[geos-commits] r2647 - trunk/tests/xmltester
svn_geos at osgeo.org
Thu Oct 1 04:46:35 EDT 2009
Author: strk
Date: 2009-10-01 04:46:35 -0400 (Thu, 01 Oct 2009)
New Revision: 2647
Added:
trunk/tests/xmltester/safe_to_xml.sh
Add utility script to import tests from SAFE software
Added: trunk/tests/xmltester/safe_to_xml.sh
--- trunk/tests/xmltester/safe_to_xml.sh (rev 0)
+++ trunk/tests/xmltester/safe_to_xml.sh 2009-10-01 08:46:35 UTC (rev 2647)
@@ -0,0 +1,142 @@
+#!/bin/sh
+# GEOS - Geometry Engine Open Source
+# http://geos.refractions.net
+# Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+# This script is an utility to convert SAFE Software testcases to
+# the format accepted by XMLTester
+if ! test -n "$1"; then
+ echo "Usage: $0 <testno>"
+ exit 1
+fi
+SAFETESTNO="$1"
+SAFEIN=${SAFETESTNO}_input.txt
+SAFEPARAMS=${SAFETESTNO}_params.txt
+if ! test -e ${SAFEIN}; then echo "Missing ${SAFEIN}"; exit 1; fi
+#if ! test -e ${SAFEOUT_LEFT}; then echo "Missing ${SAFEOUT_LEFT}"; exit 1; fi
+#if ! test -e ${SAFEOUT_RIGHT}; then echo "Missing ${SAFEOUT_RIGHT}"; exit 1; fi
+if ! test -e ${SAFEOUT_PARAMS}; then echo "Missing ${SAFEOUT_PARAMS}"; exit 1; fi
+exec 4< ${SAFEIN}
+#exec 5< ${SAFEOUT_LEFT}
+#exec 6< ${SAFEOUT_LEFT}
+#echo '<run>'
+#echo '<precisionModel type="FLOATING" />'
+# Parse parameters/tests
+TESTS=${SAFEIN}_tests
+exec 7< ${SAFEPARAMS}
+exec 8> ${TESTS}
+arg2=na
+style=na
+opname=na
+while read line <&7; do
+ # end of test
+ if test -z "${line}"; then
+ testline="<op name='buffersinglesided' arg1='a' arg2='${arg2}' arg3='4' arg4='${style}'>|${opname}"
+ echo ${testline} >&8
+ fi
+ lbl=`echo ${line} | cut -d: -f1`
+ val=`echo ${line} | cut -d: -f2`
+ if test "${lbl}" = "Buffer Amount"; then
+ arg2=${val}
+ elif test "${lbl}" = "Buffer Style"; then
+ if test "${val}" = "RIGHT_SIDE_ONLY"; then
+ style=right
+ else
+ style=left
+ fi
+ elif test "${lbl}" = "Interpolation Angle"; then
+ continue
+ else
+ opname=`echo ${lbl} | cut -d' ' -f 2 | tr '[A-Z]' ['a-z']`
+ if test "${opname}" = 'left' -o "${opname}" = 'right'; then
+ opname="_${opname}"
+ fi
+ fi
+done
+testline="<op name='buffersinglesided' arg1='a' arg2='${arg2}' arg3='4' arg4='${style}'>|${opname}"
+echo ${testline} >&8
+echo '<run>'
+echo '<precisionModel type="FLOATING" />'
+# A case each input
+caseno=1
+while read inp <&4; do
+ echo "<case><desc>SAFE test ${SAFETESTNO} line ${caseno}</desc>"
+ echo '<a>'
+ # hack until GEOS supports proper OGC WKT: POINT Z (0 0)
+ inp=`echo "${inp}" | sed -e 's/ Z //'`
+ echo ${inp}
+ echo '</a>'
+ # A test each param
+ exec 9< ${TESTS}
+ while read testspec <&9; do
+ test=`echo "${testspec}" | cut -d'|' -f1`
+ out=`echo "${testspec}" | cut -d'|' -f2`
+ echo '<test>'
+ echo ' '${test}
+ # read line from line ${caseno} of ${SAFEOUT}
+ SAFEOUT=${SAFETESTNO}_output${out}.txt
+ expout=`head -${caseno} ${SAFEOUT} | tail -1`
+ expout=`echo "${expout}" | sed -e 's/ Z //'`
+ echo ${expout}
+ echo ' </op>'
+ echo '</test>'
+ done
+ echo '</case>'
+ caseno=$((caseno+1))
+done
+echo '</run>'
Property changes on: trunk/tests/xmltester/safe_to_xml.sh
___________________________________________________________________
Added: svn:executable
More information about the geos-commits
