[geos-commits] r2936 - in trunk: include/geos/operation/valid
src/operation/valid tests/xmltester/tests/general
svn_geos at osgeo.org
Wed Mar 10 04:34:11 EST 2010
Author: strk
Date: 2010-03-10 04:34:02 -0500 (Wed, 10 Mar 2010)
New Revision: 2936
trunk/include/geos/operation/valid/IsValidOp.h
trunk/src/operation/valid/IsValidOp.cpp
trunk/tests/xmltester/tests/general/TestValid.xml
Sync TestValid xml from JTS, review IsValidOp to be in sync with current JTS trunk.
Modified: trunk/include/geos/operation/valid/IsValidOp.h
--- trunk/include/geos/operation/valid/IsValidOp.h 2010-03-07 11:39:03 UTC (rev 2935)
+++ trunk/include/geos/operation/valid/IsValidOp.h 2010-03-10 09:34:02 UTC (rev 2936)
@@ -15,7 +15,7 @@
- * Last port: operation/valid/IsValidOp.java rev. 1.41 (JTS-1.10)
+ * Last port: operation/valid/IsValidOp.java rev. 38 (JTS-1.11+)
@@ -65,8 +65,6 @@
/// the base Geometry to be validated
const geom::Geometry *parentGeometry;
- bool isChecked;
// CHECKME: should this really be a pointer ?
TopologyValidationError* validErr;
@@ -214,7 +212,6 @@
IsValidOp(const geom::Geometry *geom)
parentGeometry(geom),
- isChecked(false),
validErr(NULL),
isSelfTouchingRingFormingHoleValid(false)
Modified: trunk/src/operation/valid/IsValidOp.cpp
--- trunk/src/operation/valid/IsValidOp.cpp 2010-03-07 11:39:03 UTC (rev 2935)
+++ trunk/src/operation/valid/IsValidOp.cpp 2010-03-10 09:34:02 UTC (rev 2936)
@@ -15,7 +15,7 @@
@@ -115,8 +115,6 @@
void
IsValidOp::checkValid(const Geometry *g)
- if (isChecked) return;
//assert( validErr == NULL );
validErr=NULL;
@@ -133,7 +131,6 @@
else if (0 != (gc=dynamic_cast<const GeometryCollection *>(g)))
checkValid(gc);
else throw util::UnsupportedOperationException();
- //isChecked=true;
Modified: trunk/tests/xmltester/tests/general/TestValid.xml
--- trunk/tests/xmltester/tests/general/TestValid.xml 2010-03-07 11:39:03 UTC (rev 2935)
+++ trunk/tests/xmltester/tests/general/TestValid.xml 2010-03-10 09:34:02 UTC (rev 2936)
@@ -78,7 +78,7 @@
</case>
<case>
- <desc>L - linestring with two identical points </desc>
+ <desc>mL - MultiLinestring with two identical points in second component</desc>
<a>MULTILINESTRING((1 1, 0 0), (0 0, 0 0))</a>
<test>
<op name="isValid" arg1="A"> false </op>
More information about the geos-commits
