[geos-commits] r3306 - in trunk: include/geos/operation/buffer
src/operation/buffer tests/unit/capi
svn_geos at osgeo.org
Wed Apr 27 10:13:45 EDT 2011
Author: strk
Date: 2011-04-27 07:13:45 -0700 (Wed, 27 Apr 2011)
New Revision: 3306
trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
trunk/tests/unit/capi/GEOSBufferTest.cpp
Add test for singlesided buffer (areal). Fix premature exit from OffsetCurveSetBuilder.
Modified: trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h 2011-04-27 13:38:53 UTC (rev 3305)
+++ trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h 2011-04-27 14:13:45 UTC (rev 3306)
@@ -14,7 +14,7 @@
- * Last port: operation/buffer/OffsetCurveSetBuilder.java r262 (JTS-1.11+)
+ * Last port: operation/buffer/OffsetCurveSetBuilder.java r378 (JTS-1.12)
Modified: trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-04-27 13:38:53 UTC (rev 3305)
+++ trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-04-27 14:13:45 UTC (rev 3306)
@@ -15,7 +15,7 @@
@@ -194,7 +194,11 @@
void
OffsetCurveSetBuilder::addLineString(const LineString *line)
- if (distance <= 0.0) return;
+ if (distance <= 0.0 && ! curveBuilder.getBufferParameters().isSingleSided())
+ return;
#if GEOS_DEBUG
std::cerr<<__FUNCTION__<<": "<<line->toString()<<std::endl;
#endif
Modified: trunk/tests/unit/capi/GEOSBufferTest.cpp
--- trunk/tests/unit/capi/GEOSBufferTest.cpp 2011-04-27 13:38:53 UTC (rev 3305)
+++ trunk/tests/unit/capi/GEOSBufferTest.cpp 2011-04-27 14:13:45 UTC (rev 3306)
@@ -23,6 +23,8 @@
GEOSGeometry* geom1_;
GEOSGeometry* geom2_;
char* wkt_;
+ GEOSBufferParams* bp_;
+ GEOSWKTWriter* wktw_;
double area_;
static void notice(const char *fmt, ...)
@@ -38,15 +40,19 @@
test_capigeosbuffer_data()
- : geom1_(0), geom2_(0), wkt_(0)
+ : geom1_(0), geom2_(0), wkt_(0), bp_(0)
initGEOS(notice, notice);
+ wktw_ = GEOSWKTWriter_create();
+ GEOSWKTWriter_setTrim(wktw_, 1);
~test_capigeosbuffer_data()
GEOSGeom_destroy(geom1_);
GEOSGeom_destroy(geom2_);
+ GEOSWKTWriter_destroy(wktw_);
+ GEOSBufferParams_destroy(bp_);
GEOSFree(wkt_);
geom1_ = 0;
geom2_ = 0;
@@ -444,5 +450,81 @@
+ // Buffer with params:
+ // flat end cap on a straight line
+ template<>
+ template<>
+ void object::test<17>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 10)");
+ ensure( 0 != geom1_ );
+ bp_ = GEOSBufferParams_create();
+ GEOSBufferParams_setEndCapStyle(bp_, GEOSBUF_CAP_SQUARE);
+ geom2_ = GEOSBufferWithParams(geom1_, bp_, 2);
+ ensure( 0 != geom2_ );
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ ensure_equals(std::string(wkt_), std::string(
+"POLYGON ((10 12, 12 12, 12 8, 5 8, 3 8, 3 12, 10 12))"
+ // Single sided (left)
+ template<>
+ template<>
+ void object::test<18>()
+ GEOSBufferParams_setSingleSided(bp_, 1);
+"POLYGON ((10 10, 5 10, 5 12, 10 12, 10 10))"
+ // Single sided (right)
+ template<>
+ template<>
+ void object::test<19>()
+ geom2_ = GEOSBufferWithParams(geom1_, bp_, -2);
+"POLYGON ((5 10, 10 10, 10 8, 5 8, 5 10))"
} // namespace tut
More information about the geos-commits
