[geos-commits] r3294 - trunk/include/geos/operation/union
svn_geos at osgeo.org
Fri Apr 22 14:46:37 EDT 2011
Author: strk
Date: 2011-04-22 11:46:37 -0700 (Fri, 22 Apr 2011)
New Revision: 3294
Added:
trunk/include/geos/operation/union/GeometryListHolder.h
trunk/include/geos/operation/union/CascadedPolygonUnion.h
trunk/include/geos/operation/union/Makefile.am
Put GeometryListHolder in its own header file.
Modified: trunk/include/geos/operation/union/CascadedPolygonUnion.h
--- trunk/include/geos/operation/union/CascadedPolygonUnion.h 2011-04-22 13:51:38 UTC (rev 3293)
+++ trunk/include/geos/operation/union/CascadedPolygonUnion.h 2011-04-22 18:46:37 UTC (rev 3294)
@@ -20,11 +20,14 @@
#ifndef GEOS_OP_UNION_CASCADEDPOLYGONUNION_H
#define GEOS_OP_UNION_CASCADEDPOLYGONUNION_H
#include <geos/export.h>
#include <vector>
#include <algorithm>
+#include "GeometryListHolder.h"
// Forward declarations
namespace geos {
namespace geom {
@@ -46,44 +49,6 @@
namespace geounion { // geos::operation::geounion
- * \brief Helper class holding Geometries, part of which are held by reference
- * others are held exclusively.
-class GeometryListHolder : public std::vector<geom::Geometry*>
-private:
- typedef std::vector<geom::Geometry*> base_type;
-public:
- GeometryListHolder() {}
- ~GeometryListHolder()
- std::for_each(ownedItems.begin(), ownedItems.end(),
- &GeometryListHolder::deleteItem);
- // items need to be deleted in the end
- void push_back_owned(geom::Geometry* item)
- this->base_type::push_back(item);
- ownedItems.push_back(item);
- geom::Geometry* getGeometry(std::size_t index)
- if (index >= this->base_type::size())
- return NULL;
- return (*this)[index];
-private:
- static void deleteItem(geom::Geometry* item);
-private:
- std::vector<geom::Geometry*> ownedItems;
* \brief
* Provides an efficient method of unioning a collection of
* {@link Polygonal} geometries.
Added: trunk/include/geos/operation/union/GeometryListHolder.h
--- trunk/include/geos/operation/union/GeometryListHolder.h (rev 0)
+++ trunk/include/geos/operation/union/GeometryListHolder.h 2011-04-22 18:46:37 UTC (rev 3294)
@@ -0,0 +1,73 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_OP_UNION_GEOMETRYLISTHOLDER_H
+#define GEOS_OP_UNION_GEOMETRYLISTHOLDER_H
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Geometry;
+namespace geos {
+namespace operation { // geos::operation
+namespace geounion { // geos::operation::geounion
+ * \brief Helper class holding Geometries, part of which are held by reference
+ * others are held exclusively.
+class GeometryListHolder : public std::vector<geom::Geometry*>
+private:
+ typedef std::vector<geom::Geometry*> base_type;
+public:
+ GeometryListHolder() {}
+ ~GeometryListHolder()
+ std::for_each(ownedItems.begin(), ownedItems.end(),
+ &GeometryListHolder::deleteItem);
+ // items need to be deleted in the end
+ void push_back_owned(geom::Geometry* item)
+ this->base_type::push_back(item);
+ ownedItems.push_back(item);
+ geom::Geometry* getGeometry(std::size_t index)
+ if (index >= this->base_type::size())
+ return NULL;
+ return (*this)[index];
+private:
+ static void deleteItem(geom::Geometry* item);
+private:
+ std::vector<geom::Geometry*> ownedItems;
+} // namespace geos::operation::union
+#endif
Modified: trunk/include/geos/operation/union/Makefile.am
--- trunk/include/geos/operation/union/Makefile.am 2011-04-22 13:51:38 UTC (rev 3293)
+++ trunk/include/geos/operation/union/Makefile.am 2011-04-22 18:46:37 UTC (rev 3294)
@@ -10,5 +10,6 @@
geos_HEADERS = \
CascadedPolygonUnion.h \
+ GeometryListHolder.h \
PointGeometryUnion.h \
UnaryUnionOp.h
More information about the geos-commits
