251,150.766082763672 -2.97944402694702,150.773040771484 -2.97249984741211,150.788024902344 -2.96027803421021,150.795532226562 -2.95416688919067,150.870788574219 -2.91249990463257,150.879119873047 -2.9088888168335,150.903045654297 -2.90833330154419,150.908599853516 -2.90833330154419,150.913299560547 -2.91027784347534,150.941345214844 -2.9219446182251,151.021087646484 -2.96305561065674,151.023590087891 -2.96722221374512,151.021636962891 -2.9719443321228,151.003875732422 -2.98166656494141,150.999114990234 -2.98361110687256,150.992736816406 -2.9844446182251,150.882446289062 -2.9686107635498,150.872192382812 -2.96527767181396,150.855804443359 -2.9622220993042,150.838012695312 -2.95972204208374,150.831909179688 -2.96027803421021,150.773590087891 -2.98555564880371)),((152.640808105469 -3.23000001907349,152.636108398438 -3.2277774810791,152.605224609375 -3.20388889312744,152.577178955078 -3.17722225189209,152.538879394531 -3.1061110496521,152.537475585938 -3.10055589675903,152.537475585938 -3.09499979019165,152.539428710938 -3.09027767181396,152.553863525391 -3.07055568695068,152.558013916016 -3.06777811050415,152.590240478516 -3.05194425582886,152.599700927734 -3.04805564880371,152.606079101562 -3.04722261428833,152.640258789062 -3.04305553436279,152.644989013672 -3.04527807235718,152.648590087891 -3.04861116409302,152.667755126953 -3.12944412231445,152.668853759766 -3.14861106872559,152.668853759766 -3.15527772903442,152.667755126953 -3.16083335876465,152.654693603516 -3.21638870239258,152.6533203125 -3.22166633605957,152.646362304688 -3.22861099243164,152.640808105469 -3.23000001907349)),((153.343292236328 -3.41666650772095,153.265258789062 -3.40722227096558,153.262481689453 -3.40444421768188,153.263885498047 -3.39888906478882,153.269989013672 -3.39277791976929,153.301635742188 -3.36944437026978,153.333587646484 -3.37138891220093,153.337188720703 -3.375,153.346069335938 -3.38666677474976,153.348022460938 -3.39138889312744,153.347473144531 -3.39750003814697,153.345245361328 -3.41194438934326,153.343292236328 -3.41666650772095)),((154.818572998047 -3.53027772903442,154.795257568359 -3.44138860702515,154.794708251953 -3.43249988555908,154.796081542969 -3.4283332824707,154.799407958984 -3.42500019073486,154.825531005859 -3.4713888168335,154.830261230469 -3.48027753829956,154.833862304688 -3.50416707992554,154.833038330078 -3.51027822494507,154.818572998047 -3.53027772903442)),((153.242462158203 -3.49944448471069,153.237182617188 -3.49805545806885,153.211090087891 -3.48861122131348,153.206909179688 -3.48583316802979,153.192474365234 -3.47277736663818,153.19384765625 -3.4686107635498,153.197204589844 -3.46527767181396,153.220520019531 -3.44888877868652,153.22412109375 -3.4466667175293,153.22802734375 -3.44555521011353,153.233581542969 -3.4466667175293,153.239959716797 -3.45444440841675,153.255554199219 -3.47972202301025,153.259704589844 -3.48916673660278,153.26025390625 -3.49527788162231,153.258331298828 -3.49888896942139,153.242462158203 -3.49944448471069)),((153.639434814453 -4.14083385467529,153.634429931641 -4.13861179351807,153.588012695312 -4.10583305358887,153.585235595703 -4.10194396972656,153.584411621094 -4.09583377838135,153.585235595703 -4.08944416046143,153.587188720703 -4.0847225189209,153.602172851562 -4.05888843536377,153.629669189453 -4.0313892364502,153.633880615234 -4.0286111831665,153.653045654297 -4.02055549621582,153.658599853516 -4.01916694641113,153.662750244141 -4.02194499969482,153.664703369141 -4.02666664123535,153.671630859375 -4.08000087738037,153.672210693359 -4.08611106872559,153.671630859375 -4.10472202301025,153.670257568359 -4.10999965667725,153.650268554688 -4.1380558013916,153.645538330078 -4.14027786254883,153.639434814453 -4.14083385467529)),((145.057739257812 -4.13527774810791,145.050811767578 -4.13527774810791,145.041351318359 -4.13249969482422,145.037200927734 -4.13000011444092,145.031646728516 -4.12166595458984,145.027770996094 -4.11222171783447,145.0263671875 -4.10666656494141,145.022216796875 -4.07666683197021,145.0263671875 -4.06694507598877,145.031646728516 -4.05888843536377,145.036651611328 -4.05666637420654,145.06884765625 -4.04500007629395,145.079132080078 -4.04777812957764,145.095520019531 -4.05888843536377,145.101623535156 -4.06638813018799,145.107177734375 -4.07527828216553,145.110504150391 -4.09222221374512,145.109954833984 -4.09833335876465,145.094696044922 -4.12444400787354,145.092193603516 -4.12833309173584,145.088012695312 -4.13138866424561,145.083312988281 -4.13333320617676,145.057739257812 -4.13527774810791)),((150.74609375 -6.13554954528809,150.729675292969 -6.14666748046875,150.724975585938 -6.14861106872559,150.707183837891 -6.15555572509766,150.668853759766 -6.16833305358887,150.663879394531 -6.16916656494141,150.661102294922 -6.16499996185303,150.659149169922 -6.15333366394043,150.657196044922 -6.14861106872559,150.652191162109 -6.14666748046875,150.63525390625 -6.14861106872559,150.509704589844 -6.23499965667725,150.484954833984 -6.25833415985107,150.480255126953 -6.26722240447998,150.473571777344 -6.27388954162598,150.468566894531 -6.2761116027832,150.406372070312 -6.29305553436279,150.400268554688 -6.29361152648926,150.222747802734 -6.28833293914795,150.211639404297 -6.2761116027832,150.188293457031 -6.25833415985107,150.184143066406 -6.25555610656738,150.180816650391 -6.25500011444092,150.170532226562 -6.25694465637207,150.080810546875 -6.28000068664551,150.038879394531 -6.29916667938232,150.018310546875 -6.32361125946045,150.016387939453 -6.30388832092285,150.014434814453 -6.29916667938232,150.010803222656 -6.29583358764648,149.98828125 -6.27722263336182,149.984130859375 -6.2747220993042,149.978576660156 -6.27333354949951,149.972473144531 -6.27388954162598,149.894989013672 -6.29249954223633,149.889709472656 -6.29249954223633,149.847198486328 -6.29249954223633,149.844421386719 -6.29249954223633,149.842193603516 -6.29249954223633,149.686645507812 -6.30527782440186,149.634704589844 -6.30805492401123,149.609405517578 -6.29249954223633,149.605224609375 -6.28972244262695,149.574981689453 -6.26500034332275,149.571624755859 -6.26166725158691,149.555236816406 -6.22694492340088,149.539428710938 -6.19777774810791,149.510803222656 -6.15277767181396,149.489410400391 -6.12611103057861,149.482452392578 -6.11944389343262,149.467468261719 -6.10972213745117,149.444976806641 -6.09805583953857,149.341339111328 -6.06083297729492,149.335784912109 -6.05944442749023,149.311920166016 -6.05722236633301,149.289978027344 -6.06277751922607,149.163879394531 -6.11250019073486,149.138580322266 -6.14861106872559,149.131072998047 -6.15472221374512,149.119415283203 -6.15694427490234,149.069427490234 -6.16416645050049,149.063018798828 -6.16499996185303,149.056915283203 -6.16416645050049,149.052185058594 -6.16222190856934,149.049407958984 -6.15805530548096,149.048034667969 -6.15277767181396,149.048034667969 -6.14583396911621,149.050262451172 -6.14111137390137,149.054962158203 -6.13916683197021,149.061096191406 -6.13833332061768,149.067199707031 -6.14583396911621,149.071350097656 -6.14861106872559,149.075531005859 -6.14583396911621,149.079681396484 -6.13638877868652,149.078857421875 -6.11944389343262,149.071899414062 -6.09277820587158,149.055541992188 -6.04444408416748,149.039978027344 -6.03694438934326,148.983032226562 -6.01972198486328,148.942474365234 -6.00833415985107,148.920654296875 -6.00002384185791,148.882995605469 -5.98166465759277,148.878814697266 -5.94748497009277,148.876068115234 -5.9436616897583,148.764434814453 -5.86499118804932,148.704650878906 -5.84858131408691,148.699554443359 -5.84745788574219,148.589721679688 -5.82837104797363,148.528045654297 -5.82837104797363,148.401672363281 -5.78336238861084,148.391967773438 -5.77940940856934,148.3876953125 -5.77660369873047,148.366607666016 -5.75592136383057,148.359771728516 -5.74921321868896,148.339324951172 -5.7143726348877,148.330780029297 -5.69515228271484,148.323089599609 -5.67537689208984,148.321655273438 -5.66980838775635,148.316467285156 -5.62802600860596,148.354675292969 -5.50166702270508,148.358001708984 -5.49277782440186,148.359954833984 -5.48805522918701,148.370239257812 -5.4777774810791,148.378570556641 -5.47249984741211,148.428588867188 -5.45111179351807,148.450531005859 -5.45527839660645,148.504699707031 -5.48333263397217,148.511657714844 -5.48999977111816,148.519714355469 -5.50250053405762,148.618286132812 -5.50500011444092,148.883605957031 -5.49694442749023,148.961639404297 -5.47361087799072,148.973297119141 -5.47166633605957,148.985778808594 -5.47305583953857,149.000823974609 -5.47833347320557,149.122192382812 -5.52416706085205,149.126892089844 -5.5261116027832,149.189147949219 -5.55833339691162,149.209686279297 -5.57194519042969,149.2138671875 -5.57472229003906,149.216064453125 -5.57944488525391,149.220764160156 -5.60611152648926,149.270812988281 -5.59444427490234,149.310516357422 -5.58611106872559,149.425537109375 -5.56722259521484,149.549133300781 -5.53861141204834,149.566925048828 -5.52888870239258,149.581909179688 -5.52333354949951,149.611358642578 -5.51861095428467,149.668304443359 -5.51944446563721,149.680541992188 -5.55416679382324,149.680541992188 -5.561110496521,149.685516357422 -5.56305503845215,149.692199707031 -5.56305503845215,149.710784912109 -5.5625,149.875244140625 -5.5363883972168,149.880798339844 -5.53499984741211,149.887481689453 -5.53166675567627,149.916381835938 -5.51194477081299,149.928588867188 -5.50361156463623,149.956085205078 -5.47638893127441,149.964416503906 -5.46416664123535,149.981353759766 -5.4333324432373,149.984130859375 -5.42249965667725,149.983581542969 -5.41638851165771,149.981353759766 -5.41166687011719,149.97802734375 -5.40833377838135,149.973297119141 -5.4061107635498,149.954132080078 -5.40472221374512,149.950531005859 -5.40138912200928,149.923034667969 -5.36055564880371,149.917755126953 -5.35222244262695,149.918304443359 -5.34611129760742,149.928588867188 -5.31527709960938,149.934692382812 -5.30722236633301,150.002777099609 -5.16944408416748,150.015533447266 -5.05749988555908,150.019714355469 -5.04777812957764,150.029968261719 -5.03083324432373,150.034149169922 -5.02805614471436,150.0888671875 -5.00777816772461,150.095794677734 -5.00777816772461,150.121337890625 -5.00972270965576,150.126617431641 -5.01111125946045,150.154693603516 -5.02388954162598,150.181640625 -5.03888893127441,150.19384765625 -5.04722213745117,150.199401855469 -5.05527782440186,150.203582763672 -5.0649995803833,150.204956054688 -5.07055568695068,150.203582763672 -5.07583332061768,150.184143066406 -5.09833335876465,150.180816650391 -5.10194396972656,150.164428710938 -5.11277770996094,150.154693603516 -5.11694431304932,150.132720947266 -5.12222194671631,150.101348876953 -5.13194370269775,150.091644287109 -5.13583374023438,150.082733154297 -5.14138889312744,150.072479248047 -5.15166664123535,150.064422607422 -5.16388893127441,150.061645507812 -5.17472171783447,150.04248046875 -5.3086109161377,150.062194824219 -5.36388874053955,150.121337890625 -5.51250076293945,150.123291015625 -5.51722240447998,150.143859863281 -5.5377779006958,150.164428710938 -5.55138874053955,150.178863525391 -5.55749988555908,150.184143066406 -5.55888843536377,150.282196044922 -5.57055568695068,150.291076660156 -5.57055568695068,150.296630859375 -5.569167137146,150.300811767578 -5.56638813018799,150.306915283203 -5.55888843536377,150.318023681641 -5.54194450378418,150.319976806641 -5.53722190856934,150.323303222656 -5.53361129760742,150.326904296875 -5.53027820587158,150.345245361328 -5.51472282409668,150.412475585938 -5.45861148834229,150.422760009766 -5.45527839660645,150.488555908203 -5.44694423675537,150.511108398438 -5.4505558013916,150.574127197266 -5.47638893127441,150.578308105469 -5.47916698455811,150.595520019531 -5.4961109161377,150.601623535156 -5.51722240447998,150.611083984375 -5.54194450378418,150.61328125 -5.54666709899902,150.616058349609 -5.55083274841309,150.624114990234 -5.55611038208008,150.644134521484 -5.55694389343262,150.677917480469 -5.55129909515381,150.693298339844 -5.54749965667725,150.698852539062 -5.54611110687256,150.914154052734 -5.4908332824707,150.924407958984 -5.48722171783447,150.979125976562 -5.44499969482422,151.003051757812 -5.42111110687256,151.011383056641 -5.4088888168335,151.015533447266 -5.39944458007812,151.018859863281 -5.38916683197021,151.023040771484 -5.37277698516846,151.023040771484 -5.3658332824707,151.018310546875 -5.34333324432373,151.018310546875 -5.33666706085205,151.018859863281 -5.33027839660645,151.0244140625 -5.28805541992188,151.028594970703 -5.27166652679443,151.038879394531 -5.24111080169678,151.046936035156 -5.22194480895996,151.066070556641 -5.18583297729492,151.071075439453 -5.17694473266602,151.084686279297 -5.1563892364502,151.096923828125 -5.14277839660645,151.26220703125 -4.98638820648193,151.266387939453 -4.98388862609863,151.357452392578 -4.94749927520752,151.441070556641 -4.93666648864746,151.513610839844 -4.93805503845215,151.604675292969 -4.96805572509766,151.608856201172 -4.97083377838135,151.614959716797 -4.97000026702881,151.641082763672 -4.95499992370605,151.648590087891 -4.94888877868652,151.654144287109 -4.94083309173584,151.676086425781 -4.90805530548096,151.684417724609 -4.88890266418457,151.687744140625 -4.86499977111816,151.682189941406 -4.81444454193115,151.658325195312 -4.61638832092285,151.630798339844 -4.50638961791992,151.62744140625 -4.49749946594238,151.598022460938 -4.43805503845215,151.592468261719 -4.43000030517578,151.588287353516 -4.42722225189209,151.547210693359 -4.35999965667725,151.501373291016 -4.23916625976562,151.5 -4.23388862609863,151.5 -4.22694492340088,151.503326416016 -4.21666622161865,151.508331298828 -4.20777797698975,151.511657714844 -4.20444488525391,151.536926269531 -4.18194389343262,151.783050537109 -4.20583343505859,151.841918945312 -4.22472190856934,151.852172851562 -4.22833347320557,151.857727050781 -4.23638820648193,151.859680175781 -4.24111080169678,151.861083984375 -4.24666690826416,151.863861083984 -4.27138900756836,151.869964599609 -4.28555583953857,151.878295898438 -4.29805564880371,151.884429931641 -4.30555534362793,151.895263671875 -4.3149995803833,151.904144287109 -4.32000064849854,151.9638671875 -4.33555603027344,151.969421386719 -4.33694458007812,151.974975585938 -4.33694458007812,151.984405517578 -4.33277797698975,151.991912841797 -4.32666683197021,152.138580322266 -4.20444488525391,152.141357421875 -4.20027828216553,152.145538330078 -4.19083309173584,152.150817871094 -4.17555522918701,152.153594970703 -4.16472244262695,152.153594970703 -4.15777778625488,152.156372070312 -4.15388870239258,152.161926269531 -4.14833354949951,152.166076660156 -4.14555549621582,152.171356201172 -4.14416694641113,152.177764892578 -4.14500045776367,152.185241699219 -4.14888954162598,152.214691162109 -4.16611099243164,152.235229492188 -4.2072229385376,152.239410400391 -4.21666622161865,152.2421875 -4.2344446182251,152.2421875 -4.24111080169678,152.240783691406 -4.24666690826416,152.238006591797 -4.24805545806885,152.226898193359 -4.25083351135254,152.202453613281 -4.24666690826416,152.198303222656 -4.24388885498047,152.195526123047 -4.23999977111816,152.194122314453 -4.2344446182251,152.194122314453 -4.22749996185303,152.192749023438 -4.22222232818604,152.189971923828 -4.21805572509766,152.186645507812 -4.21472263336182,152.181640625 -4.21527767181396,152.176910400391 -4.21749973297119,152.172760009766 -4.22694492340088,152.16943359375 -4.24388885498047,152.170806884766 -4.28222274780273,152.171356201172 -4.28833293914795,152.172210693359 -4.29333305358887,152.174133300781 -4.29666709899902,152.1796875 -4.30472183227539,152.186645507812 -4.31166648864746,152.190521240234 -4.31444454193115,152.195526123047 -4.31638813018799,152.263885498047 -4.33500003814697,152.286651611328 -4.33972263336182,152.305236816406 -4.34166717529297,152.355804443359 -4.34305572509766,152.401641845703 -4.61083316802979,152.403045654297 -4.62305545806885,152.405242919922 -4.66888904571533,152.405822753906 -4.68888854980469,152.394989013672 -4.76111125946045,152.389434814453 -4.78305530548096,152.386108398438 -4.79333305358887,152.336090087891 -4.87527751922607,152.333312988281 -4.87916660308838,152.294128417969 -4.92916679382324,152.268035888672 -4.95777797698975,152.241333007812 -4.9844446182251,152.233306884766 -4.98999977111816,152.161102294922 -5.00694465637207,152.157196044922 -5.00694465637207,152.123565673828 -4.99944400787354,152.112457275391 -4.99666690826416,152.088562011719 -4.98638820648193,152.083038330078 -4.98499965667725,152.050262451172 -4.97972202301025,151.996612548828 -4.97277736663818,151.990509033203 -4.97222232818604,151.984954833984 -4.97361087799072,151.978302001953 -4.98027801513672,151.974975585938 -4.98388862609863,151.970794677734 -4.993332862854,151.968017578125 -5.0041675567627,151.966644287109 -5.02333354949951,151.964691162109 -5.10472202301025,151.969970703125 -5.14833354949951,151.97412109375 -5.15777778625488,151.979675292969 -5.16583347320557,151.993286132812 -5.17555522918701,152.069427490234 -5.23499965667725,152.07275390625 -5.23833274841309,152.118011474609 -5.29222202301025,152.124114990234 -5.29972171783447,152.129669189453 -5.30777740478516,152.144134521484 -5.34138870239258,152.145538330078 -5.34666728973389,152.147491455078 -5.36388874053955,152.144134521484 -5.37416648864746,152.131072998047 -5.40222263336182,152.123565673828 -5.41638851165771,152.096069335938 -5.4572229385376,151.972747802734 -5.53111171722412,151.968566894531 -5.53361129760742,151.841918945312 -5.59722232818604,151.825531005859 -5.60111141204834,151.818572998047 -5.60111141204834,151.808319091797 -5.5977783203125,151.779418945312 -5.58555603027344,151.771362304688 -5.58000087738037,151.759155273438 -5.55138874053955,151.752777099609 -5.54388904571533,151.748565673828 -5.54111099243164,151.705535888672 -5.53111171722412,151.699401855469 -5.53027820587158,151.491638183594 -5.52833366394043,151.473297119141 -5.53027820587158,151.467742919922 -5.53166675567627,151.459411621094 -5.53583335876465,151.454132080078 -5.54111099243164,151.44384765625 -5.58555603027344,151.444427490234 -5.59166717529297,151.402770996094 -5.75137805938721,151.384704589844 -5.80720043182373,151.317779541016 -5.84993076324463,151.165649414062 -5.95807075500488,151.003051757812 -6.02250003814697,150.940795898438 -6.0286111831665,150.855804443359 -6.04083347320557,150.811920166016 -6.07638931274414,150.812744140625 -6.08944416046143,150.793304443359 -6.11805534362793,150.775543212891 -6.13916683197021,150.771636962891 -6.14166736602783,150.74609375 -6.13554954528809)),((154.153869628906 -4.44222164154053,154.128570556641 -4.3841667175293,154.126617431641 -4.37944412231445,154.128021240234 -4.37388896942139,154.132720947266 -4.37166595458984,154.140808105469 -4.37055492401123,154.150543212891 -4.37444400787354,154.152770996094 -4.37944412231445,154.1533203125 -4.3855562210083,154.155242919922 -4.43805503845215,154.153869628906 -4.44222164154053)),((145.951354980469 -4.76444530487061,145.944427490234 -4.76444530487061,145.93359375 -4.76194477081299,145.918579101562 -4.75638961791992,145.898590087891 -4.74194431304932,145.891662597656 -4.73527717590332,145.875244140625 -4.69694423675537,145.873840332031 -4.69138813018799,145.872467041016 -4.67249965667725,145.873840332031 -4.66694450378418,145.892486572266 -4.6094446182251,145.8994140625 -4.59583377838135,145.904693603516 -4.58777809143066,145.914978027344 -4.57750034332275,145.966369628906 -4.53305530548096,145.970520019531 -4.53027820587158,145.975250244141 -4.52833366394043,145.981628417969 -4.52750015258789,146.011657714844 -4.5494441986084,146.026916503906 -4.56166648864746,146.053588867188 -4.5963888168335,146.055541992188 -4.60138893127441,146.054138183594 -4.66138935089111,146.04052734375 -4.70916652679443,146.037750244141 -4.71333408355713,146.027465820312 -4.72361087799072,146.019989013672 -4.72972202301025,145.994415283203 -4.74555492401123,145.961639404297 -4.76111125946045,145.951354980469 -4.76444530487061)),((159.513305664062 -4.58166694641113,159.511383056641 -4.57666683197021,159.515533447266 -4.53972244262695,159.518859863281 -4.5363883972168,159.522216796875 -4.55083274841309,159.523040771484 -4.56388854980469,159.519714355469 -4.57388973236084,159.516937255859 -4.57805633544922,159.513305664062 -4.58166694641113)),((149.552459716797 -4.72083377838135,149.546356201172 -4.72027778625488,149.475799560547 -4.71138954162598,149.470245361328 -4.71000003814697,149.465515136719 -4.70777797698975,149.461364746094 -4.70527839660645,149.457733154297 -4.70166683197021,149.455810546875 -4.69694423675537,149.454406738281 -4.68472194671631,149.455810546875 -4.67916679382324,149.468017578125 -4.66416645050049,149.506652832031 -4.64777851104736,149.512756347656 -4.64694499969482,149.518859863281 -4.64777851104736,149.529968261719 -4.65055561065674,149.540252685547 -4.65388870239258,149.543579101562 -4.65722274780273,149.549133300781 -4.66555595397949,149.559967041016 -4.68194389343262,149.563293457031 -4.69222164154053,149.564147949219 -4.70527839660645,149.562744140625 -4.71055603027344,149.560516357422 -4.71527767181396,149.557189941406 -4.7188892364502,149.552459716797 -4.72083377838135)),((146.240509033203 -4.85805511474609,146.234405517578 -4.85750007629395,146.215789794922 -4.85138893127441,146.2119140625 -4.84861087799072,146.201629638672 -4.83833312988281,146.199401855469 -4.83361148834229,146.198028564453 -4.82805633544922,146.200256347656 -4.81638813018799,146.202178955078 -4.81166648864746,146.215789794922 -4.79111099243164,146.219970703125 -4.78833293914795,146.232177734375 -4.78833293914795,146.238555908203 -4.79055595397949,146.241333007812 -4.79333305358887,146.256927490234 -4.81166648864746,146.262481689453 -4.81972217559814,146.263885498047 -4.82527828216553,146.263885498047 -4.83083343505859,146.261932373047 -4.83555603027344,146.250823974609 -4.85472202301025,146.246612548828 -4.85750007629395,146.240509033203 -4.85805511474609)),((149.152191162109 -4.92361068725586,149.133026123047 -4.91555595397949,149.128845214844 -4.9127779006958,149.122741699219 -4.90527820587158,149.118560791016 -4.89555549621582,149.118011474609 -4.88944435119629,149.119415283203 -4.8841667175293,149.122192382812 -4.88138866424561,149.156921386719 -4.86694431304932,149.161926269531 -4.86638832092285,149.165802001953 -4.86777782440186,149.175537109375 -4.87805557250977,149.178314208984 -4.88194370269775,149.181640625 -4.89222240447998,149.178863525391 -4.89638900756836,149.156921386719 -4.92305564880371,149.152191162109 -4.92361068725586)),((154.63720703125 -5.45861148834229,154.618011474609 -5.43138885498047,154.5869140625 -5.34472274780273,154.565795898438 -5.27666664123535,154.5302734375 -5.13388919830322,154.532196044922 -5.12222194671631,154.541076660156 -5.10388851165771,154.546630859375 -5.09555530548096,154.558319091797 -5.08000087738037,154.598846435547 -5.03083324432373,154.605529785156 -5.02388954162598,154.620513916016 -5.01861095428467,154.63916015625 -5.01638889312744,154.646087646484 -5.01638889312744,154.6513671875 -5.01777839660645,154.658874511719 -5.02388954162598,154.665802001953 -5.03083324432373,154.671356201172 -5.03888893127441,154.726898193359 -5.19722175598145,154.728302001953 -5.20277786254883,154.728302001953 -5.21638870239258,154.69384765625 -5.41833305358887,154.692474365234 -5.42388916015625,154.687194824219 -5.43194389343262,154.675537109375 -5.44083309173584,154.63720703125 -5.45861148834229)),((147.135528564453 -5.45111179351807,147.121887207031 -5.44444370269775,147.009979248047 -5.35499954223633,147.008026123047 -5.3502779006958,147.002471923828 -5.30388832092285,147.008026123047 -5.25888919830322,147.009979248047 -5.24722194671631,147.013610839844 -5.23833274841309,147.017761230469 -5.23555564880371,147.109405517578 -5.19333267211914,147.121063232422 -5.19111061096191,147.128570556641 -5.19194412231445,147.134979248047 -5.19527721405029,147.191070556641 -5.248610496521,147.211639404297 -5.26916694641113,147.228851318359 -5.36388874053955,147.229949951172 -5.42111110687256,147.224670410156 -5.42944431304932,147.220520019531 -5.43194389343262,147.158874511719 -5.44833278656006,147.1533203125 -5.44972133636475,147.135528564453 -5.45111179351807)),((147.596618652344 -5.36305522918701,147.591918945312 -5.36111068725586,147.567199707031 -5.33916664123535,147.563873291016 -5.33583354949951,147.561645507812 -5.33111190795898,147.560516357422 -5.31888961791992,147.561645507812 -5.31333351135254,147.563873291016 -5.3086109161377,147.57080078125 -5.30166625976562,147.583038330078 -5.29361152648926,147.591918945312 -5.2902774810791,147.602172851562 -5.28805541992188,147.609130859375 -5.28805541992188,147.620788574219 -5.2902774810791,147.625518798828 -5.29222202301025,147.628845214844 -5.29555511474609,147.640533447266 -5.31666660308838,147.642761230469 -5.3216667175293,147.643310546875 -5.32777786254883,147.642761230469 -5.33388900756836,147.640533447266 -5.3386116027832,147.626892089844 -5.35222244262695,147.602172851562 -5.3619441986084,147.596618652344 -5.36305522918701)),((148.114685058594 -5.4688892364502,148.087463378906 -5.45527839660645,148.079132080078 -5.44972133636475,148.077178955078 -5.44499969482422,148.073028564453 -5.43000030517578,148.071624755859 -5.4244441986084,148.072204589844 -5.41833305358887,148.084686279297 -5.38972282409668,148.090789794922 -5.38222217559814,148.099700927734 -5.3774995803833,148.117462158203 -5.3841667175293,148.122192382812 -5.38638877868652,148.136657714844 -5.39944458007812,148.139434814453 -5.40333366394043,148.143585205078 -5.41305541992188,148.144989013672 -5.41833305358887,148.145538330078 -5.43833255767822,148.143585205078 -5.44972133636475,148.138031005859 -5.45805549621582,148.133880615234 -5.46083354949951,148.125793457031 -5.4661111831665,148.120788574219 -5.46833324432373,148.114685058594 -5.4688892364502)),((155.404083251953 -6,155.41552734375 -6.07638931274414,155.418853759766 -6.08666706085205,155.428588867188 -6.11111068725586,155.430541992188 -6.1158332824707,155.432739257812 -6.12083339691162,155.477172851562 -6.16916656494141,155.490783691406 -6.18277740478516,155.499114990234 -6.18805503845215,155.562744140625 -6.21749973297119,155.577178955078 -6.22361087799072,155.582733154297 -6.22500038146973,155.5888671875 -6.22416687011719,155.614959716797 -6.22000026702881,155.767761230469 -6.35583305358887,155.772491455078 -6.35777759552002,155.795257568359 -6.36250019073486,155.809692382812 -6.36861038208008,155.813598632812 -6.37138843536377,155.832733154297 -6.39861106872559,155.909698486328 -6.51222229003906,155.917755126953 -6.52444458007812,155.921905517578 -6.53416633605957,155.965789794922 -6.70555591583252,155.967193603516 -6.71111106872559,155.967742919922 -6.71722221374512,155.966644287109 -6.72277736663818,155.948028564453 -6.77583312988281,155.940521240234 -6.78861141204834,155.918579101562 -6.80777740478516,155.913024902344 -6.80916595458984,155.909698486328 -6.80555534362793,155.908874511719 -6.7994441986084,155.890533447266 -6.77972221374512,155.860778808594 -6.77500057220459,155.854675292969 -6.77444458007812,155.848571777344 -6.77500057220459,155.823852539062 -6.77777767181396,155.816375732422 -6.78055572509766,155.775268554688 -6.81444454193115,155.748565673828 -6.84249973297119,155.742462158203 -6.84999942779541,155.719696044922 -6.875,155.713012695312 -6.88194370269775,155.707458496094 -6.88333320617676,155.69384765625 -6.88333320617676,155.623840332031 -6.868332862854,155.558868408203 -6.85249996185303,155.4921875 -6.83027839660645,155.47802734375 -6.82416725158691,155.444976806641 -6.80916595458984,155.342742919922 -6.74361133575439,155.3388671875 -6.74111080169678,155.335235595703 -6.73750019073486,155.239959716797 -6.62249946594238,155.192749023438 -6.56055545806885,155.201629638672 -6.53472232818604,155.207183837891 -6.53472232818604,155.2099609375 -6.53055572509766,155.216064453125 -6.51638889312744,155.224975585938 -6.47749996185303,155.232452392578 -6.44416618347168,155.233306884766 -6.43805503845215,155.233306884766 -6.4244441986084,155.230529785156 -6.36305522918701,155.226348876953 -6.34694480895996,155.218841552734 -6.32916736602783,155.214141845703 -6.32027816772461,155.204406738281 -6.3086109161377,155.190795898438 -6.29500007629395,155.187194824219 -6.29166698455811,155.174987792969 -6.28333282470703,155.127746582031 -6.2761116027832,155.101623535156 -6.27722263336182,155.063293457031 -6.25694561004639,154.994110107422 -6.21666622161865,154.981628417969 -6.20861148834229,154.972198486328 -6.19777774810791,154.969970703125 -6.19277763366699,154.888580322266 -6.07916736602783,154.880249023438 -6.07361125946045,154.823577880859 -6.02805614471436,154.755645751953 -5.95617389678955,154.746643066406 -5.94450378417969,154.744384765625 -5.93978023529053,154.700469970703 -5.78020095825195,154.698577880859 -5.76851844787598,154.699432373047 -5.7623987197876,154.71826171875 -5.6700611114502,154.753601074219 -5.51805591583252,154.79052734375 -5.47916698455811,154.794128417969 -5.48250007629395,154.882446289062 -5.54333305358887,154.920806884766 -5.54999923706055,154.961090087891 -5.54666709899902,154.967468261719 -5.54611110687256,155.073577880859 -5.56166648864746,155.162353515625 -5.73234081268311,155.216064453125 -5.86872386932373,155.268798828125 -5.88423919677734,155.277679443359 -5.88895511627197,155.365020751953 -5.95777797698975,155.371643066406 -5.96472263336182,155.400543212891 -5.99583339691162,155.404083251953 -6)),((147.990478515625 -5.85603713989258,147.983520507812 -5.82075119018555,147.982116699219 -5.81519317626953,147.974609375 -5.79546737670898,147.972381591797 -5.79074478149414,147.968475341797 -5.78796863555908,147.945220947266 -5.77992534637451,147.93359375 -5.7777099609375,147.927490234375 -5.77854824066162,147.922790527344 -5.78049659729004,147.865112304688 -5.74775314331055,147.802154541016 -5.67277145385742,147.793273925781 -5.66138458251953,147.769958496094 -5.62221908569336,147.766052246094 -5.61277484893799,147.765228271484 -5.60666275024414,147.761108398438 -5.52833366394043,147.761932373047 -5.5222225189209,147.7802734375 -5.49416637420654,147.783874511719 -5.4908332824707,147.814697265625 -5.48472213745117,147.841918945312 -5.48999977111816,147.852172851562 -5.49361133575439,148.008605957031 -5.57611179351807,148.020812988281 -5.58416652679443,148.040802001953 -5.59861087799072,148.044128417969 -5.60194396972656,148.065307617188 -5.62758445739746,148.074279785156 -5.64482402801514,148.078460693359 -5.65427875518799,148.080444335938 -5.66595458984375,148.078552246094 -5.69124603271484,148.076629638672 -5.70347595214844,148.072540283203 -5.72654151916504,148.067840576172 -5.74905109405518,148.061492919922 -5.77711772918701,148.057586669922 -5.78656482696533,148.017150878906 -5.84463882446289,148.000762939453 -5.85269927978516,147.990478515625 -5.85603713989258)),((149.048034667969 -6.09555530548096,149.043304443359 -6.09333324432373,149.043853759766 -6.0886116027832,149.045257568359 -6.0872220993042,149.054138183594 -6.08388900756836,149.058319091797 -6.08666706085205,149.057739257812 -6.09138870239258,149.053588867188 -6.09416675567627,149.048034667969 -6.09555530548096)),((143.994415283203 -7.82583332061768,143.984680175781 -7.8230562210083,143.943572998047 -7.80277729034424,143.934692382812 -7.79805564880371,143.923583984375 -7.78861141204834,143.91748046875 -7.78111171722412,143.914703369141 -7.77694511413574,143.877746582031 -7.7186107635498,143.875793457031 -7.71388912200928,143.877166748047 -7.7097225189209,143.88134765625 -7.70694446563721,143.886657714844 -7.70833396911621,143.959411621094 -7.74222183227539,143.966918945312 -7.74833297729492,143.979125976562 -7.76333427429199,144.000549316406 -7.78999996185303,144.008026123047 -7.80277729034424,144.009429931641 -7.80833339691162,144.008605957031 -7.81416606903076,144.006652832031 -7.819167137146,143.999694824219 -7.82444477081299,143.994415283203 -7.82583332061768)),((145.193572998047 -7.86722183227539,145.186645507812 -7.86722183227539,145.182464599609 -7.86444473266602,145.180541992188 -7.86111068725586,145.177764892578 -7.83666706085205,145.178314208984 -7.83055591583252,145.182464599609 -7.82777786254883,145.185241699219 -7.83055591583252,145.191345214844 -7.84083366394043,145.197479248047 -7.85499954223633,145.198852539062 -7.86055564880371,145.197479248047 -7.86444473266602,145.193572998047 -7.86722183227539)),((143.727752685547 -8.10222244262695,143.697479248047 -8.08444404602051,143.683319091797 -8.07833290100098,143.661376953125 -8.07277679443359,143.618011474609 -8.07222175598145,143.599700927734 -8.07416725158691,143.588562011719 -8.0716667175293,143.582458496094 -8.06416702270508,143.569427490234 -8.04305648803711,143.566070556641 -8.03277778625488,143.565246582031 -8.02000045776367,143.568023681641 -8.01583480834961,143.574127197266 -8.01388931274414,143.629669189453 -8.00638961791992,143.635803222656 -8.00583457946777,143.642761230469 -8.00583457946777,143.651092529297 -8.00833511352539,143.66943359375 -8.0172233581543,143.682464599609 -8.02472305297852,143.697479248047 -8.03694534301758,143.707733154297 -8.04722213745117,143.731079101562 -8.0716667175293,143.737182617188 -8.07888793945312,143.739959716797 -8.08305549621582,143.741333007812 -8.0886116027832,143.739410400391 -8.09333229064941,143.733306884766 -8.10083198547363,143.727752685547 -8.10222244262695)),((143.66552734375 -8.17611122131348,143.654968261719 -8.17250061035156,143.625518798828 -8.15416717529297,143.621612548828 -8.15166664123535,143.618835449219 -8.14750099182129,143.607727050781 -8.13055419921875,143.604949951172 -8.11972045898438,143.604400634766 -8.11361122131348,143.604949951172 -8.10888862609863,143.609130859375 -8.10610961914062,143.636657714844 -8.09249877929688,143.642211914062 -8.09055519104004,143.654968261719 -8.0897216796875,143.679138183594 -8.09333229064941,143.688568115234 -8.09722137451172,143.700256347656 -8.10610961914062,143.707183837891 -8.11277770996094,143.710510253906 -8.11638832092285,143.716064453125 -8.12444305419922,143.718841552734 -8.13527870178223,143.719421386719 -8.15500068664551,143.7119140625 -8.16111183166504,143.702453613281 -8.1652774810791,143.683319091797 -8.1733341217041,143.677764892578 -8.17472267150879,143.66552734375 -8.17611122131348)),((143.685791015625 -8.24722099304199,143.659973144531 -8.241943359375,143.654418945312 -8.24055480957031,143.650268554688 -8.23777770996094,143.648315429688 -8.23305511474609,143.648864746094 -8.22694396972656,143.651641845703 -8.19972229003906,143.666656494141 -8.19305610656738,143.726898193359 -8.17388916015625,143.733306884766 -8.17472267150879,143.737182617188 -8.17722320556641,143.755828857422 -8.20527839660645,143.756378173828 -8.20861053466797,143.755249023438 -8.21388816833496,143.752471923828 -8.21805572509766,143.7421875 -8.22833251953125,143.734680175781 -8.23444366455078,143.718841552734 -8.23916625976562,143.697479248047 -8.24527740478516,143.685791015625 -8.24722099304199)),((143.687194824219 -8.43972206115723,143.680541992188 -8.43972206115723,143.670257568359 -8.43638801574707,143.651641845703 -8.42749977111816,143.630523681641 -8.40722274780273,143.610504150391 -8.38611221313477,143.584411621094 -8.3577766418457,143.607177734375 -8.33277702331543,143.612731933594 -8.33388900756836,143.653045654297 -8.34222221374512,143.658599853516 -8.3436107635498,143.66552734375 -8.34749984741211,143.672210693359 -8.35444450378418,143.677764892578 -8.36249923706055,143.692199707031 -8.39583396911621,143.694976806641 -8.40666770935059,143.698303222656 -8.42361068725586,143.698303222656 -8.43027877807617,143.696929931641 -8.43555641174316,143.692749023438 -8.43833351135254,143.687194824219 -8.43972206115723)),((143.57275390625 -8.49388885498047,143.559143066406 -8.49388885498047,143.509155273438 -8.48250007629395,143.498016357422 -8.47972106933594,143.493286132812 -8.4777774810791,143.354949951172 -8.41805648803711,143.318572998047 -8.39305686950684,143.315795898438 -8.38888931274414,143.314422607422 -8.38361167907715,143.314422607422 -8.37666511535645,143.319427490234 -8.36916542053223,143.326904296875 -8.3630542755127,143.331634521484 -8.36111068725586,143.339141845703 -8.35833358764648,143.342742919922 -8.3577766418457,143.356353759766 -8.3577766418457,143.494689941406 -8.3630542755127,143.573577880859 -8.37194442749023,143.578308105469 -8.37388801574707,143.581085205078 -8.37805557250977,143.616058349609 -8.46277809143066,143.616058349609 -8.4688892364502,143.613861083984 -8.47360992431641,143.610504150391 -8.47694396972656,143.583862304688 -8.49138832092285,143.578857421875 -8.49333190917969,143.57275390625 -8.49388885498047)),((143.632446289062 -8.73444366455078,143.60107421875 -8.6924991607666,143.585784912109 -8.67972183227539,143.487731933594 -8.62888717651367,143.3671875 -8.54472351074219,143.278869628906 -8.51027870178223,143.269989013672 -8.50555610656738,143.252777099609 -8.49527740478516,143.240509033203 -8.48722076416016,143.182189941406 -8.42972183227539,143.180816650391 -8.42416763305664,143.18359375 -8.42000007629395,143.211639404297 -8.4152774810791,143.217742919922 -8.41611099243164,143.227447509766 -8.42611122131348,143.233032226562 -8.43444442749023,143.251373291016 -8.45666694641113,143.261657714844 -8.46694374084473,143.274688720703 -8.47444343566895,143.324676513672 -8.48583221435547,143.371337890625 -8.49388885498047,143.422760009766 -8.51083374023438,143.467193603516 -8.52777862548828,143.644134521484 -8.66472244262695,143.647491455078 -8.66805648803711,143.651641845703 -8.67777824401855,143.653045654297 -8.68305587768555,143.653594970703 -8.68916702270508,143.653045654297 -8.7005558013916,143.641357421875 -8.72972106933594,143.638031005859 -8.73305511474609,143.632446289062 -8.73444366455078)),((151.144439697266 -8.8305549621582,151.094970703125 -8.7711124420166,151.10107421875 -8.63888931274414,151.05859375 -8.55166625976562,151.052459716797 -8.55222320556641,151.034698486328 -8.55222320556641,151.029144287109 -8.55083274841309,151.003051757812 -8.54277801513672,150.999694824219 -8.53944396972656,150.997741699219 -8.53472328186035,150.996917724609 -8.52861213684082,150.997741699219 -8.52250099182129,151.024993896484 -8.46694374084473,151.033325195312 -8.45472145080566,151.054412841797 -8.43499946594238,151.062744140625 -8.42972183227539,151.076354980469 -8.42611122131348,151.118286132812 -8.42000007629395,151.124969482422 -8.42000007629395,151.124969482422 -8.42555618286133,151.123840332031 -8.62472152709961,151.103302001953 -8.72916603088379,151.102447509766 -8.741943359375,151.103851318359 -8.7541675567627,151.107177734375 -8.76444625854492,151.144439697266 -8.8305549621582)),((152.835510253906 -9.23555564880371,152.829956054688 -9.22333335876465,152.679962158203 -9.09055519104004,152.6533203125 -9.06972122192383,152.649139404297 -9.06694412231445,152.573028564453 -9.02027893066406,152.563598632812 -9.01611137390137,152.556640625 -9.01611137390137,152.540252685547 -9.02027893066406,152.499694824219 -9.02500152587891,152.497741699219 -9.02166748046875,152.5244140625 -8.99305534362793,152.527770996094 -8.98972129821777,152.532470703125 -8.98777770996094,152.619689941406 -8.96138954162598,152.625793457031 -8.96055603027344,152.647216796875 -8.96138954162598,152.8046875 -8.96944427490234,152.810241699219 -8.97083282470703,152.814971923828 -8.97277641296387,152.93359375 -9.04388999938965,152.937744140625 -9.04666709899902,152.952758789062 -9.05888938903809,153.017761230469 -9.11777687072754,153.020538330078 -9.12166595458984,153.019989013672 -9.12638854980469,153.002777099609 -9.16500091552734,152.997192382812 -9.17305564880371,152.993011474609 -9.17583274841309,152.98828125 -9.17777824401855,152.982177734375 -9.17722320556641,152.835510253906 -9.23555564880371)),((150.334411621094 -9.52666664123535,150.310241699219 -9.5261116027832,150.193023681641 -9.45388793945312,150.180816650391 -9.44555473327637,150.173858642578 -9.43888854980469,150.110778808594 -9.37277603149414,150.108306884766 -9.36861038208008,150.103302001953 -9.33694458007812,150.102752685547 -9.33083343505859,150.104125976562 -9.31861114501953,150.106903076172 -9.30777740478516,150.123291015625 -9.2630558013916,150.126068115234 -9.26027870178223,150.143859863281 -9.24555397033691,150.189147949219 -9.21111106872559,150.198028564453 -9.20777702331543,150.206909179688 -9.2055549621582,150.2138671875 -9.2055549621582,150.232177734375 -9.20777702331543,150.326904296875 -9.26916694641113,150.330810546875 -9.27194595336914,150.333038330078 -9.27666664123535,150.376892089844 -9.38333320617676,150.37744140625 -9.38944435119629,150.363006591797 -9.48749923706055,150.344696044922 -9.51666641235352,150.339141845703 -9.52472305297852,150.334411621094 -9.52666664123535)),((150.846923828125 -9.71805572509766,150.844116210938 -9.68555641174316,150.801635742188 -9.65861129760742,150.763305664062 -9.66250038146973,150.691345214844 -9.66333389282227,150.661102294922 -9.66333389282227,150.654968261719 -9.66250038146973,150.622741699219 -9.65388870239258,150.514434814453 -9.62333297729492,150.490509033203 -9.58361053466797,150.427459716797 -9.44083404541016,150.423309326172 -9.43138885498047,150.419982910156 -9.41472244262695,150.419982910156 -9.4011116027832,150.421905517578 -9.38944435119629,150.426086425781 -9.37666511535645,150.435791015625 -9.35916519165039,150.442474365234 -9.35499954223633,150.473571777344 -9.33888816833496,150.478851318359 -9.33749961853027,150.481628417969 -9.33694458007812,150.487731933594 -9.33749961853027,150.498840332031 -9.34027671813965,150.505554199219 -9.34222221374512,150.5302734375 -9.35166549682617,150.571350097656 -9.37055397033691,150.598022460938 -9.38500022888184,150.618011474609 -9.39777946472168,150.624969482422 -9.40444564819336,150.63525390625 -9.42194557189941,150.639434814453 -9.42472267150879,150.666656494141 -9.43833351135254,150.676910400391 -9.4416675567627,150.683044433594 -9.44083404541016,150.731903076172 -9.42805671691895,150.7421875 -9.42472267150879,150.746063232422 -9.42138862609863,150.748291015625 -9.41805648803711,150.754974365234 -9.40444564819336,150.760528564453 -9.40444564819336,150.765258789062 -9.4063892364502,150.777770996094 -9.41472244262695,150.804412841797 -9.43277740478516,150.828308105469 -9.45638847351074,150.885803222656 -9.52083396911621,150.888031005859 -9.52555656433105,150.931915283203 -9.64166831970215,150.932464599609 -9.64777946472168,150.930541992188 -9.65916633605957,150.921630859375 -9.67083358764648,150.906646728516 -9.68277740478516,150.901092529297 -9.68138885498047,150.896362304688 -9.67416763305664,150.893585205078 -9.67194557189941,150.888580322266 -9.67138862609863,150.876892089844 -9.67749977111816,150.873565673828 -9.68083381652832,150.846923828125 -9.71805572509766)),((151.229125976562 -10.2011108398438,151.19775390625 -10.1727771759033,151.190246582031 -10.1669454574585,151.148315429688 -10.1472234725952,151.143585205078 -10.1452789306641,151.086639404297 -10.1269435882568,151.075805664062 -10.1244430541992,151.025817871094 -10.1141662597656,151.001647949219 -10.1108322143555,150.994964599609 -10.1108322143555,150.983306884766 -10.1127777099609,150.970245361328 -10.1122207641602,150.958587646484 -10.1102771759033,150.94970703125 -10.1055545806885,150.91552734375 -10.0041675567627,150.877746582031 -9.92666625976562,150.826904296875 -9.83888816833496,150.762481689453 -9.80500030517578,150.758605957031 -9.80249977111816,150.750274658203 -9.74833297729492,150.748840332031 -9.73083305358887,150.757202148438 -9.71194458007812,150.759979248047 -9.70777702331543,150.763885498047 -9.70499992370605,150.769439697266 -9.70666694641113,150.788024902344 -9.71944427490234,150.803039550781 -9.73138809204102,150.821624755859 -9.74694442749023,150.900268554688 -9.81916618347168,150.931915283203 -9.8488883972168,150.938873291016 -9.85583305358887,150.962738037109 -9.89361190795898,151.030548095703 -9.98527717590332,151.039428710938 -9.99694442749023,151.059967041016 -10.0169448852539,151.073028564453 -10.0244445800781,151.111358642578 -10.0447244644165,151.116058349609 -10.046667098999,151.122467041016 -10.0475006103516,151.136657714844 -10.041389465332,151.147216796875 -10.0325012207031,151.149139404297 -10.0277786254883,151.149719238281 -10.0219459533691,151.147766113281 -10.0169448852539,151.143585205078 -10.0088901519775,151.140808105469 -10.0050010681152,151.136657714844 -10.0022239685059,151.134704589844 -9.99749946594238,151.134704589844 -9.9908332824707,151.138031005859 -9.98749923706055,151.184143066406 -9.94472312927246,151.192199707031 -9.93944358825684,151.200531005859 -9.93666648864746,151.26416015625 -9.91972160339355,151.281372070312 -9.9233341217041,151.284149169922 -9.92722320556641,151.298583984375 -9.95083236694336,151.299133300781 -9.96249961853027,151.296356201172 -9.97305488586426,151.271087646484 -10.0616655349731,151.252471923828 -10.0974998474121,151.246337890625 -10.1047210693359,151.243560791016 -10.1088886260986,151.234130859375 -10.1330547332764,151.221618652344 -10.1708335876465,151.221618652344 -10.1816673278809,151.222473144531 -10.1877784729004,151.223846435547 -10.1930561065674,151.229125976562 -10.2011108398438)),((150.880523681641 -10.6527786254883,150.856353759766 -10.6494445800781,150.794128417969 -10.6394443511963,150.785247802734 -10.6347236633301,150.769439697266 -10.6111106872559,150.767486572266 -10.6075000762939,150.788024902344 -10.5463886260986,150.790802001953 -10.5422229766846,150.794708251953 -10.539722442627,150.798858642578 -10.5383338928223,150.868835449219 -10.5383338928223,150.874969482422 -10.5388889312744,150.892211914062 -10.547779083252,150.900268554688 -10.5530548095703,150.904418945312 -10.5625,150.894989013672 -10.6466665267944,150.892211914062 -10.6508331298828,150.880523681641 -10.6527786254883)),((150.927185058594 -10.6838893890381,150.923034667969 -10.6825008392334,150.920257568359 -10.6783332824707,150.911926269531 -10.65944480896,150.909973144531 -10.6547222137451,150.909149169922 -10.6419448852539,150.909973144531 -10.6358337402344,150.91943359375 -10.6130542755127,150.922210693359 -10.6088886260986,150.9296875 -10.6030540466309,150.934692382812 -10.6008319854736,150.94970703125 -10.59694480896,151.016082763672 -10.5908336639404,151.064147949219 -10.5922222137451,151.066925048828 -10.5947227478027,151.06884765625 -10.5980548858643,151.069702148438 -10.6111106872559,151.063293457031 -10.6438903808594,151.049133300781 -10.6702785491943,151.042205810547 -10.676944732666,151.036651611328 -10.6783332824707,151.031372070312 -10.676944732666,151.009979248047 -10.6683330535889,151.008026123047 -10.6636123657227,151.003875732422 -10.6472234725952,151.001647949219 -10.6427783966064,150.994110107422 -10.6366672515869,150.988861083984 -10.6352787017822,150.941345214844 -10.6347236633301,150.936096191406 -10.6347236633301,150.929138183594 -10.6547222137451,150.927185058594 -10.6838893890381)),((152.744415283203 -10.7166652679443,152.702453613281 -10.7066669464111,152.686920166016 -10.7019443511963,152.573852539062 -10.6569442749023,152.564971923828 -10.6522235870361,152.544982910156 -10.6380558013916,152.541656494141 -10.6338901519775,152.540802001953 -10.6305541992188,152.542205810547 -10.6277770996094,152.555236816406 -10.6230554580688,152.562194824219 -10.6230554580688,152.573852539062 -10.6252765655518,152.614959716797 -10.6386127471924,152.690246582031 -10.6627788543701,152.693023681641 -10.6627788543701,152.759429931641 -10.6372222900391,152.784973144531 -10.6211109161377,152.790252685547 -10.6197204589844,152.814971923828 -10.6291656494141,152.870513916016 -10.6580562591553,152.873291015625 -10.6622219085693,152.873840332031 -10.6683330535889,152.873291015625 -10.6730556488037,152.870513916016 -10.676944732666,152.863586425781 -10.6825008392334,152.844970703125 -10.6952781677246,152.814971923828 -10.6966667175293,152.744415283203 -10.7166652679443)),((153.210510253906 -11.2858333587646,153.181640625 -11.2522239685059,153.143859863281 -11.2247219085693,153.13916015625 -11.2227764129639,153.120513916016 -11.2166652679443,153.114959716797 -11.2152767181396,153.106079101562 -11.2147216796875,153.093292236328 -11.2019443511963,153.091064453125 -11.1972217559814,153.093841552734 -11.1930561065674,153.102172851562 -11.1888885498047,153.112457275391 -11.1844444274902,153.123840332031 -11.1849994659424,153.12939453125 -11.1863880157471,153.198028564453 -11.2172222137451,153.2138671875 -11.2247219085693,153.222747802734 -11.2294454574585,153.251373291016 -11.2469444274902,153.250579833984 -11.25,153.25 -11.2522239685059,153.241058349609 -11.2688903808594,153.210510253906 -11.2858333587646)),((154.112182617188 -11.4397220611572,154.106628417969 -11.4397220611572,154.062744140625 -11.4330558776855,154.058013916016 -11.4308338165283,154.006652832031 -11.3872222900391,154.003326416016 -11.3838901519775,154.021087646484 -11.3488883972168,154.089691162109 -11.3152770996094,154.153869628906 -11.3141670227051,154.225250244141 -11.3194446563721,154.268310546875 -11.338888168335,154.276641845703 -11.344165802002,154.286376953125 -11.3605556488037,154.288299560547 -11.3649997711182,154.297760009766 -11.3919448852539,154.289703369141 -11.4108333587646,154.285522460938 -11.4136123657227,154.266387939453 -11.421667098999,154.263031005859 -11.4180555343628,154.26025390625 -11.4075012207031,154.256103515625 -11.4047222137451,154.250549316406 -11.4033336639404,154.190246582031 -11.3994445800781,154.137481689453 -11.3986110687256,154.134704589844 -11.4027786254883,154.112182617188 -11.4397220611572)),((153.566070556641 -11.6424999237061,153.522216796875 -11.602222442627,153.479125976562 -11.5733337402344,153.421356201172 -11.5686111450195,153.376068115234 -11.5672225952148,153.3671875 -11.557222366333,153.364410400391 -11.5530548095703,153.363861083984 -11.5472221374512,153.376068115234 -11.5269451141357,153.382446289062 -11.5197219848633,153.38720703125 -11.5108337402344,153.388580322266 -11.5055561065674,153.387756347656 -11.5008344650269,153.384429931641 -11.4974994659424,153.325531005859 -11.4752769470215,153.276916503906 -11.4624996185303,153.271911621094 -11.4605560302734,153.268585205078 -11.4572219848633,153.190521240234 -11.3730554580688,153.188293457031 -11.3683319091797,153.187194824219 -11.3536109924316,153.187194824219 -11.3497219085693,153.198028564453 -11.3241672515869,153.200805664062 -11.3199996948242,153.220520019531 -11.3274993896484,153.291931152344 -11.3569431304932,153.398040771484 -11.4047222137451,153.413879394531 -11.4161109924316,153.426910400391 -11.4302787780762,153.437744140625 -11.4397220611572,153.507751464844 -11.4724998474121,153.559143066406 -11.491943359375,153.570251464844 -11.494722366333,153.576354980469 -11.4955539703369,153.645538330078 -11.5150012969971,153.686645507812 -11.5269451141357,153.751098632812 -11.5644445419312,153.754425048828 -11.5680561065674,153.7763671875 -11.5974998474121,153.777770996094 -11.6027765274048,153.7763671875 -11.6080551147461,153.7744140625 -11.6130542755127,153.770812988281 -11.6163883209229,153.676361083984 -11.6283321380615,153.670257568359 -11.6277770996094,153.605804443359 -11.6174983978271,153.598846435547 -11.6174983978271,153.582458496094 -11.6283321380615,153.566070556641 -11.6424999237061)))
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits
