[geos-commits] r2648 - trunk/tests/xmltester
svn_geos at osgeo.org
Thu Oct 1 05:02:00 EDT 2009
Author: strk
Date: 2009-10-01 05:01:59 -0400 (Thu, 01 Oct 2009)
New Revision: 2648
trunk/tests/xmltester/safe_to_xml.sh
Better parse style parameter
Modified: trunk/tests/xmltester/safe_to_xml.sh
--- trunk/tests/xmltester/safe_to_xml.sh 2009-10-01 08:46:35 UTC (rev 2647)
+++ trunk/tests/xmltester/safe_to_xml.sh 2009-10-01 09:01:59 UTC (rev 2648)
@@ -67,7 +67,8 @@
elif test "${lbl}" = "Buffer Style"; then
- if test "${val}" = "RIGHT_SIDE_ONLY"; then
+ # No quotes around ${val} is intentional, to trim blanks
+ if test ${val} = "RIGHT_SIDE_ONLY"; then
style=right
else
style=left
More information about the geos-commits
