[geos-commits] r3312 - in trunk/src: geomgraph operation/valid
svn_geos at osgeo.org
Thu Apr 28 06:04:11 EDT 2011
Author: strk
Date: 2011-04-28 03:04:11 -0700 (Thu, 28 Apr 2011)
New Revision: 3312
trunk/src/geomgraph/EdgeIntersectionList.cpp
trunk/src/geomgraph/NodeMap.cpp
trunk/src/operation/valid/IsValidOp.cpp
Trim old embedded history log (from CVS times)
Modified: trunk/src/geomgraph/EdgeIntersectionList.cpp
--- trunk/src/geomgraph/EdgeIntersectionList.cpp 2011-04-27 16:42:15 UTC (rev 3311)
+++ trunk/src/geomgraph/EdgeIntersectionList.cpp 2011-04-28 10:04:11 UTC (rev 3312)
@@ -191,114 +191,3 @@
} // namespace geos.geomgraph
} // namespace
- * $Log$
- * Revision 1.23 2006/03/23 13:31:56 strk
- * Fixed to allow build with GEOS_DEBUG
- * Revision 1.22 2006/03/15 17:16:29 strk
- * streamlined headers inclusion
- * Revision 1.21 2006/03/03 10:46:21 strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.20 2006/03/02 12:12:00 strk
- * Renamed DEBUG macros to GEOS_DEBUG, all wrapped in #ifndef block to allow global override (bug#43)
- * Revision 1.19 2006/02/19 19:46:49 strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.18 2006/01/31 19:07:34 strk
- * - Renamed DefaultCoordinateSequence to CoordinateArraySequence.
- * - Moved GetNumGeometries() and GetGeometryN() interfaces
- * from GeometryCollection to Geometry class.
- * - Added getAt(int pos, Coordinate &to) funtion to CoordinateSequence class.
- * - Reworked automake scripts to produce a static lib for each subdir and
- * then link all subsystem's libs togheter
- * - Moved C-API in it's own top-level dir capi/
- * - Moved source/bigtest and source/test to tests/bigtest and test/xmltester
- * - Fixed PointLocator handling of LinearRings
- * - Changed CoordinateArrayFilter to reduce memory copies
- * - Changed UniqueCoordinateArrayFilter to reduce memory copies
- * - Added CGAlgorithms::isPointInRing() version working with
- * Coordinate::ConstVect type (faster!)
- * - Ported JTS-1.7 version of ConvexHull with big attention to
- * memory usage optimizations.
- * - Improved XMLTester output and user interface
- * - geos::geom::util namespace used for geom/util stuff
- * - Improved memory use in geos::geom::util::PolygonExtractor
- * - New ShortCircuitedGeometryVisitor class
- * - New operation/predicate package
- * Revision 1.17 2006/01/08 15:24:40 strk
- * Changed container-related typedef to class-scoped STL-like typedefs.
- * Fixed const correctness of EdgeIntersectionList::begin() and ::end() consts;
- * defined M_PI when undef as suggested by Charlie Savage.
- * Removed <stdio.h> include from GeometricShapeFactory.cpp.
- * Revision 1.16 2005/12/08 01:11:29 strk
- * minor optimizations in loops
- * Revision 1.15 2005/12/08 00:24:41 strk
- * Reduced coordinate assignments in ::createSplitEdge
- * Revision 1.14 2005/11/14 18:14:04 strk
- * Reduced heap allocations made by TopologyLocation and Label objects.
- * Enforced const-correctness on GraphComponent.
- * Cleanups.
- * Revision 1.13 2005/11/07 18:05:28 strk
- * Reduced set<> lookups
- * Revision 1.12 2005/11/07 12:31:24 strk
- * Changed EdgeIntersectionList to use a set<> rathern then a vector<>, and
- * to avoid dynamic allocation of initial header.
- * Inlined short SweepLineEvent methods.
- * Revision 1.11 2005/02/05 05:44:47 strk
- * Changed geomgraph nodeMap to use Coordinate pointers as keys, reduces
- * lots of other Coordinate copies.
- * Revision 1.10 2004/12/08 13:54:43 strk
- * gcc warnings checked and fixed, general cleanups.
- * Revision 1.9 2004/11/23 19:53:06 strk
- * Had LineIntersector compute Z by interpolation.
- * Revision 1.8 2004/11/22 13:02:12 strk
- * Forced use if computed intersection point in ::createSplitEdge (for Z computation)
- * Revision 1.7 2004/11/17 08:13:16 strk
- * Indentation changes.
- * Some Z_COMPUTATION activated by default.
- * Revision 1.6 2004/11/04 19:08:06 strk
- * Cleanups, initializers list, profiling.
- * Revision 1.5 2004/10/21 22:29:54 strk
- * Indentation changes and some more COMPUTE_Z rules
- * Revision 1.4 2004/10/20 17:32:14 strk
- * Initial approach to 2.5d intersection()
- * Revision 1.3 2004/07/08 19:34:49 strk
- * Mirrored JTS interface of CoordinateSequence, factory and
- * default implementations.
- * Added CoordinateArraySequenceFactory::instance() function.
- * Revision 1.2 2004/07/02 13:28:26 strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.1 2004/03/19 09:48:45 ybychkov
- * "geomgraph" and "geomgraph/indexl" upgraded to JTS 1.4
- * Revision 1.18 2003/11/07 01:23:42 pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
- * Revision 1.17 2003/11/06 19:04:28 strk
- * removed useless Coordinate copy in ::createSplitEdge()
Modified: trunk/src/geomgraph/NodeMap.cpp
--- trunk/src/geomgraph/NodeMap.cpp 2011-04-27 16:42:15 UTC (rev 3311)
+++ trunk/src/geomgraph/NodeMap.cpp 2011-04-28 10:04:11 UTC (rev 3312)
@@ -168,110 +168,3 @@
} // namespace geos
- * $Log$
- * Revision 1.16 2006/04/27 15:06:24 strk
- * (addNode): always use the Node Coordinate as a key in the map to reduce likeliness of a premature deletion.
- * Revision 1.15 2006/04/08 13:00:47 strk
- * assertion checking, mergeLabel() call fix (bug#91)
- * Revision 1.14 2006/03/14 12:55:55 strk
- * Headers split: geomgraphindex.h, nodingSnapround.h
- * Revision 1.13 2006/03/03 10:46:21 strk
- * Revision 1.12 2006/03/02 12:12:00 strk
- * Revision 1.11 2006/02/23 11:54:20 strk
- * - MCIndexPointSnapper
- * - MCIndexSnapRounder
- * - SnapRounding BufferOp
- * - ScaledNoder
- * - GEOSException hierarchy cleanups
- * - SpatialIndex memory-friendly query interface
- * - GeometryGraph::getBoundaryNodes memory-friendly
- * - NodeMap::getBoundaryNodes memory-friendly
- * - Cleanups in geomgraph::Edge
- * - Added an XML test for snaprounding buffer (shows leaks, working on it)
- * Revision 1.10 2006/02/19 19:46:49 strk
- * Revision 1.9 2006/01/08 15:24:40 strk
- * Revision 1.8 2005/11/21 16:03:20 strk
- * Coordinate interface change:
- * Removed setCoordinate call, use assignment operator
- * instead. Provided a compile-time switch to
- * make copy ctor and assignment operators non-inline
- * to allow for more accurate profiling.
- * Coordinate copies removal:
- * NodeFactory::createNode() takes now a Coordinate reference
- * rather then real value. This brings coordinate copies
- * in the testLeaksBig.xml test from 654818 to 645991
- * (tested in 2.1 branch). In the head branch Coordinate
- * copies are 222198.
- * Removed useless coordinate copies in ConvexHull
- * operations
- * STL containers heap allocations reduction:
- * Converted many containers element from
- * pointers to real objects.
- * Made some use of .reserve() or size
- * initialization when final container size is known
- * in advance.
- * Stateless classes allocations reduction:
- * Provided ::instance() function for
- * NodeFactories, to avoid allocating
- * more then one (they are all
- * stateless).
- * HCoordinate improvements:
- * Changed HCoordinate constructor by HCoordinates
- * take reference rather then real objects.
- * Changed HCoordinate::intersection to avoid
- * a new allocation but rather return into a provided
- * storage. LineIntersector changed to reflect
- * the above change.
- * Revision 1.7 2005/11/09 13:44:28 strk
- * Cleanups in Node and NodeMap.
- * Optimization of EdgeIntersectionLessThen.
- * Revision 1.6 2005/02/05 05:44:47 strk
- * Revision 1.5 2004/11/20 15:45:47 strk
- * Fixed Z merging in addNode(Node *)
- * Revision 1.4 2004/11/20 15:41:41 strk
- * Added Z merging in ::addNode
- * Revision 1.3 2004/10/21 22:29:54 strk
- * Revision 1.12 2003/11/07 01:23:42 pramsey
- * files.
Modified: trunk/src/operation/valid/IsValidOp.cpp
--- trunk/src/operation/valid/IsValidOp.cpp 2011-04-27 16:42:15 UTC (rev 3311)
+++ trunk/src/operation/valid/IsValidOp.cpp 2011-04-28 10:04:11 UTC (rev 3312)
@@ -669,214 +669,3 @@
} // namespace geos.operation
} // namespace geos
- * $Log$
- * Revision 1.51 2006/04/07 09:54:30 strk
- * Geometry::getNumGeometries() changed to return 'unsigned int'
- * rather then 'int'
- * Revision 1.50 2006/03/29 13:53:59 strk
- * EdgeRing equipped with Invariant testing function and lots of exceptional assertions. Removed useless heap allocations, and pointers usages.
- * Revision 1.49 2006/03/22 18:12:32 strk
- * indexChain.h header split.
- * Revision 1.48 2006/03/20 16:57:44 strk
- * spatialindex.h and opValid.h headers split
- * Revision 1.47 2006/03/17 16:48:55 strk
- * LineIntersector and PointLocator made complete components of RelateComputer
- * (were statics const pointers before). Reduced inclusions from opRelate.h
- * and opValid.h, updated .cpp files to allow build.
- * Revision 1.46 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.45 2006/03/06 19:40:47 strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
- * Revision 1.44 2006/03/06 12:47:52 strk
- * TopologyValidationError error names (enum) renamed to avoid conflicts.
- * Revision 1.43 2006/02/19 19:46:50 strk
- * Revision 1.42 2006/02/09 15:52:47 strk
- * GEOSException derived from std::exception; always thrown and cought by const ref.
- * Revision 1.41 2006/02/08 17:18:28 strk
- * - New WKTWriter::toLineString and ::toPoint convenience methods
- * - New IsValidOp::setSelfTouchingRingFormingHoleValid method
- * - New Envelope::centre()
- * - New Envelope::intersection(Envelope)
- * - New Envelope::expandBy(distance, [ydistance])
- * - New LineString::reverse()
- * - New MultiLineString::reverse()
- * - New Geometry::buffer(distance, quadSeg, endCapStyle)
- * - Obsoleted toInternalGeometry/fromInternalGeometry
- * - More const-correctness in Buffer "package"
- * Revision 1.40 2006/01/31 19:07:34 strk
- * Revision 1.39 2006/01/20 19:11:09 strk
- * Updated last port info
- * Revision 1.38 2006/01/08 15:24:40 strk
- * Revision 1.37 2005/11/25 11:31:21 strk
- * Removed all CoordinateSequence::getSize() calls embedded in for loops.
- * Revision 1.36 2005/11/21 16:03:20 strk
- * operations
- * in advance.
- * stateless).
- * Revision 1.35 2005/11/16 22:21:45 strk
- * enforced const-correctness and use of initializer lists.
- * Revision 1.34 2005/11/16 15:49:54 strk
- * Reduced gratuitous heap allocations.
- * Revision 1.33 2005/11/07 12:31:24 strk
- * Revision 1.32 2005/11/04 11:04:09 strk
- * Ported revision 1.38 of IsValidOp.java (adding closed Ring checks).
- * Changed NestedRingTester classes to use Coorinate pointers
- * rather then actual objects, to speedup NULL tests.
- * Added JTS port revision when applicable.
- * Revision 1.31 2005/11/01 09:40:42 strk
- * Replaced finite() with FINITE() calls.
- * Revision 1.30 2005/06/24 11:09:43 strk
- * Dropped RobustLineIntersector, made LineIntersector a concrete class.
- * Added LineIntersector::hasIntersection(Coordinate&,Coordinate&,Coordinate&)
- * to avoid computing intersection point (Z) when it's not necessary.
- * Revision 1.29 2005/04/07 18:43:20 strk
- * Fixed bug throwing an exception when a result could be returned instead
- * (ported JTS patch)
- * Revision 1.28 2005/02/05 05:44:47 strk
- * Revision 1.27 2004/12/08 13:54:44 strk
- * Revision 1.26 2004/11/06 08:16:46 strk
- * Fixed CGAlgorithms::isCCW from JTS port.
- * Code cleanup in IsValidOp.
- * Revision 1.25 2004/11/05 11:41:57 strk
- * Made IsValidOp handle IllegalArgumentException throw from GeometryGraph
- * as a sign of invalidity (just for Polygon geometries).
- * Removed leaks generated by this specific exception.
- * Revision 1.24 2004/10/19 19:51:14 strk
- * Fixed many leaks and bugs in Polygonizer.
- * Output still bogus.
- * Revision 1.23 2004/09/13 12:50:11 strk
- * comments cleanup
- * Revision 1.22 2004/09/13 12:39:14 strk
- * Made Point and MultiPoint subject to Validity tests.
- * Revision 1.21 2004/09/13 10:12:49 strk
- * Added invalid coordinates checks in IsValidOp.
- * Cleanups.
- * Revision 1.20 2004/09/13 09:18:10 strk
- * Added IsValidOp::isValid(Coordinate &)
- * Revision 1.19 2004/07/08 19:34:50 strk
- * Revision 1.18 2004/07/02 13:28:29 strk
- * Revision 1.17 2004/05/18 00:02:37 ybychkov
- * IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1 (not released yet) has been added.
- * Revision 1.16 2004/03/29 06:59:25 ybychkov
- * "noding/snapround" package ported (JTS 1.4);
- * "operation", "operation/valid", "operation/relate" and "operation/overlay" upgraded to JTS 1.4;
- * "geom" partially upgraded.
- * Revision 1.15 2003/11/07 01:23:42 pramsey
- * files.
- * Revision 1.14 2003/10/15 11:24:28 strk
- * Use getCoordinatesRO() introduced.
- * Revision 1.13 2003/10/13 17:54:40 strk
- * IsValidOp constructor used same name for the arg and a private
- * element. Fixed.
More information about the geos-commits
