[geos-commits] r2934 - in trunk: . cmake
svn_geos at osgeo.org
Fri Mar 5 20:49:46 EST 2010
Author: mloskot
Date: 2010-03-05 20:49:44 -0500 (Fri, 05 Mar 2010)
New Revision: 2934
Added:
trunk/cmake/cmake_uninstall.cmake.in
trunk/CMakeLists.txt
Added cmake/cmake_uninstall.cmake.in script and configured make uninstall target for CMake configuration (#317)
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2010-03-03 07:21:06 UTC (rev 2933)
+++ trunk/CMakeLists.txt 2010-03-06 01:49:44 UTC (rev 2934)
@@ -15,7 +15,8 @@
cmake_minimum_required(VERSION 2.6)
if(NOT CMAKE_VERSION)
- set(CMAKE_VERSION "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
+ set(CMAKE_VERSION
+ "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
endif()
# Location of custom CMake modules with macros used by GEOS
@@ -271,9 +272,16 @@
add_subdirectory(tools)
-# Setup installation of common files not specific to any target
+# Install/Uninstall
+configure_file("${CMAKE_CURRENT_SOURCE_DIR}/cmake/cmake_uninstall.cmake.in"
+ "${CMAKE_CURRENT_BINARY_DIR}/cmake/cmake_uninstall.cmake"
+ IMMEDIATE @ONLY)
+add_custom_target(uninstall
+ "${CMAKE_COMMAND}" -P "${CMAKE_CURRENT_BINARY_DIR}/cmake/cmake_uninstall.cmake")
# DEBUG settings - TODO: make a summary
Added: trunk/cmake/cmake_uninstall.cmake.in
--- trunk/cmake/cmake_uninstall.cmake.in (rev 0)
+++ trunk/cmake/cmake_uninstall.cmake.in 2010-03-06 01:49:44 UTC (rev 2934)
@@ -0,0 +1,49 @@
+# $Id: CMakeLists.txt 2920 2010-02-21 17:11:38Z mloskot $
+# This file is a part of CMake build configuration of GEOS library
+# Defines commands used by make uninstall target of CMake build configuration.
+# Author: Credit to the CMake mailing list archives for providing this solution.
+# Modifications: Mateusz Loskot <mateusz at loskot.net>
+if(NOT EXISTS "@CMAKE_CURRENT_BINARY_DIR@/install_manifest.txt")
+ message(FATAL_ERROR
+ "Cannot find install manifest:
+ @CMAKE_CURRENT_BINARY_DIR@/install_manifest.txt")
+endif()
+file(READ "@CMAKE_CURRENT_BINARY_DIR@/install_manifest.txt" files)
+string(REGEX REPLACE "\n" ";" files "${files}")
+set(GEOS_INCLUDE_DIR)
+foreach(file ${files})
+ if(${file} MATCHES "geos.h")
+ get_filename_component(GEOS_INCLUDE_DIR ${file} PATH)
+ endif()
+ message(STATUS "Uninstalling $ENV{DESTDIR}${file}")
+ if(NOT EXISTS "$ENV{DESTDIR}${file}")
+ message(STATUS "File \"$ENV{DESTDIR}${file}\" does not exist.")
+ message(STATUS "\tTrying to execute remove command anyway.")
+ endif()
+ exec_program("@CMAKE_COMMAND@" ARGS "-E remove \"$ENV{DESTDIR}${file}\""
+ OUTPUT_VARIABLE rm_out
+ RETURN_VALUE rm_retval)
+ if(NOT "${rm_retval}" STREQUAL 0)
+ message(FATAL_ERROR "Problem when removing \"$ENV{DESTDIR}${file}\"")
+ endif()
+endforeach()
+message(STATUS "Deleting ${GEOS_INCLUDE_DIR} directory")
+exec_program("@CMAKE_COMMAND@"
+ ARGS "-E remove_directory \"${GEOS_INCLUDE_DIR}\""
+if(NOT "${rm_retval}" STREQUAL 0)
+ message(FATAL_ERROR "Problem when removing \"${GEOS_INCLUDE_DIR}\"")
+endif()
More information about the geos-commits
