[geos-commits] r3031 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 04:32:29 EDT 2010
Author: strk
Date: 2010-06-20 08:32:29 +0000 (Sun, 20 Jun 2010)
New Revision: 3031
trunk/php/TODO
trunk/php/geos.c
trunk/php/test/test.php
Polygonize (testing need further review for a possible bug in core lib)
Modified: trunk/php/TODO
--- trunk/php/TODO 2010-06-19 21:38:23 UTC (rev 3030)
+++ trunk/php/TODO 2010-06-20 08:32:29 UTC (rev 3031)
@@ -1,5 +1,7 @@
In order of priority
+- Equip GEOSGeometry with standard string output
+ (and make sure it comes out on var_dump)
- Complete interfaces of Geometry
- Add interfaces for WKBReader/WKBWriter ?
- Doxygen based documentation ?
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-19 21:38:23 UTC (rev 3030)
+++ trunk/php/geos.c 2010-06-20 08:32:29 UTC (rev 3031)
@@ -188,6 +188,7 @@
PHP_METHOD(Geometry, pointOnSurface);
PHP_METHOD(Geometry, centroid);
PHP_METHOD(Geometry, relate);
+PHP_METHOD(Geometry, polygonize);
PHP_METHOD(Geometry, numGeometries);
@@ -206,6 +207,7 @@
PHP_ME(Geometry, pointOnSurface, NULL, 0)
PHP_ME(Geometry, centroid, NULL, 0)
PHP_ME(Geometry, relate, NULL, 0)
+ PHP_ME(Geometry, polygonize, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -215,6 +217,41 @@
static zend_object_handlers Geometry_object_handlers;
+ * Return a newly created array zval containing
+ * a clone of all components of given geometry
+ * NOTE: collection components are not descended into
+static zval*
+dumpGeometry(GEOSGeometry* g)
+ zval *array;
+ int ngeoms, i;
+ MAKE_STD_ZVAL(array);
+ array_init(array);
+ ngeoms = GEOSGetNumGeometries(g);
+ for (i=0; i<ngeoms; ++i)
+ zval *tmp;
+ GEOSGeometry* cc;
+ const GEOSGeometry* c = GEOSGetGeometryN(g, i);
+ if ( ! c ) continue; /* should get an exception */
+ /* we _need_ to clone as this one is owned by 'g' */
+ cc = GEOSGeom_clone(c);
+ if ( ! cc ) continue; /* should get an exception */
+ MAKE_STD_ZVAL(tmp);
+ object_init_ex(tmp, Geometry_ce_ptr);
+ setRelay(tmp, cc);
+ add_next_index_zval(array, tmp);
+ return array;
static void
Geometry_dtor (void *object TSRMLS_DC)
@@ -614,6 +651,65 @@
+ * array GEOSGeometry::polygonize()
+ * The returned array contains the following elements:
+ * - 'rings'
+ * Type: array of GEOSGeometry
+ * Rings that can be formed by the costituent
+ * linework of geometry.
+ * - 'cut_edges' (optional)
+ * Edges which are connected at both ends but
+ * which do not form part of polygon.
+ * - 'dangles'
+ * Edges which have one or both ends which are
+ * not incident on another edge endpoint
+ * - 'invalid_rings'
+ * Edges which form rings which are invalid
+ * (e.g. the component lines contain a self-intersection)
+ GEOSGeometry *this;
+ GEOSGeometry *rings;
+ GEOSGeometry *cut_edges;
+ GEOSGeometry *dangles;
+ GEOSGeometry *invalid_rings;
+ zval *rings_array;
+ zval *cut_edges_array;
+ zval *dangles_array;
+ zval *invalid_rings_array;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ rings = GEOSPolygonize_full(this, &cut_edges, &dangles, &invalid_rings);
+ if ( ! rings ) RETURN_NULL(); /* should get an exception first */
+ /* return value should be an array */
+ array_init(return_value);
+ rings_array = dumpGeometry(rings);
+ GEOSGeom_destroy(rings);
+ cut_edges_array = dumpGeometry(cut_edges);
+ GEOSGeom_destroy(cut_edges);
+ dangles_array = dumpGeometry(dangles);
+ GEOSGeom_destroy(dangles);
+ invalid_rings_array = dumpGeometry(invalid_rings);
+ GEOSGeom_destroy(invalid_rings);
+ add_assoc_zval(return_value, "rings", rings_array);
+ add_assoc_zval(return_value, "cut_edges", cut_edges_array);
+ add_assoc_zval(return_value, "dangles", dangles_array);
+ add_assoc_zval(return_value, "invalid_rings", invalid_rings_array);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-19 21:38:23 UTC (rev 3030)
+++ trunk/php/test/test.php 2010-06-20 08:32:29 UTC (rev 3031)
@@ -894,4 +894,65 @@
$this->assertEquals(FALSE, $ret);
+ public function testGeometry_polygonize()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g = $reader->read('GEOMETRYCOLLECTION(
+ LINESTRING(0 0, 10 10),
+ LINESTRING(185 221, 100 100),
+ LINESTRING(185 221, 88 275, 180 316),
+ LINESTRING(185 221, 292 281, 180 316),
+ LINESTRING(189 98, 83 187, 185 221),
+ LINESTRING(189 98, 325 168, 185 221))
+ $g2 = $reader->read('POINT(0 0)');
+ $g = $g->union($g2); /* Make sure linestrings are noded */
+ $ret = $g->polygonize();
+ * NOTE: the following expected results are suspicious
+ * due to the duplicated dangle and lack of a cut edge
+ //var_dump($ret);
+ $this->assertEquals('array', gettype($ret));
+ $this->assertEquals('array', gettype($ret['rings']));
+ $this->assertEquals('array', gettype($ret['cut_edges']));
+ $this->assertEquals('array', gettype($ret['dangles']));
+ $this->assertEquals('array', gettype($ret['invalid_rings']));
+ $this->assertEquals(3, count($ret['rings']));
+'POLYGON ((185 221, 132 146, 83 187, 185 221))'
+ , $writer->write($ret['rings'][0]));
+'POLYGON ((132 146, 185 221, 325 168, 189 98, 132 146))'
+ , $writer->write($ret['rings'][1]));
+'POLYGON ((185 221, 88 275, 180 316, 292 281, 185 221))'
+ , $writer->write($ret['rings'][2]));
+ $this->assertEquals(0, count($ret['cut_edges']));
+ $this->assertEquals(3, count($ret['dangles']));
+'LINESTRING (132 146, 100 100)'
+ , $writer->write($ret['dangles'][0]));
+'LINESTRING (0 0, 10 10)'
+ , $writer->write($ret['dangles'][1]));
+ , $writer->write($ret['dangles'][2]));
+ $this->assertEquals(0, count($ret['invalid_rings']));
More information about the geos-commits
