[geos-commits] r2695 - in trunk/source: headers/geos/linearref
linearref
svn_geos at osgeo.org
Fri Oct 23 05:53:30 EDT 2009
Author: strk
Date: 2009-10-23 05:53:30 -0400 (Fri, 23 Oct 2009)
New Revision: 2695
trunk/source/headers/geos/linearref/LinearGeometryBuilder.h
trunk/source/linearref/LinearGeometryBuilder.cpp
Cleanup LinearGeometrybuilder defs and impl to match common code style, add note about suspicious things (not written but noted that the class seems to lack a destructor..)
Modified: trunk/source/headers/geos/linearref/LinearGeometryBuilder.h
--- trunk/source/headers/geos/linearref/LinearGeometryBuilder.h 2009-10-23 09:43:52 UTC (rev 2694)
+++ trunk/source/headers/geos/linearref/LinearGeometryBuilder.h 2009-10-23 09:53:30 UTC (rev 2695)
@@ -59,7 +59,8 @@
* Allows invalid lines to be ignored rather than causing Exceptions.
* An invalid line is one which has only one unique point.
- * @param ignoreShortLines <code>true</code> if short lines are to be ignored
+ * @param ignoreShortLines <code>true</code> if short lines are
+ * to be ignored
void setIgnoreInvalidLines(bool ignoreInvalidLines);
@@ -67,9 +68,11 @@
+ * to be ignored
void setFixInvalidLines(bool fixInvalidLines);
* Adds a point to the current line.
@@ -84,15 +87,16 @@
void add(const geom::Coordinate& pt, bool allowRepeatedPoints);
+ /// NOTE strk: why return by value ?
geom::Coordinate getLastCoordinate() const;
- * Terminate the current LineString.
+ /// Terminate the current LineString.
void endLine();
geom::Geometry *getGeometry();
+} // namespace geos.linearref
#endif
Modified: trunk/source/linearref/LinearGeometryBuilder.cpp
--- trunk/source/linearref/LinearGeometryBuilder.cpp 2009-10-23 09:43:52 UTC (rev 2694)
+++ trunk/source/linearref/LinearGeometryBuilder.cpp 2009-10-23 09:53:30 UTC (rev 2695)
@@ -35,47 +35,41 @@
namespace geos
namespace linearref // geos.linearref
+/* public */
LinearGeometryBuilder::LinearGeometryBuilder(const GeometryFactory* geomFact) :
geomFact(geomFact),
ignoreInvalidLines(false),
fixInvalidLines(false),
coordList(0) {}
-void LinearGeometryBuilder::setIgnoreInvalidLines(bool ignoreInvalidLines)
+/* public */
+void
+LinearGeometryBuilder::setIgnoreInvalidLines(bool ignoreInvalidLines)
this->ignoreInvalidLines = ignoreInvalidLines;
- * Allows invalid lines to be ignored rather than causing Exceptions.
- * An invalid line is one which has only one unique point.
-void LinearGeometryBuilder::setFixInvalidLines(bool fixInvalidLines)
+/* public */
+void
+LinearGeometryBuilder::setFixInvalidLines(bool fixInvalidLines)
this->fixInvalidLines = fixInvalidLines;
- * Adds a point to the current line.
- * @param pt the Coordinate to add
-void LinearGeometryBuilder::add(const Coordinate& pt)
+/* public */
+void
+LinearGeometryBuilder::add(const Coordinate& pt)
add(pt, true);
-void LinearGeometryBuilder::add(const Coordinate& pt, bool allowRepeatedPoints)
+/* public */
+void
+LinearGeometryBuilder::add(const Coordinate& pt, bool allowRepeatedPoints)
if (!coordList)
coordList = new CoordinateArraySequence();
@@ -83,15 +77,16 @@
lastPt = pt;
-Coordinate LinearGeometryBuilder::getLastCoordinate() const
+/* public */
+Coordinate
+LinearGeometryBuilder::getLastCoordinate() const
return lastPt;
-void LinearGeometryBuilder::endLine()
+/* public */
+void
+LinearGeometryBuilder::endLine()
if (!coordList)
@@ -131,11 +126,16 @@
coordList = 0;
-Geometry* LinearGeometryBuilder::getGeometry()
+/* public */
+Geometry*
+LinearGeometryBuilder::getGeometry()
// end last line in case it was not done by user
endLine();
+ // NOTE: lines elements are cloned
return geomFact->buildGeometry(lines);
More information about the geos-commits
