[geos-commits] r3116 - in trunk: . tests/unit
svn_geos at osgeo.org
Fri Oct 15 11:54:15 EDT 2010
Author: mloskot
Date: 2010-10-15 08:54:14 -0700 (Fri, 15 Oct 2010)
New Revision: 3116
trunk/CMakeLists.txt
trunk/tests/unit/CMakeLists.txt
Unified CMAKE_*_OUTPUT_DIRECTOR locations to simplify tests running and finding all binaries.
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2010-10-15 15:20:02 UTC (rev 3115)
+++ trunk/CMakeLists.txt 2010-10-15 15:54:14 UTC (rev 3116)
@@ -204,6 +204,18 @@
endif()
+# Setup build directories
+# Put the libaries and binaries that get built into directories at the
+# top of the build tree rather than in hard-to-find leaf
+# directories. This simplifies manual testing and the use of the build
+# tree rather than installed Boost libraries.
+set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
+set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
+set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/bin)
# Setup include directories
Modified: trunk/tests/unit/CMakeLists.txt
--- trunk/tests/unit/CMakeLists.txt 2010-10-15 15:20:02 UTC (rev 3115)
+++ trunk/tests/unit/CMakeLists.txt 2010-10-15 15:54:14 UTC (rev 3116)
@@ -25,9 +25,9 @@
add_executable(geos_unit ${geos_unit_SOURCES})
target_link_libraries(geos_unit geos geos_c)
- add_test(geos_unit ${CMAKE_CURRENT_BINARY_DIR}/geos_unit)
+ add_test(geos_unit ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/geos_unit)
set(STATUS_RESULT "ON")
endif()
-message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
\ No newline at end of file
+message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
More information about the geos-commits
