[geos-commits] r3307 - in trunk: include/geos/algorithm
src/algorithm tests/unit tests/unit/algorithm
svn_geos at osgeo.org
Wed Apr 27 11:18:08 EDT 2011
Author: strk
Date: 2011-04-27 08:18:08 -0700 (Wed, 27 Apr 2011)
New Revision: 3307
Added:
trunk/tests/unit/algorithm/AngleTest.cpp
trunk/include/geos/algorithm/Angle.h
trunk/src/algorithm/Angle.cpp
trunk/tests/unit/Makefile.am
Sync Angle class to JTS-1.12, port unit testing for it.
Modified: trunk/include/geos/algorithm/Angle.h
--- trunk/include/geos/algorithm/Angle.h 2011-04-27 14:13:45 UTC (rev 3306)
+++ trunk/include/geos/algorithm/Angle.h 2011-04-27 15:18:08 UTC (rev 3307)
@@ -4,7 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2009-2011 Sandro Santilli <strk at keybit.net>
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -13,7 +13,7 @@
- * Last port: algorithm/Angle.java rev. 1.6 (JTS-1.9)
+ * Last port: algorithm/Angle.java r378 (JTS-1.12)
Modified: trunk/src/algorithm/Angle.cpp
--- trunk/src/algorithm/Angle.cpp 2011-04-27 14:13:45 UTC (rev 3306)
+++ trunk/src/algorithm/Angle.cpp 2011-04-27 15:18:08 UTC (rev 3307)
@@ -4,7 +4,7 @@
@@ -13,7 +13,7 @@
@@ -27,7 +27,7 @@
namespace algorithm { // geos.algorithm
namespace {
- const double PI = 3.14159265358979;
+ const double PI = 3.14159265358979323846;
const double Angle::PI_TIMES_2 = 2.0 * PI;
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2011-04-27 14:13:45 UTC (rev 3306)
+++ trunk/tests/unit/Makefile.am 2011-04-27 15:18:08 UTC (rev 3307)
@@ -30,6 +30,7 @@
geos_unit_SOURCES = \
geos_unit.cpp \
+ algorithm/AngleTest.cpp \
algorithm/CGAlgorithms/isCCWTest.cpp \
algorithm/CGAlgorithms/isPointInRingTest.cpp \
algorithm/CGAlgorithms/computeOrientationTest.cpp \
Added: trunk/tests/unit/algorithm/AngleTest.cpp
--- trunk/tests/unit/algorithm/AngleTest.cpp (rev 0)
+++ trunk/tests/unit/algorithm/AngleTest.cpp 2011-04-27 15:18:08 UTC (rev 3307)
@@ -0,0 +1,129 @@
+// $Id$
+// Test Suite for geos::algorithm::Angle
+// Ported from JTS junit/algorithm/AngleTest.java r378
+#include <tut.hpp>
+// geos
+#include <geos/geom/Coordinate.h>
+#include <geos/algorithm/Angle.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace tut
+ // Test Group
+ // dummy data, not used
+ struct test_angle_data {
+ typedef geos::geom::Coordinate Coordinate;
+ typedef geos::algorithm::Angle Angle;
+ double TOL;
+ double PI;
+ test_angle_data()
+ TOL (1e-5),
+ PI ( 3.14159265358979323846 )
+ typedef test_group<test_angle_data> group;
+ typedef group::object object;
+ group test_angle_group("geos::algorithm::Angle");
+ // Test Cases
+ // testAngle()
+ template<>
+ template<>
+ void object::test<1>()
+ ensure_equals("1", Angle::angle(Coordinate(10,0)), 0.0, TOL);
+ ensure_equals("2", Angle::angle(Coordinate(10,10)), PI/4, TOL);
+ ensure_equals("3", Angle::angle(Coordinate(0,10)), PI/2, TOL);
+ ensure_equals("4", Angle::angle(Coordinate(-10,10)), 0.75*PI, TOL);
+ ensure_equals("5", Angle::angle(Coordinate(-10,0)), PI, TOL);
+ ensure_equals("6", Angle::angle(Coordinate(-10,-0.1)), -3.131592987, TOL);
+ ensure_equals("7", Angle::angle(Coordinate(-10,-10)), -0.75*PI, TOL);
+ // testIsAcute()
+ template<>
+ template<>
+ void object::test<2>()
+ ensure(Angle::isAcute(
+ Coordinate(10,0), Coordinate(0,0), Coordinate(5,10)));
+ Coordinate(10,0), Coordinate(0,0), Coordinate(5,-10)));
+ // angle of 0
+ Coordinate(10,0), Coordinate(0,0), Coordinate(10,0)));
+ ensure_not(Angle::isAcute(
+ Coordinate(10,0), Coordinate(0,0), Coordinate(-5,10)));
+ Coordinate(10,0), Coordinate(0,0), Coordinate(-5,-10)));
+ // testNormalizePositive()
+ template<>
+ template<>
+ void object::test<3>()
+ ensure_equals("", Angle::normalizePositive(0.0), 0.0, TOL);
+ ensure_equals("", Angle::normalizePositive(-0.5*PI), 1.5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(-PI), PI, TOL);
+ ensure_equals("", Angle::normalizePositive(-1.5*PI), .5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(-2*PI), 0.0, TOL);
+ ensure_equals("", Angle::normalizePositive(-2.5*PI), 1.5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(-3*PI), PI, TOL);
+ ensure_equals("", Angle::normalizePositive(-4 * PI), 0.0, TOL);
+ ensure_equals("", Angle::normalizePositive(0.5*PI), 0.5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(PI), PI, TOL);
+ ensure_equals("", Angle::normalizePositive(1.5*PI), 1.5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(2*PI), 0.0, TOL);
+ ensure_equals("", Angle::normalizePositive(2.5*PI), 0.5*PI, TOL);
+ ensure_equals("", Angle::normalizePositive(3*PI), PI, TOL);
+ ensure_equals("", Angle::normalizePositive(4 * PI), 0.0, TOL);
+ // testNormalize()
+ template<>
+ template<>
+ void object::test<4>()
+ ensure_equals("1", Angle::normalize(0.0), 0.0, TOL);
+ ensure_equals("2", Angle::normalize(-0.5*PI), -0.5*PI, TOL);
+ ensure_equals("3", Angle::normalize(-PI), PI, TOL);
+ ensure_equals("4", Angle::normalize(-1.5*PI), .5*PI, TOL);
+ ensure_equals("5", Angle::normalize(-2*PI), 0.0, TOL);
+ ensure_equals("6", Angle::normalize(-2.5*PI), -0.5*PI, TOL);
+ ensure_equals("7", Angle::normalize(-3*PI), PI, TOL);
+ ensure_equals("8", Angle::normalize(-4 * PI), 0.0, TOL);
+ ensure_equals("9", Angle::normalize(0.5*PI), 0.5*PI, TOL);
+ ensure_equals("10", Angle::normalize(PI), PI, TOL);
+ ensure_equals("11", Angle::normalize(1.5*PI), -0.5*PI, TOL);
+ ensure_equals("12", Angle::normalize(2*PI), 0.0, TOL);
+ ensure_equals("13", Angle::normalize(2.5*PI), 0.5*PI, TOL);
+ ensure_equals("14", Angle::normalize(3*PI), PI, TOL);
+ ensure_equals("15", Angle::normalize(4 * PI), 0.0, TOL);
+} // namespace tut
More information about the geos-commits
