[geos-commits] r3032 - trunk/php
svn_geos at osgeo.org
Sun Jun 20 04:50:44 EDT 2010
Author: strk
Date: 2010-06-20 08:50:44 +0000 (Sun, 20 Jun 2010)
New Revision: 3032
trunk/php/TODO
trunk/php/geos.c
Geometry.__toString for easier debuggin
Modified: trunk/php/TODO
--- trunk/php/TODO 2010-06-20 08:32:29 UTC (rev 3031)
+++ trunk/php/TODO 2010-06-20 08:50:44 UTC (rev 3032)
@@ -1,7 +1,7 @@
In order of priority
-- Equip GEOSGeometry with standard string output
- (and make sure it comes out on var_dump)
+- Find a way to have GEOSGeometry contents shown
+ on var_dump
- Complete interfaces of Geometry
- Add interfaces for WKBReader/WKBWriter ?
- Doxygen based documentation ?
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-20 08:32:29 UTC (rev 3031)
+++ trunk/php/geos.c 2010-06-20 08:50:44 UTC (rev 3032)
@@ -175,6 +175,7 @@
/* -- class GEOSGeometry -------------------- */
PHP_METHOD(Geometry, __construct);
+PHP_METHOD(Geometry, __toString);
PHP_METHOD(Geometry, project);
PHP_METHOD(Geometry, interpolate);
PHP_METHOD(Geometry, buffer);
@@ -194,6 +195,7 @@
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
+ PHP_ME(Geometry, __toString, NULL, 0)
PHP_ME(Geometry, project, NULL, 0)
PHP_ME(Geometry, interpolate, NULL, 0)
PHP_ME(Geometry, buffer, NULL, 0)
@@ -278,6 +280,35 @@
+ GEOSGeometry *geom;
+ GEOSWKTWriter *writer;
+ char *wkt;
+ char *ret;
+ geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ writer = GEOSWKTWriter_create();
+ /* NOTE: if we get an exception before reaching
+ * GEOSWKTWriter_destory below we'll be leaking memory.
+ * One fix could be storing the object in a refcounted
+ * zval.
+ GEOSWKTWriter_setTrim(writer, 1);
+ wkt = GEOSWKTWriter_write(writer, geom);
+ /* we'll probably get an exception if wkt is null */
+ if ( ! wkt ) RETURN_NULL();
+ GEOSWKTWriter_destroy(writer);
+ ret = estrdup(wkt);
+ GEOSFree(wkt);
+ RETURN_STRING(ret, 0);
PHP_METHOD(Geometry, numGeometries)
GEOSGeometry *geom;
More information about the geos-commits
