[geos-commits] r3102 - in trunk: include/geos/geom tests/xmltester
svn_geos at osgeo.org
Fri Aug 27 11:55:28 EDT 2010
Author: strk
Date: 2010-08-27 15:55:28 +0000 (Fri, 27 Aug 2010)
New Revision: 3102
trunk/include/geos/geom/BinaryOp.h
trunk/tests/xmltester/Makefile.am
Check validity of CommonBitsOp return, as JTS does. Check output validity for all tests, do not run the now-throwing tests also known to be bogus in JTS.
Modified: trunk/include/geos/geom/BinaryOp.h
--- trunk/include/geos/geom/BinaryOp.h 2010-08-27 15:43:21 UTC (rev 3101)
+++ trunk/include/geos/geom/BinaryOp.h 2010-08-27 15:55:28 UTC (rev 3102)
@@ -117,7 +117,7 @@
* to prevent a result.
-//#define GEOS_CHECK_COMMONBITS_VALIDITY 1
+#define GEOS_CHECK_COMMONBITS_VALIDITY 1
* Use snapping policy
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2010-08-27 15:43:21 UTC (rev 3101)
+++ trunk/tests/xmltester/Makefile.am 2010-08-27 15:55:28 UTC (rev 3102)
@@ -6,9 +6,9 @@
#top_srcdir=@top_srcdir@
#top_builddir=@top_builddir@
-TESTS = testrunner invalid-testrunner
+TESTS = testrunner
-CLEANFILES = testrunner invalid-testrunner
+CLEANFILES = testrunner
EXTRA_DIST = testrunner.sh
@@ -57,6 +57,7 @@
$(srcdir)/tests/general/TestValid2-big.xml \
$(srcdir)/tests/general/TestWithinDistance.xml \
$(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20061020-invalid-output.xml \
$(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
$(srcdir)/tests/robust/TestRobustRelate.xml \
@@ -70,8 +71,7 @@
$(srcdir)/tests/safe/16595.xml \
$(srcdir)/tests/safe/16596.xml
-INVALID_OUTPUT_XMLTESTS = \
- $(srcdir)/tests/stmlf/stmlf-cases-20061020-invalid-output.xml
+INVALID_OUTPUT_XMLTESTS =
FAILING_XMLTESTS = \
$(srcdir)/tests/failure/TestOverlay.xml
@@ -121,6 +121,3 @@
testrunner: testrunner.sh Makefile
@sh $(srcdir)/testrunner.sh $@ --test-valid-output $(SAFE_XMLTESTS)
-invalid-testrunner: testrunner.sh Makefile
- @sh $(srcdir)/testrunner.sh $@ $(INVALID_OUTPUT_XMLTESTS)
More information about the geos-commits
