[geos-commits] r3089 - trunk/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Aug 17 14:57:38 EDT 2010
Author: sgillies
Date: 2010-08-17 18:57:38 +0000 (Tue, 17 Aug 2010)
New Revision: 3089
   trunk/capi/geos_ts_c.cpp
Use fully qualified std::runtime_error (#371) and fix indentation
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2010-08-17 18:33:56 UTC (rev 3088)
+++ trunk/capi/geos_ts_c.cpp	2010-08-17 18:57:38 UTC (rev 3089)
@@ -4,7 +4,6 @@
  * C-Wrapper for GEOS library
- * Copyright (C) 2010 Sean Gillies <sean.gillies at gmail.com>
  * Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
  * Copyright (C) 2005-2006 Refractions Research Inc.
@@ -121,8 +120,6 @@
 using geos::algorithm::distance::DiscreteHausdorffDistance;
-using std::runtime_error;
 typedef std::auto_ptr<Geometry> GeomAutoPtr;
 typedef struct GEOSContextHandleInternal
@@ -168,8 +165,10 @@
     // we haven't been checking allocation before ticket #371
     if (0 == out)
-	      throw(runtime_error("Failed to allocate memory for duplicate string"));
+        throw(std::runtime_error("Failed to allocate memory for duplicate string"));
     return out;
More information about the geos-commits mailing list
