[geos-commits] r3163 - in trunk: src/operation/sharedpaths
tests/unit/operation/sharedpaths
svn_geos at osgeo.org
Wed Dec 22 11:28:08 EST 2010
Author: strk
Date: 2010-12-22 08:28:08 -0800 (Wed, 22 Dec 2010)
New Revision: 3163
trunk/src/operation/sharedpaths/SharedPathsOp.cpp
trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
Fix computation of shared path direction when path starts or ends on the first-last point of a closed line. Fixes ticket #391. Includes automated testing.
Modified: trunk/src/operation/sharedpaths/SharedPathsOp.cpp
--- trunk/src/operation/sharedpaths/SharedPathsOp.cpp 2010-12-22 09:42:40 UTC (rev 3162)
+++ trunk/src/operation/sharedpaths/SharedPathsOp.cpp 2010-12-22 16:28:08 UTC (rev 3163)
@@ -147,8 +147,21 @@
const Coordinate& pt1 = edge.getCoordinateN(0);
const Coordinate& pt2 = edge.getCoordinateN(1);
- LinearLocation l1 = LocationIndexOfPoint::indexOf(&geom, pt1);
- LinearLocation l2 = LocationIndexOfPoint::indexOf(&geom, pt2);
+ * We move the coordinate somewhat closer, to avoid
+ * vertices of the geometry being checked (geom).
+ * This is mostly only needed when one of the two points
+ * of the edge is an endpoint of a _closed_ geom.
+ * We have an unit test for this...
+ Coordinate pt1i = LinearLocation::pointAlongSegmentByFraction(pt1, pt2, 0.1);
+ Coordinate pt2i = LinearLocation::pointAlongSegmentByFraction(pt1, pt2, 0.9);
+ LinearLocation l1 = LocationIndexOfPoint::indexOf(&geom, pt1i);
+ LinearLocation l2 = LocationIndexOfPoint::indexOf(&geom, pt2i);
return l1.compareTo(l2) < 0;
Modified: trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
--- trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp 2010-12-22 09:42:40 UTC (rev 3162)
+++ trunk/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp 2010-12-22 16:28:08 UTC (rev 3163)
@@ -322,5 +322,69 @@
ensure(forwDir.empty());
+ // line - line_closed_no_rhr
+ template<> template<>
+ void object::test<18>()
+ GeomPtr g0(wktreader.read("LINESTRING( 0 0, 10 0)"));
+ GeomPtr g1(wktreader.read("LINESTRING( 0 0, 10 0, 10 10, 0 10, 0 0 )"));
+ forwDir.clear(); backDir.clear();
+ SharedPathsOp::sharedPathsOp(*g0, *g1, forwDir, backDir);
+ ensure_equals(forwDir.size(), 1u);
+ ensure_equals(wktwriter.write(forwDir[0]), "LINESTRING (0 0, 10 0)");
+ SharedPathsOp::clearEdges(forwDir);
+ ensure(backDir.empty());
+ // line_closed_no_rhr - line
+ void object::test<19>()
+ GeomPtr g0(wktreader.read("LINESTRING( 0 0, 10 0, 10 10, 0 10, 0 0 )"));
+ GeomPtr g1(wktreader.read("LINESTRING( 0 0, 10 0)"));
+ // line - line_closed_rhr (see ticket #391)
+ void object::test<20>()
+ GeomPtr g1(wktreader.read("LINESTRING( 0 0, 0 10, 10 10, 10 0, 0 0 )"));
+ ensure_equals(backDir.size(), 1u);
+ ensure_equals(wktwriter.write(backDir[0]), "LINESTRING (0 0, 10 0)");
+ SharedPathsOp::clearEdges(backDir);
+ ensure(forwDir.empty());
+ // line_closed_rhr - line
+ void object::test<21>()
+ GeomPtr g0(wktreader.read("LINESTRING( 0 0, 0 10, 10 10, 10 0, 0 0 )"));
+ ensure_equals(wktwriter.write(backDir[0]), "LINESTRING (10 0, 0 0)");
} // namespace tut
More information about the geos-commits
