[geos-commits] r3103 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Aug 27 11:58:07 EDT 2010
Author: strk
Date: 2010-08-27 15:58:07 +0000 (Fri, 27 Aug 2010)
New Revision: 3103
Removed:
   trunk/tests/xmltester/tests/bug375.xml
Drop duplicated testcase
Deleted: trunk/tests/xmltester/tests/bug375.xml
--- trunk/tests/xmltester/tests/bug375.xml	2010-08-27 15:55:28 UTC (rev 3102)
+++ trunk/tests/xmltester/tests/bug375.xml	2010-08-27 15:58:07 UTC (rev 3103)
@@ -1,184 +0,0 @@
-<run>
-  <!-- first occurrence is used -->
-  <precisionModel type="FLOATING" />
-  <precisionModel type="FLOATING_SINGLE" />
-  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
- <case>
-<desc>
-http://trac.osgeo.org/geos/ticket/375
-</desc>
-<a>
-POLYGON((5417148.108 5658342.603,5417139.016
-5658338.009,5417126.791 5658331.833,5417116.292 5658327.518,5417112.871
-5658325.598,5417110.25 5658324.127,5417106.071 5658321.781,5417104.226
-5658320.745,5417093.266 5658315.008,5417091.265 5658313.961,5417085.335
-5658310.857,5417060.44 5658326.26,5417064.68 5658327.52,5417088.83
-5658336.46,5417088.52 5658337.31,5417102.92 5658342.65,5417103.26
-5658341.83,5417111.76 5658345.51,5417121.662 5658349.583,5417121.878
-5658349.672,5417125.217 5658351.119,5417131.761 5658353.388,5417137.589
-5658356.276,5417142.166 5658359.67,5417146.599 5658364.988,5417151.395
-5658370.641,5417150.853 5658371.392,5417152.59741167
-5658373.52811061,5417154.92 5658376.37,5417155.18955743
-5658376.89699992,5417154.919 5658376.371,5417155.814
-5658378.111,5417157.051 5658380.297,5417158.004 5658382.304,5417159.014
-5658384.47,5417159.775 5658386.619,5417160.629 5658389.278,5417161.5
-5658399.49,5417160.773 5658404.194,5417159.41 5658413.02,5417158.853
-5658414.442,5417153.671 5658427.659,5417153.67051161
-5658427.6586943,5417153.67 5658427.66,5417152.73 5658427.07,5417149.993
-5658436.599,5417148.81 5658439.42,5417149.233 5658439.67,5417148.36
-5658440.81,5417146.41 5658446.6,5417144.321 5658453.127,5417144.32092232
-5658453.13043826,5417154.59 5658458.01,5417154.99551047
-5658455.8409905,5417155.446 5658453.413,5417157.23981414
-5658448.75748237,5417157.22660892 5658448.57861162,5417157.22660849
-5658448.57860592,5417157.22660865 5658448.57860812,5417157.128
-5658447.265,5417157.64950997 5658446.06368023,5417157.64950961
-5658446.06368108,5417158.314 5658444.533,5417172.322
-5658417.957,5417174.99 5658418.57,5417175.23 5658417.74,5417176.696
-5658412.61,5417177.875 5658408.488,5417178.76 5658405.39,5417178.1
-5658393.55,5417178.08 5658393.36,5417177.11 5658384.95,5417178.151
-5658384.915,5417178.14836289 5658384.91508866,5417178.12
-5658384.83,5417177.91415246 5658383.81114117,5417176.927
-5658378.944,5417176.603 5658377.341,5417176.73975922
-5658378.01762048,5417176.6 5658377.34,5417176.51210558
-5658376.89535766,5417176.428 5658376.483,5417175.235
-5658370.602,5417171.577 5658362.886,5417170.762 5658360.107,5417168.522
-5658357.989,5417166.042 5658355.047,5417164.137 5658352.264,5417162.642
-5658351.593,5417160.702 5658350.843,5417160.05417889
-5658350.5823586,5417158.82 5658350.09,5417158.82103105
-5658350.0862195,5417159.50373263 5658350.36089455,5417158.818
-5658350.085,5417159.055 5658349.214,5417155.754
-5658347.679,5417156.78066321 5658348.15640928,5417155.7525011
-5658347.6811561,5417155.161 5658348.532,5417149.028
-5658343.237,5417152.26877967 5658346.03496647,5417149.03
-5658343.24,5417148.78133339 5658343.06701453,5417148.108
-5658342.603))
-</a>
-<b>
-POLYGON((5417148.36 5658440.81,5417149.233
-5658439.67,5417148.81 5658439.42,5417149.993 5658436.599,5417152.73
-5658427.07,5417153.67 5658427.66,5417153.67051161
-5658427.6586943,5417153.671 5658427.659,5417158.853
-5658414.442,5417159.41 5658413.02,5417160.773 5658404.194,5417161.5
-5658399.49,5417160.63 5658389.28,5417159.78 5658386.62,5417159.366239
-5658385.46469333,5417159.014 5658384.47,5417158.004
-5658382.304,5417157.051 5658380.297,5417155.814
-5658378.111,5417155.18955747 5658376.897,5417154.92
-5658376.37,5417152.59740379 5658373.52810095,5417150.853
-5658371.392,5417151.13020611 5658371.00790076,5417151.4
-5658370.64,5417147.11100598 5658365.59149663,5417146.599
-5658364.988,5417145.96673439 5658364.22950947,5417142.17
-5658359.67,5417139.98754716 5658358.05460369,5417137.589
-5658356.276,5417131.761 5658353.388,5417125.33011568
-5658351.15822058,5417125.22 5658351.12,5417121.88 5658349.67,5417121.66
-5658349.58,5417111.76 5658345.51,5417103.26 5658341.83,5417102.92
-5658342.65,5417088.52 5658337.31,5417088.83 5658336.46,5417064.68
-5658327.52,5417060.44 5658326.26,5417085.34 5658310.86,5417085.90750076
-5658311.15666987,5417091.265 5658313.961,5417093.266
-5658315.008,5417093.61266829 5658315.18946314,5417104.23
-5658320.75,5417105.81727304 5658321.63852784,5417106.071
-5658321.781,5417106.60319005 5658322.07975996,5417110.25
-5658324.13,5417112.87 5658325.6,5417116.29 5658327.52,5417121.76604303
-5658329.76778528,5417126.791 5658331.833,5417139.016
-5658338.009,5417148.108 5658342.603,5417148.78133333
-5658343.06701449,5417149.03 5658343.24,5417152.26878253
-5658346.03496893,5417155.161 5658348.532,5417155.7525011
-5658347.6811561,5417156.78066337 5658348.15640935,5417159.055
-5658349.214,5417158.818 5658350.085,5417158.82103105
-5658350.0862195,5417158.82 5658350.09,5417160.0541792
-5658350.58235872,5417160.702 5658350.843,5417162.642
-5658351.593,5417164.137 5658352.264,5417165.25343486
-5658353.89499119,5417166.04 5658355.05,5417168.52 5658357.99,5417170.76
-5658360.11,5417171.26171711 5658361.81094338,5417171.577
-5658362.886,5417175.235 5658370.602,5417176.428
-5658376.483,5417176.51210558 5658376.89535766,5417176.6
-5658377.34,5417176.73975924 5658378.01762057,5417176.927
-5658378.944,5417177.91415134 5658383.81113564,5417178.12
-5658384.83,5417178.14836289 5658384.91508866,5417177.11
-5658384.95,5417178.08 5658393.36,5417178.1 5658393.55,5417178.76
-5658405.39,5417177.875 5658408.488,5417176.696 5658412.61,5417175.23
-5658417.74,5417174.99 5658418.57,5417172.322
-5658417.957,5417172.32037372 5658417.96008538,5417172.32
-5658417.96,5417158.31 5658444.53,5417157.64951003
-5658446.06368011,5417157.128 5658447.265,5417157.22660867
-5658448.5786084,5417157.23981414 5658448.75748238,5417155.446
-5658453.413,5417154.99551072 5658455.84098918,5417154.59
-5658458.01,5417144.32092232 5658453.13043826,5417144.321
-5658453.127,5417146.41 5658446.6,5417148.36 5658440.81))
-</b>
-<test>
-<op name="isValid" arg1="A">
-true
-</op>
-</test>
-<test>
-<op name="isValid" arg1="B">
-true
-</op>
-</test>
-<test>
-<op name="intersection" arg1="a" arg2="b">
-POLYGON((5417060.44 5658326.26,5417064.68 5658327.52,5417088.83
-5658341.83,5417111.76 5658345.51,5417121.66 5658349.58,5417121.88
-5658349.67,5417125.22 5658351.12,5417125.33011568
-5658351.15822058,5417131.761 5658353.388,5417137.589
-5658356.276,5417139.98755196 5658358.05460724,5417142.17
-5658359.67,5417145.96673439 5658364.22950947,5417146.599
-5658364.988,5417147.11101057 5658365.59150203,5417151.4
-5658370.64,5417151.13020611 5658371.00790076,5417150.853
-5658371.392,5417152.59740379 5658373.52810095,5417154.92
-5658376.37,5417155.18955732 5658376.89699971,5417155.18955735
-5658376.89699976,5417155.814 5658378.111,5417157.051
-5658380.297,5417158.004 5658382.304,5417159.014
-5658384.47,5417159.36623958 5658385.46469496,5417159.78
-5658386.62,5417160.63 5658389.28,5417161.5 5658399.49,5417160.773
-5658404.194,5417159.41 5658413.02,5417158.853 5658414.442,5417153.671
-5658427.659,5417153.67051161 5658427.6586943,5417153.67
-5658427.66,5417152.73 5658427.07,5417149.993 5658436.599,5417148.81
-5658439.42,5417149.233 5658439.67,5417148.36 5658440.81,5417146.41
-5658446.6,5417144.321 5658453.127,5417144.32092232
-5658448.75748237,5417157.22660867 5658448.5786084,5417157.128
-5658447.265,5417157.64950997 5658446.06368023,5417157.64950966
-5658446.06368096,5417157.64951003 5658446.06368011,5417158.31
-5658444.53,5417172.32 5658417.96,5417172.32037372
-5658417.96008538,5417172.322 5658417.957,5417174.99 5658418.57,5417175.23
-5658417.74,5417176.696 5658412.61,5417177.875 5658408.488,5417178.76
-5658405.39,5417178.1 5658393.55,5417178.08 5658393.36,5417177.11
-5658384.95,5417178.14836289 5658384.91508866,5417178.12
-5658384.83,5417177.91415162 5658383.811137,5417176.927
-5658378.944,5417176.73975924 5658378.01762057,5417176.73975913
-5658378.01762003,5417176.73975922 5658378.01762048,5417176.6
-5658377.34,5417176.51210558 5658376.89535766,5417176.428
-5658376.483,5417175.235 5658370.602,5417171.577
-5658362.886,5417171.26171711 5658361.81094338,5417170.76
-5658360.11,5417168.52 5658357.99,5417166.04 5658355.05,5417165.25343486
-5658353.89499119,5417164.137 5658352.264,5417162.642
-5658350.0862195,5417158.818 5658350.085,5417159.055
-5658349.214,5417156.78066259 5658348.15640899,5417156.7806617
-5658348.15640858,5417156.78066321 5658348.15640928,5417155.7525011
-5658347.6811561,5417155.161 5658348.532,5417152.26876422
-5658346.03495313,5417152.2687603 5658346.03494974,5417152.26877967
-5658346.03496647,5417149.03 5658343.24,5417148.78133333
-5658343.06701449,5417148.108 5658342.603,5417139.016
-5658338.009,5417126.791 5658331.833,5417121.76604007
-5658329.76778407,5417116.29 5658327.52,5417112.87 5658325.6,5417110.25
-5658324.13,5417106.60319005 5658322.07975996,5417106.071
-5658321.781,5417105.81727161 5658321.63852704,5417104.23
-5658320.75,5417093.61266829 5658315.18946314,5417093.266
-5658315.008,5417091.265 5658313.961,5417085.90749368
-5658311.15666617,5417085.34 5658310.86,5417060.44 5658326.26))
-</op>
-</test>
-</case>
-</run>
More information about the geos-commits mailing list
