[geos-commits] r3161 - in trunk: . capi tests/unit tests/unit/capi
svn_geos at osgeo.org
Tue Dec 21 03:55:29 EST 2010
Author: strk
Date: 2010-12-21 00:55:29 -0800 (Tue, 21 Dec 2010)
New Revision: 3161
Added:
trunk/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
trunk/NEWS
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/Makefile.am
Add GEOSRelatePatternMatch C-API interface [RT-SIGTA]
Modified: trunk/NEWS
--- trunk/NEWS 2010-12-20 11:34:43 UTC (rev 3160)
+++ trunk/NEWS 2010-12-21 08:55:29 UTC (rev 3161)
@@ -12,6 +12,7 @@
- CAPI: GEOSOrientationIndex
- CAPI: GEOSSharedPaths to find shared paths and their orientation
- CAPI: GEOSSnap
+ - CAPI: GEOSRelatePatternMatch
- PHP: new PHP5 bindings based on CAPI
- C++ API changes:
- Geometry::isWithinDistance method is now const
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2010-12-20 11:34:43 UTC (rev 3160)
+++ trunk/capi/geos_c.cpp 2010-12-21 08:55:29 UTC (rev 3161)
@@ -176,6 +176,12 @@
return GEOSRelatePattern_r( handle, g1, g2, pat );
+char
+GEOSRelatePatternMatch(const char *mat, const char *pat)
+ return GEOSRelatePatternMatch_r( handle, mat, pat );
char *
GEOSRelate(const Geometry *g1, const Geometry *g2)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-12-20 11:34:43 UTC (rev 3160)
+++ trunk/capi/geos_c.h.in 2010-12-21 08:55:29 UTC (rev 3161)
@@ -628,8 +628,8 @@
-extern char GEOS_DLL GEOSRelatePattern(const GEOSGeometry* g1, const GEOSGeometry* g2,
- const char *pat);
+extern char GEOS_DLL GEOSRelatePattern(const GEOSGeometry* g1, const GEOSGeometry* g2, const char *pat);
+extern char GEOS_DLL GEOSRelatePatternMatch(const char* mat, const char *pat);
extern char GEOS_DLL GEOSDisjoint(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSTouches(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSIntersects(const GEOSGeometry* g1, const GEOSGeometry* g2);
@@ -644,6 +644,9 @@
const char *pat);
+extern char GEOS_DLL GEOSRelatePatternMatch_r(GEOSContextHandle_t handle,
+ const char* mat,
+ const char *pat);
extern char GEOS_DLL GEOSDisjoint_r(GEOSContextHandle_t handle,
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-12-20 11:34:43 UTC (rev 3160)
+++ trunk/capi/geos_ts_c.cpp 2010-12-21 08:55:29 UTC (rev 3161)
@@ -525,6 +525,45 @@
return 2;
+char
+GEOSRelatePatternMatch_r(GEOSContextHandle_t extHandle, const char *mat,
+ const char *pat)
+ if ( 0 == extHandle )
+ return 2;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return 2;
+ try
+ using geos::geom::IntersectionMatrix;
+ std::string m(mat);
+ std::string p(pat);
+ IntersectionMatrix im(m);
+ bool result = im.matches(p);
+ return result;
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 2;
char *
GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *g2)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2010-12-20 11:34:43 UTC (rev 3160)
+++ trunk/tests/unit/Makefile.am 2010-12-21 08:55:29 UTC (rev 3161)
@@ -101,7 +101,8 @@
capi/GEOSOrientationIndex.cpp \
capi/GEOSLineString_PointTest.cpp \
capi/GEOSSnapTest.cpp \
- capi/GEOSSharedPathsTest.cpp
+ capi/GEOSSharedPathsTest.cpp \
+ capi/GEOSRelatePatternMatchTest.cpp
noinst_HEADERS = \
utility.h
Added: trunk/tests/unit/capi/GEOSRelatePatternMatchTest.cpp
--- trunk/tests/unit/capi/GEOSRelatePatternMatchTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSRelatePatternMatchTest.cpp 2010-12-21 08:55:29 UTC (rev 3161)
@@ -0,0 +1,102 @@
+// $Id$
+// Test Suite for C-API GEOSRelatePatternMatch
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosrelatepatternmatch_data
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosrelatepatternmatch_data()
+ initGEOS(notice, notice);
+ ~test_capigeosrelatepatternmatch_data()
+ finishGEOS();
+ typedef test_group<test_capigeosrelatepatternmatch_data> group;
+ typedef group::object object;
+ group test_capigeosrelatepatternmatch_group("capi::GEOSRelatePatternMatch");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ char ret = GEOSRelatePatternMatch("000000000", "*********");
+ ensure_equals(ret, char(1));
+ template<>
+ template<>
+ void object::test<2>()
+ char ret = GEOSRelatePatternMatch("000000000", "TTTTTTTTT");
+ template<>
+ template<>
+ void object::test<3>()
+ char ret = GEOSRelatePatternMatch("000000000", "000000000");
+ template<>
+ template<>
+ void object::test<4>()
+ char ret = GEOSRelatePatternMatch("000000000", "FFFFFFFFF");
+ ensure_equals(ret, char(0));
+ template<>
+ template<>
+ void object::test<5>()
+ const char* mat = "012TF012F";
+ char ret = GEOSRelatePatternMatch(mat, "TTTTFTTTF");
+ ret = GEOSRelatePatternMatch(mat, "TT1TFTTTF");
+} // namespace tut
More information about the geos-commits
