[geos-commits] r3115 - in trunk/tests/unit: capi io
svn_geos at osgeo.org
Fri Oct 15 11:20:02 EDT 2010
Author: mloskot
Date: 2010-10-15 08:20:02 -0700 (Fri, 15 Oct 2010)
New Revision: 3115
trunk/tests/unit/capi/GEOSGeom_create.cpp
trunk/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
trunk/tests/unit/io/WKTReaderTest.cpp
Visual C++ warnings cleanup
Modified: trunk/tests/unit/capi/GEOSGeom_create.cpp
--- trunk/tests/unit/capi/GEOSGeom_create.cpp 2010-10-15 15:19:27 UTC (rev 3114)
+++ trunk/tests/unit/capi/GEOSGeom_create.cpp 2010-10-15 15:20:02 UTC (rev 3115)
@@ -64,9 +64,9 @@
void object::test<1>()
geom1_ = GEOSGeom_createEmptyPoint_r(handle_);
- ensure(GEOSisEmpty_r(handle_, geom1_));
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POINT);
- GEOSGeom_destroy(geom1_); geom1_=0;
+ ensure(0 != GEOSisEmpty_r(handle_, geom1_));
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POINT);
+ GEOSGeom_destroy(geom1_); geom1_=0;
// EMPTY linestring
@@ -75,9 +75,9 @@
void object::test<2>()
geom1_ = GEOSGeom_createEmptyLineString_r(handle_);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_LINESTRING);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_LINESTRING);
@@ -87,9 +87,9 @@
void object::test<3>()
geom1_ = GEOSGeom_createEmptyPolygon_r(handle_);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POLYGON);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POLYGON);
// EMPTY multipoint
@@ -98,9 +98,9 @@
void object::test<4>()
geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOINT);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOINT);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOINT);
// EMPTY multilinestring
@@ -109,9 +109,9 @@
void object::test<5>()
geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTILINESTRING);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTILINESTRING);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTILINESTRING);
// EMPTY multipolygon
@@ -120,9 +120,9 @@
void object::test<6>()
geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOLYGON);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOLYGON);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOLYGON);
// EMPTY collection
@@ -131,9 +131,9 @@
void object::test<7>()
geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_GEOMETRYCOLLECTION);
- ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_GEOMETRYCOLLECTION);
Modified: trunk/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp
--- trunk/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp 2010-10-15 15:19:27 UTC (rev 3114)
+++ trunk/tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp 2010-10-15 15:20:02 UTC (rev 3115)
@@ -73,7 +73,7 @@
geom1_ = GEOSGeomFromWKT_r(handle_, "POLYGON EMPTY");
/* ensure_equals(GEOSGetNumGeometries_r(handle_, geom2_), 0); */
geom3_ = GEOSGeom_extractUniquePoints_r(handle_, geom1_);
- ensure(GEOSisEmpty_r(handle_, geom3_));
+ ensure(0 != GEOSisEmpty_r(handle_, geom3_));
template<>
@@ -84,7 +84,7 @@
geom2_ = GEOSGeomFromWKT_r(handle_, "MULTIPOINT(0 0, 1 1)");
- ensure(GEOSEquals_r(handle_, geom3_, geom2_));
+ ensure(0 != GEOSEquals_r(handle_, geom3_, geom2_));
template<>
@@ -95,7 +95,7 @@
geom2_ = GEOSGeomFromWKT_r(handle_, "MULTIPOINT(0 0, 1 1, 2 2, 5 5, 0 2)");
Modified: trunk/tests/unit/io/WKTReaderTest.cpp
--- trunk/tests/unit/io/WKTReaderTest.cpp 2010-10-15 15:19:27 UTC (rev 3114)
+++ trunk/tests/unit/io/WKTReaderTest.cpp 2010-10-15 15:20:02 UTC (rev 3115)
@@ -132,6 +132,7 @@
ensure( !"Didn't get expected exception" );
} catch (const geos::util::IllegalArgumentException& ex) {
ensure( "Did get expected exception" );
+ ex.what();
} catch (...) {
ensure( !"Got unexpected exception" );
More information about the geos-commits
