[geos-commits] r3088 - trunk/capi
svn_geos at osgeo.org
Tue Aug 17 14:33:56 EDT 2010
Author: sgillies
Date: 2010-08-17 18:33:56 +0000 (Tue, 17 Aug 2010)
New Revision: 3088
trunk/capi/geos_ts_c.cpp
Throw runtime_error if allocation fails in gstrdup_s
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-07-26 22:21:07 UTC (rev 3087)
+++ trunk/capi/geos_ts_c.cpp 2010-08-17 18:33:56 UTC (rev 3088)
@@ -4,6 +4,7 @@
* C-Wrapper for GEOS library
+ * Copyright (C) 2010 Sean Gillies <sean.gillies at gmail.com>
* Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2006 Refractions Research Inc.
@@ -120,6 +121,8 @@
using geos::algorithm::distance::DiscreteHausdorffDistance;
+using std::runtime_error;
typedef std::auto_ptr<Geometry> GeomAutoPtr;
typedef struct GEOSContextHandleInternal
@@ -162,6 +165,11 @@
assert(0 != out);
+ // we haven't been checking allocation before ticket #371
+ if (0 == out)
+ throw(runtime_error("Failed to allocate memory for duplicate string"));
return out;
More information about the geos-commits
