[geos-commits] r3299 - in trunk: include/geos/operation/buffer
src/operation/buffer
svn_geos at osgeo.org
Wed Apr 27 05:42:03 EDT 2011
Author: strk
Date: 2011-04-27 02:42:02 -0700 (Wed, 27 Apr 2011)
New Revision: 3299
trunk/include/geos/operation/buffer/BufferOp.h
trunk/src/operation/buffer/BufferOp.cpp
Sync BufferOp class to JTS r378. Do not port the unused isSingleSided property.
Modified: trunk/include/geos/operation/buffer/BufferOp.h
--- trunk/include/geos/operation/buffer/BufferOp.h 2011-04-23 10:30:12 UTC (rev 3298)
+++ trunk/include/geos/operation/buffer/BufferOp.h 2011-04-27 09:42:02 UTC (rev 3299)
@@ -4,7 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2009-2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2007 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -15,7 +15,7 @@
- * Last port: operation/buffer/BufferOp.java r262 (JTS-1.12)
+ * Last port: operation/buffer/BufferOp.java r378 (JTS-1.12)
@@ -51,15 +51,17 @@
* Computes the buffer of a geometry, for both positive and negative
* buffer distances.
- * In GIS, the buffer of a geometry is defined as
- * the Minkowski sum or difference of the geometry
+ * In GIS, the positive (or negative) buffer of a geometry is defined as
+ * the Minkowski sum (or difference) of the geometry
* with a circle with radius equal to the absolute value of the buffer
* distance.
* In the CAD/CAM world buffers are known as </i>offset curves</i>.
- * In morphological analysis they are known as <i>erosion</i> and <i>dilation</i>.
+ * In morphological analysis the operation of positive and negative buffering
+ * is referred to as <i>erosion</i> and <i>dilation</i>.
* The buffer operation always returns a polygonal result.
- * The negative or zero-distance buffer of lines and points is always an empty Polygon.
+ * The negative or zero-distance buffer of lines and points is always
+ * an empty Polygon.
* Since true buffer curves may contain circular arcs,
* computed buffer polygons can only be approximations to the true geometry.
@@ -190,7 +192,6 @@
* Specifies the end cap style of the generated buffer.
* The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
Modified: trunk/src/operation/buffer/BufferOp.cpp
--- trunk/src/operation/buffer/BufferOp.cpp 2011-04-23 10:30:12 UTC (rev 3298)
+++ trunk/src/operation/buffer/BufferOp.cpp 2011-04-27 09:42:02 UTC (rev 3299)
@@ -4,7 +4,7 @@
@@ -15,7 +15,7 @@
More information about the geos-commits
