[geos-commits] r2937 - in trunk: . capi tests/unit tests/unit/capi
svn_geos at osgeo.org
Fri Mar 12 02:54:47 EST 2010
Author: strk
Date: 2010-03-12 02:54:45 -0500 (Fri, 12 Mar 2010)
New Revision: 2937
Added:
trunk/tests/unit/capi/GEOSOrientationIndex.cpp
trunk/NEWS
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/Makefile.am
Expose GEOSOrientationIndex to C-API
Modified: trunk/NEWS
--- trunk/NEWS 2010-03-10 09:34:02 UTC (rev 2936)
+++ trunk/NEWS 2010-03-12 07:54:45 UTC (rev 2937)
@@ -9,6 +9,7 @@
- CAPI: GEOSGetGeometryN support for single geometries
- CAPI: GEOSPolygonize_full to return all informations computed by
the polygonizer
+ - CAPI: GEOSOrientationIndex
- C++ API changes:
- Polygonizer::getCutEdges returns by const ref
- Polygonizer::getDangles returns by const ref
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2010-03-10 09:34:02 UTC (rev 2936)
+++ trunk/capi/geos_c.cpp 2010-03-12 07:54:45 UTC (rev 2937)
@@ -967,4 +967,11 @@
return GEOSGeom_createEmptyPolygon_r(handle);
+int
+GEOSOrientationIndex(double Ax, double Ay, double Bx, double By,
+ double Px, double Py)
+ return GEOSOrientationIndex_r(handle, Ax, Ay, Bx, By, Px, Py);
} /* extern "C" */
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-03-10 09:34:02 UTC (rev 2936)
+++ trunk/capi/geos_c.h.in 2010-03-12 07:54:45 UTC (rev 2937)
@@ -909,7 +909,26 @@
const GEOSGeometry *g2,
double densifyFrac, double *dist);
+ * Algorithms
+/* Walking from A to B:
+ * return -1 if reaching P takes a counter-clockwise (left) turn
+ * return 1 if reaching P takes a clockwise (right) turn
+ * return 0 if P is collinear with A-B
+ * On exceptions, return 2.
+extern int GEOSOrientationIndex(double Ax, double Ay, double Bx, double By,
+ double Px, double Py);
+extern int GEOSOrientationIndex_r(GEOSContextHandle_t handle,
+ double Ax, double Ay, double Bx, double By, double Px, double Py);
* Reader and Writer APIs
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-03-10 09:34:02 UTC (rev 2936)
+++ trunk/capi/geos_ts_c.cpp 2010-03-12 07:54:45 UTC (rev 2937)
@@ -32,6 +32,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/Coordinate.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/geom/Envelope.h>
#include <geos/index/strtree/STRtree.h>
@@ -41,6 +42,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/io/WKBWriter.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <geos/algorithm/CGAlgorithms.h>
#include <geos/simplify/DouglasPeuckerSimplifier.h>
#include <geos/simplify/TopologyPreservingSimplifier.h>
#include <geos/operation/valid/IsValidOp.h>
@@ -4809,6 +4811,37 @@
+int GEOSOrientationIndex_r(GEOSContextHandle_t /*handle*/,
+ using geos::geom::Coordinate;
+ using geos::algorithm::CGAlgorithms;
+ if ( 0 == extHandle )
+ return 2;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return 2;
+ try
+ Coordinate A(Ax, Ay);
+ Coordinate B(Bx, By);
+ Coordinate P(Px, Py);
+ return CGAlgorithms::orientationIndex(A, B, P);
+ catch (...)
+ handle->ERROR_MESSAGE("%s", e.what());
+ return 2;
} /* extern "C" */
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2010-03-10 09:34:02 UTC (rev 2936)
+++ trunk/tests/unit/Makefile.am 2010-03-12 07:54:45 UTC (rev 2937)
@@ -93,7 +93,8 @@
capi/GEOSPolygonizer_getCutEdgesTest.cpp \
capi/GEOSBufferTest.cpp \
capi/GEOSGeom_create.cpp \
- capi/GEOSGeom_extractUniquePointsTest.cpp
+ capi/GEOSGeom_extractUniquePointsTest.cpp \
+ capi/GEOSOrientationIndex.cpp
noinst_HEADERS = \
utility.h
Added: trunk/tests/unit/capi/GEOSOrientationIndex.cpp
--- trunk/tests/unit/capi/GEOSOrientationIndex.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSOrientationIndex.cpp 2010-03-12 07:54:45 UTC (rev 2937)
@@ -0,0 +1,162 @@
+// $Id$
+// Test Suite for C-API GEOSOrientationIndex*
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <string>
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosorientationindex_data
+ GEOSContextHandle_t handle_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosorientationindex_data()
+ : handle_(initGEOS_r(notice, notice))
+ ~test_capigeosorientationindex_data()
+ finishGEOS_r(handle_);
+ typedef test_group<test_capigeosorientationindex_data> group;
+ typedef group::object object;
+ group test_capigeosorientationindex_group("capi::GEOSOrientationIndex");
+ // Test Cases
+ // Interior, collinear
+ template<>
+ template<>
+ void object::test<1>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 5, 0);
+ ensure_equals(ret, 0);
+ // Boundary (last point), collinear
+ template<>
+ template<>
+ void object::test<2>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 10, 0);
+ // Boundary (first point), collinear
+ template<>
+ template<>
+ void object::test<3>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 0, 0);
+ // Exterior, before first point, collinear
+ template<>
+ template<>
+ void object::test<4>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, -5, 0);
+ // Exterior, after last point, collinear
+ template<>
+ template<>
+ void object::test<5>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 0, 20, 0);
+ // Exterior, in bounding box, turn left
+ template<>
+ template<>
+ void object::test<6>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 6);
+ ensure_equals(ret, 1);
+ // Exterior, outside bounding box, turn left
+ template<>
+ template<>
+ void object::test<7>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 20);
+ // Exterior, in bounding box, turn right
+ template<>
+ template<>
+ void object::test<8>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 3);
+ ensure_equals(ret, -1);
+ template<>
+ template<>
+ void object::test<9>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, -2);
+ // Exterior, outside bounding box, very close to collinear, turn left
+ template<>
+ template<>
+ void object::test<10>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 1000001);
+ // Exterior, outside bounding box, very close to collinear, turn right
+ template<>
+ template<>
+ void object::test<11>()
+ int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 999999);
+} // namespace tut
More information about the geos-commits
