[geos-commits] r3162 - in trunk: . php php/test
svn_geos at osgeo.org
Wed Dec 22 04:42:40 EST 2010
Author: strk
Date: 2010-12-22 01:42:40 -0800 (Wed, 22 Dec 2010)
New Revision: 3162
trunk/.gitignore
trunk/php/geos.c
trunk/php/test/test.php
Expose GEOSRelateMatch to PHP api.
Modified: trunk/.gitignore
--- trunk/.gitignore 2010-12-21 08:55:29 UTC (rev 3161)
+++ trunk/.gitignore 2010-12-22 09:42:40 UTC (rev 3162)
@@ -44,3 +44,4 @@
doc/example
include/config.h
include/config.h.in
+php/test/phpunit
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-12-21 08:55:29 UTC (rev 3161)
+++ trunk/php/geos.c 2010-12-22 09:42:40 UTC (rev 3162)
@@ -42,12 +42,14 @@
PHP_FUNCTION(GEOSPolygonize);
PHP_FUNCTION(GEOSLineMerge);
PHP_FUNCTION(GEOSSharedPaths);
+PHP_FUNCTION(GEOSRelateMatch);
static function_entry geos_functions[] = {
PHP_FE(GEOSVersion, NULL)
PHP_FE(GEOSPolygonize, NULL)
PHP_FE(GEOSLineMerge, NULL)
PHP_FE(GEOSSharedPaths, NULL)
+ PHP_FE(GEOSRelateMatch, NULL)
{NULL, NULL, NULL}
@@ -2364,6 +2366,32 @@
setRelay(return_value, geom_out);
+ * bool GEOSRelateMatch(string matrix, string pattern)
+ char* mat = NULL;
+ int matlen;
+ char* pat = NULL;
+ int patlen;
+ int ret;
+ zend_bool retBool;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "ss",
+ &mat, &matlen, &pat, &patlen) == FAILURE)
+ RETURN_NULL();
+ ret = GEOSRelatePatternMatch(mat, pat);
+ if ( ret == 2 ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ retBool = ret;
+ RETURN_BOOL(retBool);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-12-21 08:55:29 UTC (rev 3161)
+++ trunk/php/test/test.php 2010-12-22 09:42:40 UTC (rev 3162)
@@ -2046,4 +2046,13 @@
+ public function testGEOSRelateMatch()
+ $this->assertTrue(GEOSRelateMatch('0FFFFFFF2', '0FFFFFFF2'));
+ $this->assertTrue(GEOSRelateMatch('0FFFFFFF2', '0FFFFFFF*'));
+ $this->assertTrue(GEOSRelateMatch('0FFFFFFF2', 'TFFFFFFF2'));
+ $this->assertFalse(GEOSRelateMatch('0FFFFFFF2', '0FFFFFFFF'));
More information about the geos-commits
