[geos-commits] r2694 - in trunk: source/headers/geos/linearref
source/linearref tests/unit/linearref
svn_geos at osgeo.org
Fri Oct 23 05:43:52 EDT 2009
Author: strk
Date: 2009-10-23 05:43:52 -0400 (Fri, 23 Oct 2009)
New Revision: 2694
trunk/source/headers/geos/linearref/LocationIndexOfLine.h
trunk/source/linearref/LengthIndexedLine.cpp
trunk/source/linearref/LocationIndexOfLine.cpp
trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
Document ownership of return from LocationIndexOfLine::indicesOf, fix mismatch delete/delete[] in core and unit test
Modified: trunk/source/headers/geos/linearref/LocationIndexOfLine.h
--- trunk/source/headers/geos/linearref/LocationIndexOfLine.h 2009-10-23 09:34:24 UTC (rev 2693)
+++ trunk/source/headers/geos/linearref/LocationIndexOfLine.h 2009-10-23 09:43:52 UTC (rev 2694)
@@ -50,10 +50,25 @@
const geom::Geometry* linearGeom;
public:
+ /** \brief
+ * Determines the location of a subline along a linear {@link Geometry}.
+ * The location is reported as a pair of {@link LinearLocation}s.
+ * <b>Note:</b> Currently this algorithm is not guaranteed to
+ * return the correct substring in some situations where
+ * an endpoint of the test line occurs more than once in the input line.
+ * (However, the common case of a ring is always handled correctly).
+ * Caller must take of releasing with delete[]
static LinearLocation* indicesOf(const geom::Geometry* linearGeom, const geom::Geometry* subLine);
LocationIndexOfLine(const geom::Geometry* linearGeom);
+ /// Caller must take of releasing with delete[]
LinearLocation* indicesOf(const geom::Geometry* subLine) const;
Modified: trunk/source/linearref/LengthIndexedLine.cpp
--- trunk/source/linearref/LengthIndexedLine.cpp 2009-10-23 09:34:24 UTC (rev 2693)
+++ trunk/source/linearref/LengthIndexedLine.cpp 2009-10-23 09:43:52 UTC (rev 2694)
@@ -86,7 +86,7 @@
double* index = new double[2];
index[0] = LengthLocationMap::getLength(linearGeom, locIndex[0]);
index[1] = LengthLocationMap::getLength(linearGeom, locIndex[1]);
- delete locIndex;
+ delete [] locIndex;
return index;
Modified: trunk/source/linearref/LocationIndexOfLine.cpp
--- trunk/source/linearref/LocationIndexOfLine.cpp 2009-10-23 09:34:24 UTC (rev 2693)
+++ trunk/source/linearref/LocationIndexOfLine.cpp 2009-10-23 09:43:52 UTC (rev 2694)
@@ -33,17 +33,10 @@
namespace linearref // geos.linearref
- * Determines the location of a subline along a linear {@link Geometry}.
- * The location is reported as a pair of {@link LinearLocation}s.
- * <p>
- * <b>Note:</b> Currently this algorithm is not guaranteed to
- * return the correct substring in some situations where
- * an endpoint of the test line occurs more than once in the input line.
- * (However, the common case of a ring is always handled correctly).
-LinearLocation* LocationIndexOfLine::indicesOf(const Geometry* linearGeom, const Geometry* subLine)
+/* public static */
+LinearLocation*
+LocationIndexOfLine::indicesOf(const Geometry* linearGeom,
+ const Geometry* subLine)
LocationIndexOfLine locater(linearGeom);
return locater.indicesOf(subLine);
@@ -52,7 +45,9 @@
LocationIndexOfLine::LocationIndexOfLine(const Geometry* linearGeom) :
linearGeom(linearGeom) {}
-LinearLocation* LocationIndexOfLine::indicesOf(const Geometry* subLine) const
+/* public */
+LinearLocation*
+LocationIndexOfLine::indicesOf(const Geometry* subLine) const
Coordinate startPt = dynamic_cast<const LineString*> (subLine->getGeometryN(0))->getCoordinateN(0);
const LineString* lastLine = dynamic_cast<const LineString*> (subLine->getGeometryN(subLine->getNumGeometries() - 1));
Modified: trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
--- trunk/tests/unit/linearref/LengthIndexedLineTest.cpp 2009-10-23 09:34:24 UTC (rev 2693)
+++ trunk/tests/unit/linearref/LengthIndexedLineTest.cpp 2009-10-23 09:43:52 UTC (rev 2694)
@@ -148,7 +148,7 @@
LengthIndexedLine indexedLine(linearGeom);
double* loc = indexedLine.indicesOf(subLine);
Geometry* result = indexedLine.extractLine(loc[0], loc[1]);
- delete loc;
+ delete [] loc;
return result;
More information about the geos-commits
