[geos-commits] r2938 - in trunk: capi tests/unit/capi
svn_geos at osgeo.org
Sat Mar 13 17:07:18 EST 2010
Author: strk
Date: 2010-03-13 17:07:17 -0500 (Sat, 13 Mar 2010)
New Revision: 2938
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/capi/GEOSOrientationIndex.cpp
Fix GEOSOrientationIndex implementation and testcase. Closes ticket #335.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-03-12 07:54:45 UTC (rev 2937)
+++ trunk/capi/geos_ts_c.cpp 2010-03-13 22:07:17 UTC (rev 2938)
@@ -4811,9 +4811,11 @@
-int GEOSOrientationIndex_r(GEOSContextHandle_t /*handle*/,
+int GEOSOrientationIndex_r(GEOSContextHandle_t extHandle,
double Ax, double Ay, double Bx, double By, double Px, double Py)
+ GEOSContextHandleInternal_t *handle = 0;
using geos::geom::Coordinate;
using geos::algorithm::CGAlgorithms;
@@ -4822,7 +4824,6 @@
return 2;
- GEOSContextHandleInternal_t *handle = 0;
handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if ( 0 == handle->initialized )
@@ -4835,11 +4836,17 @@
Coordinate B(Bx, By);
Coordinate P(Px, Py);
return CGAlgorithms::orientationIndex(A, B, P);
- catch (...)
+ catch (const std::exception &e)
handle->ERROR_MESSAGE("%s", e.what());
return 2;
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 2;
Modified: trunk/tests/unit/capi/GEOSOrientationIndex.cpp
--- trunk/tests/unit/capi/GEOSOrientationIndex.cpp 2010-03-12 07:54:45 UTC (rev 2937)
+++ trunk/tests/unit/capi/GEOSOrientationIndex.cpp 2010-03-13 22:07:17 UTC (rev 2938)
@@ -61,7 +61,7 @@
template<>
void object::test<1>()
- int ret = GEOSOrientationIndex(0, 0, 10, 0, 5, 0);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 5, 0);
ensure_equals(ret, 0);
@@ -70,7 +70,7 @@
template<>
void object::test<2>()
- int ret = GEOSOrientationIndex(0, 0, 10, 0, 10, 0);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 10, 0);
@@ -79,7 +79,7 @@
template<>
void object::test<3>()
- int ret = GEOSOrientationIndex(0, 0, 10, 0, 0, 0);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 0, 0);
@@ -88,7 +88,7 @@
template<>
void object::test<4>()
- int ret = GEOSOrientationIndex(0, 0, 10, 0, -5, 0);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, -5, 0);
@@ -97,7 +97,7 @@
template<>
void object::test<5>()
- int ret = GEOSOrientationIndex(0, 0, 10, 0, 20, 0);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 0, 20, 0);
@@ -106,7 +106,7 @@
template<>
void object::test<6>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 6);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 6);
ensure_equals(ret, 1);
@@ -115,7 +115,7 @@
template<>
void object::test<7>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 20);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 20);
@@ -124,7 +124,7 @@
template<>
void object::test<8>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, 3);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, 3);
ensure_equals(ret, -1);
@@ -133,7 +133,7 @@
template<>
void object::test<9>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 5, -2);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 5, -2);
@@ -142,7 +142,7 @@
template<>
void object::test<10>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 1000001);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 1000000, 1000001);
@@ -151,7 +151,7 @@
template<>
void object::test<11>()
- int ret = GEOSOrientationIndex(0, 0, 10, 10, 1000000, 999999);
+ int ret = GEOSOrientationIndex_r(handle_, 0, 0, 10, 10, 1000000, 999999);
More information about the geos-commits
