[geos-commits] r3292 - in trunk: include/geos/geom src/geom
tests/unit tests/unit/geom tests/unit/io
svn_geos at osgeo.org
Fri Apr 22 09:04:20 EDT 2011
Author: strk
Date: 2011-04-22 06:04:20 -0700 (Fri, 22 Apr 2011)
New Revision: 3292
Added:
trunk/tests/unit/geom/PrecisionModelTest.cpp
trunk/include/geos/geom/PrecisionModel.h
trunk/include/geos/geom/PrecisionModel.inl
trunk/src/geom/PrecisionModel.cpp
trunk/tests/unit/Makefile.am
trunk/tests/unit/io/WKTReaderTest.cpp
trunk/tests/unit/io/WKTWriterTest.cpp
Sync PrecisionModel to JTS-1.12, add unit testing, fix getMaximumPrecisionDigit to behave as documented (JTS doesn't).
Modified: trunk/include/geos/geom/PrecisionModel.h
--- trunk/include/geos/geom/PrecisionModel.h 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/include/geos/geom/PrecisionModel.h 2011-04-22 13:04:20 UTC (rev 3292)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2006 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -13,7 +14,7 @@
- * Last port: geom/PrecisionModel.java rev. 1.51 (JTS-1.7)
+ * Last port: geom/PrecisionModel.java r378 (JTS-1.12)
@@ -73,6 +74,10 @@
* - jtsPt.x = round( inputPt.x * scale ) / scale
* - jtsPt.y = round( inputPt.y * scale ) / scale
+ * For example, to specify 3 decimal places of precision, use a scale factor
+ * of 1000. To specify -3 decimal places of precision (i.e. rounding to
+ * the nearest 1000), use a scale factor of 0.001.
* Coordinates are represented internally as Java double-precision values.
* Since Java uses the IEEE-394 floating point standard, this
* provides 53 bits of precision. (Thus the maximum precisely representable
Modified: trunk/include/geos/geom/PrecisionModel.inl
--- trunk/include/geos/geom/PrecisionModel.inl 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/include/geos/geom/PrecisionModel.inl 2011-04-22 13:04:20 UTC (rev 3292)
@@ -4,6 +4,7 @@
* Copyright (C) 2005-2006 Refractions Research Inc.
@@ -13,7 +14,7 @@
Modified: trunk/src/geom/PrecisionModel.cpp
--- trunk/src/geom/PrecisionModel.cpp 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/src/geom/PrecisionModel.cpp 2011-04-22 13:04:20 UTC (rev 3292)
@@ -4,6 +4,7 @@
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -13,7 +14,7 @@
@@ -80,7 +81,7 @@
PrecisionModel::PrecisionModel()
modelType(FLOATING),
- scale(1.0)
+ scale(0.0)
#if GEOS_DEBUG
cerr<<"PrecisionModel["<<this<<"] ctor()"<<endl;
@@ -161,8 +162,13 @@
} else if (modelType == FLOATING_SINGLE) {
maxSigDigits = 6;
} else if (modelType == FIXED) {
- const int dgts = static_cast<int>(std::ceil(std::log(getScale()) / std::log(double(10.0))));
- maxSigDigits = 1 + dgts;
+ double dgtsd = std::log(getScale()) / std::log(double(10.0));
+ const int dgts = static_cast<int>(
+ dgtsd > 0 ? std::ceil(dgtsd)
+ : std::floor(dgtsd)
+ maxSigDigits = dgts;
return maxSigDigits;
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/tests/unit/Makefile.am 2011-04-22 13:04:20 UTC (rev 3292)
@@ -57,6 +57,7 @@
geom/MultiPolygonTest.cpp \
geom/PointTest.cpp \
geom/PolygonTest.cpp \
+ geom/PrecisionModelTest.cpp \
geom/prep/PreparedGeometryFactoryTest.cpp \
geom/TriangleTest.cpp \
geom/util/GeometryExtracterTest.cpp \
Added: trunk/tests/unit/geom/PrecisionModelTest.cpp
--- trunk/tests/unit/geom/PrecisionModelTest.cpp (rev 0)
+++ trunk/tests/unit/geom/PrecisionModelTest.cpp 2011-04-22 13:04:20 UTC (rev 3292)
@@ -0,0 +1,143 @@
+// $Id$
+// Test Suite for geos::geom::PrecisionModel class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/Coordinate.h>
+namespace tut
+ // Test Group
+ // Common data used by tests
+ struct test_precisionmodel_data
+ typedef geos::geom::PrecisionModel PrecisionModel;
+ typedef geos::geom::Coordinate Coordinate;
+ test_precisionmodel_data() {}
+ void preciseCoordinateTester(const PrecisionModel& pm,
+ double x1, double y1,
+ double x2, double y2)
+ Coordinate p(x1, y1);
+ pm.makePrecise(p);
+ Coordinate pPrecise(x2, y2);
+ ensure(p.equals2D(pPrecise));
+ typedef test_group<test_precisionmodel_data> group;
+ typedef group::object object;
+ group test_precisionmodel_group("geos::geom::PrecisionModel");
+ // Test Cases
+ // Test of default constructor
+ template<>
+ template<>
+ void object::test<1>()
+ PrecisionModel pm;
+ ensure(pm.isFloating());
+ ensure_equals(pm.getMaximumSignificantDigits(), 16);
+ ensure_equals(pm.getScale(), 0);
+ // Test FLOAT_SINGLE model
+ template<>
+ template<>
+ void object::test<2>()
+ PrecisionModel pm(PrecisionModel::FLOATING_SINGLE);
+ ensure_equals(pm.getType(), PrecisionModel::FLOATING_SINGLE);
+ ensure_equals(pm.getMaximumSignificantDigits(), 6);
+ // Test default FIXED model
+ template<>
+ template<>
+ void object::test<3>()
+ PrecisionModel pm(PrecisionModel::FIXED);
+ ensure(!pm.isFloating());
+ ensure_equals(pm.getType(), PrecisionModel::FIXED);
+ ensure_equals(pm.getMaximumSignificantDigits(), 0);
+ // Test maximum significant digits (1:0)
+ template<>
+ template<>
+ void object::test<4>()
+ PrecisionModel pm(1);
+ // Test maximum significant digits (10:1)
+ template<>
+ template<>
+ void object::test<5>()
+ PrecisionModel pm(10);
+ ensure_equals(pm.getMaximumSignificantDigits(), 1);
+ // Test maximum significant digits (1000:3)
+ template<>
+ template<>
+ void object::test<6>()
+ PrecisionModel pm(1000);
+ ensure_equals(pm.getMaximumSignificantDigits(), 3);
+ // Test maximum significant digits (0.1:-1)
+ template<>
+ template<>
+ void object::test<7>()
+ PrecisionModel pm(0.1);
+ ensure_equals(pm.getMaximumSignificantDigits(), -1);
+ // Test maximum significant digits (0.001:-3)
+ template<>
+ template<>
+ void object::test<8>()
+ PrecisionModel pm(0.001);
+ ensure_equals(pm.getMaximumSignificantDigits(), -3);
+ // Test makePrecise
+ template<>
+ template<>
+ void object::test<9>()
+ PrecisionModel pm_10(0.1);
+ preciseCoordinateTester(pm_10, 1200.4, 1240.4, 1200, 1240);
+ preciseCoordinateTester(pm_10, 1209.4, 1240.4, 1210, 1240);
+} // namespace tut
Modified: trunk/tests/unit/io/WKTReaderTest.cpp
--- trunk/tests/unit/io/WKTReaderTest.cpp 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/tests/unit/io/WKTReaderTest.cpp 2011-04-22 13:04:20 UTC (rev 3292)
@@ -105,7 +105,7 @@
ensure( coords->getDimension() == 3 );
ensure_equals( wktwriter.write(geom.get()),
- std::string("LINESTRING Z (-117.0 33.0 2.0, -116.0 34.0 4.0)") );
+ std::string("LINESTRING Z (-117 33 2, -116 34 4)") );
delete coords;
@@ -117,7 +117,7 @@
GeomPtr geom(wktreader.read("LineString (-117 33 2, -116 34 4)"));
// 6 - invalid WKT (see http://trac.osgeo.org/geos/ticket/361)
Modified: trunk/tests/unit/io/WKTWriterTest.cpp
--- trunk/tests/unit/io/WKTWriterTest.cpp 2011-04-20 17:13:13 UTC (rev 3291)
+++ trunk/tests/unit/io/WKTWriterTest.cpp 2011-04-22 13:04:20 UTC (rev 3292)
@@ -1,6 +1,6 @@
// $Id: WKBReaderTest.cpp 2344 2009-04-09 21:46:30Z mloskot $
-// Test Suite for geos::io::WKTReader
+// Test Suite for geos::io::WKTWriter
// tut
#include <tut.hpp>
@@ -59,12 +59,12 @@
wktwriter.setTrim(false);
result = wktwriter.write( geom );
- ensure( result == "POINT (-117.0000 33.0000)" );
+ ensure_equals( result , "POINT (-117.000 33.000)" );
wktwriter.setTrim(true);
- ensure( result == "POINT (-117 33)" );
+ ensure_equals( result , "POINT (-117 33)" );
delete geom;
@@ -80,12 +80,12 @@
- ensure( result == "POINT (-117.1230 33.1230)" );
+ ensure_equals( result , "POINT (-117.123 33.123)" );
wktwriter.setRoundingPrecision(2);
- ensure( result == "POINT (-117.12 33.12)" );
+ ensure_equals( result , "POINT (-117.12 33.12)" );
delete geom;
@@ -132,6 +132,29 @@
delete geom;
+ // 5 - Test fixed precision model geometries
+ template<>
+ template<>
+ geos::geom::PrecisionModel pm3(1000, 0, 0);
+ geos::geom::GeometryFactory gf3(&pm3);
+ geos::io::WKTReader wktreader3(&gf3);
+ geos::geom::Geometry *geom = wktreader3.read("POINT(0.123456 1.98765)");
+ std::string result = wktwriter.write( geom );
+ ensure_equals( result, std::string("POINT (0.123 1.988)") );
+ delete geom;
} // namespace tut
More information about the geos-commits
