[geos-commits] r3293 - in trunk: include/geos/io src/io
tests/unit/io
svn_geos at osgeo.org
Fri Apr 22 09:51:38 EDT 2011
Author: strk
Date: 2011-04-22 06:51:38 -0700 (Fri, 22 Apr 2011)
New Revision: 3293
trunk/include/geos/io/WKTWriter.h
trunk/src/io/WKTWriter.cpp
trunk/tests/unit/io/WKTWriterTest.cpp
Use stringstream to format strings rather than printf-like statements. Simplifies things a lot.
Modified: trunk/include/geos/io/WKTWriter.h
--- trunk/include/geos/io/WKTWriter.h 2011-04-22 13:04:20 UTC (rev 3292)
+++ trunk/include/geos/io/WKTWriter.h 2011-04-22 13:51:38 UTC (rev 3293)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2006 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -169,7 +170,7 @@
protected:
- std::string formatter;
+ int decimalPlaces;
void appendGeometryTaggedText(const geom::Geometry *geometry, int level, Writer *writer);
@@ -245,10 +246,6 @@
// static const int INDENT = 2;
- static std::string createFormatter(
- const geom::PrecisionModel* precisionModel,
- int overwritePrecision);
bool isFormatted;
int roundingPrecision;
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp 2011-04-22 13:04:20 UTC (rev 3292)
+++ trunk/src/io/WKTWriter.cpp 2011-04-22 13:51:38 UTC (rev 3293)
@@ -4,6 +4,7 @@
@@ -39,6 +40,7 @@
#include <sstream>
#include <cassert>
#include <cmath>
+#include <iomanip>
using namespace std;
using namespace geos::geom;
@@ -47,7 +49,7 @@
namespace io { // geos.io
WKTWriter::WKTWriter():
- formatter("%f"),
+ decimalPlaces(6),
isFormatted(false),
roundingPrecision(-1),
trim(false),
@@ -143,37 +145,9 @@
trim = p0;
-string
-WKTWriter::createFormatter(const PrecisionModel* precisionModel, int overwritePrecision)
- // the default number of decimal places is 16, which is sufficient
- // to accomodate the maximum precision of a double.
- // if roundingPrecision is specified (not -1) it will be used instead
- int decimalPlaces = precisionModel->getMaximumSignificantDigits();
- if(overwritePrecision != -1) {
- decimalPlaces = overwritePrecision;
- std::string fmt("%.");
- char buffer[255] = { 0 };
- sprintf(buffer,"%i",decimalPlaces);
- fmt.append(buffer);
- fmt.append("f");
- return fmt;
-//string WKTWriter::stringOfChar(char ch, int count) {
- //string str="";
- //for (int i=0;i<count;i++) str+=ch;
- //return string(count, ch);
string WKTWriter::write(const Geometry *geometry) {
Writer sw;
-// try {
- writeFormatted(geometry,false,&sw);
-// } catch (const IOException ex) {
-// Assert::shouldNeverReachHere();
+ writeFormatted(geometry,false,&sw);
string res=sw.toString();
return res;
@@ -198,7 +172,7 @@
CLocalizer clocale;
this->isFormatted=isFormatted;
- formatter=createFormatter(geometry->getPrecisionModel(), roundingPrecision);
+ decimalPlaces = roundingPrecision == -1 ? geometry->getPrecisionModel()->getMaximumSignificantDigits() : roundingPrecision;
appendGeometryTaggedText(geometry, 0, writer);
@@ -340,6 +314,7 @@
+/* pritected */
void
WKTWriter::appendCoordinate(const Coordinate* coordinate,
Writer *writer)
@@ -359,75 +334,16 @@
writer->write(out);
-string WKTWriter::writeNumber(double d) {
- sprintf(buffer,formatter.c_str(),d);
- //If we've set trim to true, do it here
- if(trim) {
- bool roundNines = false;
- int i = 0, j;
+/* protected */
+string
+WKTWriter::writeNumber(double d) {
- //count the length of the string
- while(buffer[i] != '\0') {
- i++;
- //arrays go to length-1 of course
- i--;
+ std::stringstream ss;
- * Is there a rounding error at the end?
- if(i > 6 &&
- buffer[i] != '0' &&
- buffer[i-1] == '0' &&
- buffer[i-2] == '0' &&
- buffer[i-3] == '0' &&
- buffer[i-4] == '0' &&
- buffer[i-5] == '0') {
- buffer[i--] = '\0';
- * Do we need to round 9's?
- if(i > 6 &&
- buffer[i] == '9' &&
- buffer[i-1] == '9' &&
- buffer[i-2] == '9' &&
- buffer[i-3] == '9' &&
- buffer[i-4] == '9' &&
- buffer[i-5] == '9') {
- roundNines = true;
+ if ( ! trim ) ss << std::fixed;
+ ss << std::setprecision(decimalPlaces >= 0 ? decimalPlaces : 0) << d;
- * Now let's format the string
- for(j = i; j >= 0; j--) {
- if(roundNines) {
- if(buffer[j] == '9') {
- buffer[j] = '\0';
- else {
- buffer[j]++;
- roundNines = false;
- else if(buffer[j] == '0') {
- buffer[j] = '\0';
- else {
- //remove period if no decimals
- if(buffer[j] == '.' && buffer[j+1] == '\0') {
- buffer[j] = '\0';
- //and we're done
- break;
- std::string out(buffer);
- out.append("");
- return out;
+ return ss.str();
void
@@ -570,101 +486,9 @@
void WKTWriter::indent(int level, Writer *writer) {
if (!isFormatted || level<=0) return;
writer->write("\n");
- //writer->write(stringOfChar(' ', INDENT * level));
writer->write(string(INDENT * level, ' '));
} // namespace geos.io
} // namespace geos
- * $Log$
- * Revision 1.35 2006/06/12 16:55:53 strk
- * fixed compiler warnings, fixed some methods to omit unused parameters.
- * Revision 1.34 2006/06/08 17:58:57 strk
- * Polygon::getNumInteriorRing() return size_t, Polygon::interiorRingN() takes size_t.
- * Revision 1.33 2006/06/01 11:49:36 strk
- * Reduced installed headers form geomgraph namespace
- * Revision 1.32 2006/04/28 11:12:31 strk
- * removed warnings related to change in getNumPoints() return type.
- * Revision 1.31 2006/04/07 09:54:30 strk
- * Geometry::getNumGeometries() changed to return 'unsigned int'
- * rather then 'int'
- * Revision 1.30 2006/03/22 16:58:35 strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
- * Revision 1.29 2006/03/20 18:18:15 strk
- * io.h header split
- * Revision 1.28 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.27 2006/03/06 19:40:47 strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.26 2006/03/06 15:23:14 strk
- * geos::io namespace
- * Revision 1.25 2006/03/03 10:46:21 strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.24 2006/02/09 15:52:47 strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.23 2006/02/08 17:18:28 strk
- * - New WKTWriter::toLineString and ::toPoint convenience methods
- * - New IsValidOp::setSelfTouchingRingFormingHoleValid method
- * - New Envelope::centre()
- * - New Envelope::intersection(Envelope)
- * - New Envelope::expandBy(distance, [ydistance])
- * - New LineString::reverse()
- * - New MultiLineString::reverse()
- * - New Geometry::buffer(distance, quadSeg, endCapStyle)
- * - Obsoleted toInternalGeometry/fromInternalGeometry
- * - More const-correctness in Buffer "package"
- * Revision 1.22 2006/01/18 17:46:57 strk
- * Fixed leak in ::writeFormatted(Geometry *)
- * Revision 1.21 2004/12/08 13:54:43 strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.20 2004/10/21 22:29:54 strk
- * Indentation changes and some more COMPUTE_Z rules
- * Revision 1.19 2004/10/20 17:32:14 strk
- * Initial approach to 2.5d intersection()
- * Revision 1.18 2004/07/19 13:19:31 strk
- * Documentation fixes
- * Revision 1.17 2004/07/07 09:38:12 strk
- * Dropped WKTWriter::stringOfChars (implemented by std::string).
- * Dropped WKTWriter default constructor (internally created GeometryFactory).
- * Updated XMLTester to respect the changes.
- * Main documentation page made nicer.
- * Revision 1.16 2004/07/02 13:28:27 strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.15 2004/03/18 10:42:44 ybychkov
- * "IO" and "Util" upgraded to JTS 1.4
- * "Geometry" partially upgraded.
- * Revision 1.14 2003/11/07 01:23:42 pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
Modified: trunk/tests/unit/io/WKTWriterTest.cpp
--- trunk/tests/unit/io/WKTWriterTest.cpp 2011-04-22 13:04:20 UTC (rev 3292)
+++ trunk/tests/unit/io/WKTWriterTest.cpp 2011-04-22 13:51:38 UTC (rev 3293)
@@ -24,11 +24,17 @@
// dummy data, not used
struct test_wktwriter_data
- geos::geom::PrecisionModel pm;
- geos::geom::GeometryFactory gf;
- geos::io::WKTReader wktreader;
- geos::io::WKTWriter wktwriter;
+ typedef geos::geom::PrecisionModel PrecisionModel;
+ typedef geos::geom::GeometryFactory GeometryFactory;
+ typedef geos::io::WKTReader WKTReader;
+ typedef geos::io::WKTWriter WKTWriter;
+ typedef std::auto_ptr<geos::geom::Geometry> GeomPtr;
+ PrecisionModel pm;
+ GeometryFactory gf;
+ WKTReader wktreader;
+ WKTWriter wktwriter;
test_wktwriter_data()
pm(1000.0),
@@ -53,20 +59,18 @@
template<>
void object::test<1>()
- geos::geom::Geometry *geom = wktreader.read("POINT(-117 33)");
+ GeomPtr geom ( wktreader.read("POINT(-117 33)") );
std::string result;
wktwriter.setTrim(false);
- result = wktwriter.write( geom );
+ result = wktwriter.write( geom.get() );
ensure_equals( result , "POINT (-117.000 33.000)" );
wktwriter.setTrim(true);
ensure_equals( result , "POINT (-117 33)" );
- delete geom;
// 2 - Test the output precision capability
@@ -74,20 +78,19 @@
template<>
void object::test<2>()
- geos::geom::Geometry *geom = wktreader.read("POINT(-117.1234567 33.1234567)");
+ GeomPtr geom ( wktreader.read("POINT(-117.1234567 33.1234567)") );
std::string result;
ensure_equals( result , "POINT (-117.123 33.123)" );
wktwriter.setRoundingPrecision(2);
ensure_equals( result , "POINT (-117.12 33.12)" );
- delete geom;
// 3 - Test 3D generation from a 3D geometry.
@@ -95,23 +98,22 @@
template<>
void object::test<3>()
- geos::geom::Geometry *geom = wktreader.read("POINT Z (-117 33 120)");
+ GeomPtr geom ( wktreader.read("POINT Z (-117 33 120)") );
std::string result;
wktwriter.setOutputDimension(3);
wktwriter.setTrim( true );
wktwriter.setOld3D( false );
ensure_equals( result, std::string("POINT Z (-117 33 120)") );
wktwriter.setOld3D( true );
ensure_equals( result, std::string("POINT (-117 33 120)") );
- delete geom;
// 4 - Test 2D generation from a 3D geometry.
@@ -119,41 +121,30 @@
template<>
void object::test<4>()
- geos::geom::Geometry *geom = wktreader.read("POINT(-117 33 120)");
+ GeomPtr geom ( wktreader.read("POINT(-117 33 120)") );
std::string result;
wktwriter.setOutputDimension(2);
ensure_equals( result, std::string("POINT (-117 33)") );
- delete geom;
- // 5 - Test fixed precision model geometries
+ // 5 - Test negative number of digits in precision model
template<>
template<>
void object::test<5>()
+ PrecisionModel pm3(0.001);
+ GeometryFactory gf3(&pm3);
+ WKTReader wktreader3(&gf3);
+ GeomPtr geom ( wktreader3.read("POINT(123456 654321)") );
- * For example, to specify 3 decimal places of precision, use a scale factor
- * of 1000. To specify -3 decimal places of precision (i.e. rounding to
- * the nearest 1000), use a scale factor of 0.001.
- geos::geom::PrecisionModel pm3(1000, 0, 0);
- geos::geom::GeometryFactory gf3(&pm3);
- geos::io::WKTReader wktreader3(&gf3);
- geos::geom::Geometry *geom = wktreader3.read("POINT(0.123456 1.98765)");
- std::string result = wktwriter.write( geom );
- ensure_equals( result, std::string("POINT (0.123 1.988)") );
- delete geom;
+ std::string result = wktwriter.write( geom.get() );
+ ensure_equals( result, std::string("POINT (123000 654000)") );
} // namespace tut
More information about the geos-commits
