[geos-commits] r3300 - in trunk: include/geos/operation/buffer
src/operation/buffer
svn_geos at osgeo.org
Wed Apr 27 05:42:13 EDT 2011
Author: strk
Date: 2011-04-27 02:42:13 -0700 (Wed, 27 Apr 2011)
New Revision: 3300
trunk/include/geos/operation/buffer/BufferParameters.h
trunk/src/operation/buffer/BufferParameters.cpp
Sync BufferParameters class to JTS r378 (isSingleSided property)
Modified: trunk/include/geos/operation/buffer/BufferParameters.h
--- trunk/include/geos/operation/buffer/BufferParameters.h 2011-04-27 09:42:02 UTC (rev 3299)
+++ trunk/include/geos/operation/buffer/BufferParameters.h 2011-04-27 09:42:13 UTC (rev 3300)
@@ -13,7 +13,7 @@
- * Last port: operation/buffer/BufferParameters.java r262 (JTS-1.11+)
+ * Last port: operation/buffer/BufferParameters.java r378 (JTS-1.12)
@@ -243,7 +243,38 @@
mitreLimit = limit;
+ * Sets whether the computed buffer should be single-sided.
+ * A single-sided buffer is constructed on only one side of each input line.
+ * The side used is determined by the sign of the buffer distance:
+ * - a positive distance indicates the left-hand side
+ * - a negative distance indicates the right-hand side
+ * The single-sided buffer of point geometries is
+ * the same as the regular buffer.
+ * The End Cap Style for single-sided buffers is
+ * always ignored,
+ * and forced to the equivalent of <tt>CAP_FLAT</tt>.
+ * @param isSingleSided true if a single-sided buffer should be constructed
+ void setSingleSided(bool isSingleSided)
+ _isSingleSided = isSingleSided;
+ * Tests whether the buffer is to be generated on a single side only.
+ * @return true if the generated buffer is to be single-sided
+ bool isSingleSided() const {
+ return _isSingleSided;
private:
/// Defaults to DEFAULT_QUADRANT_SEGMENTS;
@@ -252,11 +283,13 @@
/// Defaults to CAP_ROUND;
EndCapStyle endCapStyle;
- // Defaults to JOIN_ROUND;
+ /// Defaults to JOIN_ROUND;
JoinStyle joinStyle;
- // Defaults to DEFAULT_MITRE_LIMIT;
+ /// Defaults to DEFAULT_MITRE_LIMIT;
double mitreLimit;
+ bool _isSingleSided;
} // namespace geos::operation::buffer
Modified: trunk/src/operation/buffer/BufferParameters.cpp
--- trunk/src/operation/buffer/BufferParameters.cpp 2011-04-27 09:42:02 UTC (rev 3299)
+++ trunk/src/operation/buffer/BufferParameters.cpp 2011-04-27 09:42:13 UTC (rev 3300)
@@ -13,7 +13,7 @@
+ * Last port: operation/buffer/BufferParameters.java r278 (JTS-1.12)
@@ -40,7 +40,8 @@
quadrantSegments(DEFAULT_QUADRANT_SEGMENTS),
endCapStyle(CAP_ROUND),
joinStyle(JOIN_ROUND),
- mitreLimit(DEFAULT_MITRE_LIMIT)
+ mitreLimit(DEFAULT_MITRE_LIMIT),
+ _isSingleSided(false)
// public
@@ -49,7 +50,8 @@
setQuadrantSegments(quadrantSegments);
@@ -61,7 +63,8 @@
setEndCapStyle(endCapStyle);
@@ -76,7 +79,8 @@
More information about the geos-commits
