[geos-commits] r2935 - trunk
svn_geos at osgeo.org
Sun Mar 7 06:39:05 EST 2010
Author: strk
Date: 2010-03-07 06:39:03 -0500 (Sun, 07 Mar 2010)
New Revision: 2935
trunk/README
Apply slightly modified patch by mwtoews (#344)
Modified: trunk/README
--- trunk/README 2010-03-06 01:49:44 UTC (rev 2934)
+++ trunk/README 2010-03-07 11:39:03 UTC (rev 2935)
@@ -2,13 +2,20 @@
Unix
- # ./configure
- # make
- # make check
- # make install
+Using Autotools:
+ ./autogen.sh # in ${srcdir}, if obtained from SVN
+ ${srcdir}/configure # in build dir
+Using CMake:
+ cmake ${srcdir} # in build dir
+Now, all versions:
+ make
+ make check
+ make install
Win32
@@ -38,47 +45,46 @@
To compile programs against the C lib (recommended):
- CFLAGS += `geos-config --cflags`
- LDFLAGS += `geos-config --ldflags` -lgeos_c
- #include <geos_c.h>
+ CFLAGS += `geos-config --cflags`
+ LDFLAGS += `geos-config --ldflags` -lgeos_c
+ #include <geos_c.h>
Example usage:
- capi/geostest.c contains basic usage
- examples.
+ capi/geostest.c contains basic usage examples.
Using the C++ interface (discouraged)
To compile programs against the C++ lib:
- #include <geos.h>
+ #include <geos.h>
Example usage:
- doc/example.cpp contains basic usage
- examples.
+ doc/example.cpp contains basic usage examples.
Scripting language bindings
-Ruby bindings are fully supported. To build, use the --enable-ruby option when
-configuring:
+Ruby bindings are fully supported. To build, use the --enable-ruby option
+when configuring:
- # ./configure ... --enable-ruby
+ ./configure ... --enable-ruby
Since version 3.0, the Python bindings are unsupported. Recommended options:
1. Become or recruit a new maintainer.
- 2. Use Shapely (http://pypi.python.org/pypi/Shapely) with Python versions 2.4 or greater.
+ 2. Use Shapely (http://pypi.python.org/pypi/Shapely) with Python
+ versions 2.4 or greater.
3. Simply call functions from libgeos_c via Python ctypes.
DOCUMENTATION
- # cd doc; make doxygen-html
+ cd doc; make doxygen-html
- http://trac.osgeo.org/geos
+ http://trac.osgeo.org/geos
More information about the geos-commits
