[geos-commits] r3313 - in trunk: doc include/geos/geom/util
include/geos/util src/geom/util src/util
svn_geos at osgeo.org
Thu Apr 28 06:04:27 EDT 2011
Author: strk
Date: 2011-04-28 03:04:27 -0700 (Thu, 28 Apr 2011)
New Revision: 3313
Added:
trunk/include/geos/geom/util/SineStarFactory.h
trunk/src/geom/util/SineStarFactory.cpp
trunk/doc/example.cpp
trunk/include/geos/geom/util/Makefile.am
trunk/include/geos/util/GeometricShapeFactory.h
trunk/src/geom/util/Makefile.am
trunk/src/util/GeometricShapeFactory.cpp
Port geos::geom::util::SineStarFactory from JTS-1.12, useful for profile-test RectangleIntersects.
Modified: trunk/doc/example.cpp
--- trunk/doc/example.cpp 2011-04-28 10:04:11 UTC (rev 3312)
+++ trunk/doc/example.cpp 2011-04-28 10:04:27 UTC (rev 3313)
@@ -44,6 +44,7 @@
#include <geos/io/WKBWriter.h>
#include <geos/io/WKTWriter.h>
#include <geos/util/GeometricShapeFactory.h>
+#include <geos/geom/util/SineStarFactory.h>
#include <geos/util/GEOSException.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/opLinemerge.h>
@@ -71,6 +72,8 @@
using namespace geos::geom;
using namespace geos::operation::polygonize;
using namespace geos::operation::linemerge;
+using geos::util::GEOSException;
+using geos::util::IllegalArgumentException;
// Prototypes
@@ -333,7 +336,7 @@
Polygon *
create_circle(double centerX, double centerY, double radius)
- util::GeometricShapeFactory shapefactory(global_factory);
+ geos::util::GeometricShapeFactory shapefactory(global_factory);
shapefactory.setCentre(Coordinate(centerX, centerY));
shapefactory.setSize(radius);
// same as:
@@ -349,7 +352,7 @@
Polygon *
create_ellipse(double centerX, double centerY, double width, double height)
shapefactory.setHeight(height);
shapefactory.setWidth(width);
@@ -364,7 +367,7 @@
Polygon *
create_rectangle(double llX, double llY, double width, double height)
shapefactory.setBase(Coordinate(llX, llY));
@@ -381,7 +384,7 @@
LineString *
create_arc(double llX, double llY, double width, double height, double startang, double endang)
@@ -390,6 +393,18 @@
return shapefactory.createArc(startang, endang);
+auto_ptr<Polygon>
+create_sinestar(double cx, double cy, double size, int nArms, double armLenRat)
+ geos::geom::util::SineStarFactory fact(global_factory);
+ fact.setCentre(Coordinate(cx, cy));
+ fact.setSize(size);
+ fact.setNumPoints(nArms*5);
+ fact.setArmLengthRatio(armLenRat);
+ fact.setNumArms(nArms);
+ return fact.createSineStar();
// Start reading here
void do_all()
@@ -429,6 +444,7 @@
geoms->push_back(create_rectangle(-5, -5, 10, 20)); // a rectangle
// The upper-right quarter of a vertical ellipse
geoms->push_back(create_arc(0, 0, 10, 20, 0, M_PI/2));
+ geoms->push_back(create_sinestar(10, 10, 100, 5, 2).release()); // a sine star
#endif
// Print all geoms.
@@ -474,7 +490,7 @@
Geometry *g2 = g->buffer(10);
newgeoms->push_back(g2);
- catch (const util::GEOSException& exc) {
+ catch (const GEOSException& exc) {
cerr <<"GEOS Exception: geometry "<<i<<"->buffer(10): "<<exc.what()<<"\n";
@@ -540,7 +556,7 @@
else cout<<" 0\t";
// Geometry Collection is not a valid argument
- catch (const util::IllegalArgumentException& exc) {
+ catch (const IllegalArgumentException& exc) {
cout<<" X\t";
catch (const std::exception& exc) {
@@ -570,7 +586,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -600,7 +616,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -630,7 +646,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -660,7 +676,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -690,7 +706,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -720,7 +736,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -757,7 +773,7 @@
delete im; // delete afterwards
cout<<" X\t";
@@ -787,7 +803,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -818,7 +834,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -849,7 +865,7 @@
else cout<<" 0\t";
cout<<" X\t";
@@ -887,7 +903,7 @@
newgeoms->push_back(g3);
// It's illegal to union a collection ...
- catch (const util::IllegalArgumentException& ill) {
+ catch (const IllegalArgumentException& ill) {
//cerr <<ill.toString()<<"\n";
@@ -922,7 +938,7 @@
// Collection are illegal as intersection argument
@@ -955,7 +971,7 @@
// Collection are illegal as difference argument
@@ -988,7 +1004,7 @@
// Collection are illegal as symdifference argument
@@ -1079,7 +1095,7 @@
// All exception thrown by GEOS are subclasses of this
// one, so this is a catch-all
cerr <<"GEOS Exception: "<<exc.what()<<"\n";
exit(1);
Modified: trunk/include/geos/geom/util/Makefile.am
--- trunk/include/geos/geom/util/Makefile.am 2011-04-28 10:04:11 UTC (rev 3312)
+++ trunk/include/geos/geom/util/Makefile.am 2011-04-28 10:04:27 UTC (rev 3313)
@@ -19,4 +19,5 @@
LinearComponentExtracter.h \
PointExtracter.h \
PolygonExtracter.h \
- ShortCircuitedGeometryVisitor.h
+ ShortCircuitedGeometryVisitor.h \
+ SineStarFactory.h
Added: trunk/include/geos/geom/util/SineStarFactory.h
--- trunk/include/geos/geom/util/SineStarFactory.h (rev 0)
+++ trunk/include/geos/geom/util/SineStarFactory.h 2011-04-28 10:04:27 UTC (rev 3313)
@@ -0,0 +1,122 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: geom/util/SineStarFactory.java r378 (JTS-1.12)
+#ifndef GEOS_UTIL_SINESTARFACTORY_H
+#define GEOS_UTIL_SINESTARFACTORY_H
+#include <geos/export.h>
+#include <geos/util/GeometricShapeFactory.h> // for inheritance
+#include <memory>
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
+#endif
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Coordinate;
+ class Envelope;
+ class Polygon;
+ class GeometryFactory;
+ class PrecisionModel;
+ class LineString;
+namespace geos {
+namespace geom { // geos::geom
+namespace util { // geos::geom::util
+ * Creates geometries which are shaped like multi-armed stars
+ * with each arm shaped like a sine wave.
+ * These kinds of geometries are useful as a more complex
+ * geometry for testing algorithms.
+ * @author Martin Davis
+class GEOS_DLL SineStarFactory : public geos::util::GeometricShapeFactory {
+protected:
+ int numArms;
+ double armLengthRatio;
+public:
+ * Creates a factory which will create sine stars using the given
+ * {@link GeometryFactory}.
+ * @param fact the factory to use. You need to keep the
+ * factory alive for the whole SineStarFactory
+ * life time.
+ SineStarFactory(const geom::GeometryFactory* fact)
+ geos::util::GeometricShapeFactory(fact),
+ numArms(8),
+ armLengthRatio(0.5)
+ * Sets the number of arms in the star
+ * @param nArms the number of arms to generate
+ void setNumArms(int nArms)
+ numArms = numArms;
+ * Sets the ration of the length of each arm to the distance from the tip
+ * of the arm to the centre of the star.
+ * Value should be between 0.0 and 1.0
+ * @param armLenRatio
+ void setArmLengthRatio(double armLenRatio)
+ armLengthRatio = armLenRatio;
+ * Generates the geometry for the sine star
+ * @return the geometry representing the sine star
+ std::auto_ptr<Polygon> createSineStar() const;
+} // namespace geos::geom::util
+#ifdef _MSC_VER
+#pragma warning(pop)
+#endif
+#endif // GEOS_UTIL_SINESTARFACTORY_H
Modified: trunk/include/geos/util/GeometricShapeFactory.h
--- trunk/include/geos/util/GeometricShapeFactory.h 2011-04-28 10:04:11 UTC (rev 3312)
+++ trunk/include/geos/util/GeometricShapeFactory.h 2011-04-28 10:04:27 UTC (rev 3313)
@@ -80,14 +80,14 @@
void setHeight(double nHeight);
// Return newly-allocated object, ownership transferred
- geom::Envelope* getEnvelope();
+ geom::Envelope* getEnvelope() const;
const geom::GeometryFactory* geomFact; // externally owned
const geom::PrecisionModel* precModel; // externally owned
Dimensions dim;
int nPts;
- geom::Coordinate createCoord(double x, double y) const;
+ geom::Coordinate coord(double x, double y) const;
public:
@@ -103,7 +103,7 @@
GeometricShapeFactory(const geom::GeometryFactory *factory);
- ~GeometricShapeFactory();
+ virtual ~GeometricShapeFactory() {}
* \brief Creates an elliptical arc, as a LineString.
Modified: trunk/src/geom/util/Makefile.am
--- trunk/src/geom/util/Makefile.am 2011-04-28 10:04:11 UTC (rev 3312)
+++ trunk/src/geom/util/Makefile.am 2011-04-28 10:04:27 UTC (rev 3313)
@@ -12,4 +12,5 @@
GeometryEditor.cpp \
GeometryTransformer.cpp \
ShortCircuitedGeometryVisitor.cpp \
+ SineStarFactory.cpp \
GeometryCombiner.cpp
Added: trunk/src/geom/util/SineStarFactory.cpp
--- trunk/src/geom/util/SineStarFactory.cpp (rev 0)
+++ trunk/src/geom/util/SineStarFactory.cpp 2011-04-28 10:04:27 UTC (rev 3313)
@@ -0,0 +1,93 @@
+ * $Id$
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Envelope.h>
+#include <vector>
+#include <cmath>
+#include <memory>
+#ifndef M_PI
+#define M_PI 3.14159265358979323846
+#endif
+using namespace std;
+//using namespace geos::geom;
+namespace geos {
+/* public */
+auto_ptr<Polygon>
+SineStarFactory::createSineStar() const
+ auto_ptr<Envelope> env ( dim.getEnvelope() );
+ double radius = env->getWidth() / 2.0;
+ double armRatio = armLengthRatio;
+ if (armRatio < 0.0) armRatio = 0.0;
+ if (armRatio > 1.0) armRatio = 1.0;
+ double armMaxLen = armRatio * radius;
+ double insideRadius = (1 - armRatio) * radius;
+ double centreX = env->getMinX() + radius;
+ double centreY = env->getMinY() + radius;
+ auto_ptr< vector<Coordinate> > pts ( new vector<Coordinate>(nPts+1) );
+ int iPt = 0;
+ for (int i = 0; i < nPts; i++) {
+ // the fraction of the way thru the current arm - in [0,1]
+ double ptArcFrac = (i / (double) nPts) * numArms;
+ double armAngFrac = ptArcFrac - floor(ptArcFrac);
+ // the angle for the current arm - in [0,2Pi]
+ // (each arm is a complete sine wave cycle)
+ double armAng = 2 * M_PI * armAngFrac;
+ // the current length of the arm
+ double armLenFrac = (cos(armAng) + 1.0) / 2.0;
+ // the current radius of the curve (core + arm)
+ double curveRadius = insideRadius + armMaxLen * armLenFrac;
+ // the current angle of the curve
+ double ang = i * (2 * M_PI / nPts);
+ double x = curveRadius * cos(ang) + centreX;
+ double y = curveRadius * sin(ang) + centreY;
+ (*pts)[iPt++] = coord(x, y);
+ (*pts)[iPt] = Coordinate((*pts)[0]);
+ auto_ptr<CoordinateSequence> cs (
+ geomFact->getCoordinateSequenceFactory()->create( pts.release() )
+ auto_ptr<LinearRing> ring ( geomFact->createLinearRing( cs.release() ) );
+ auto_ptr<Polygon> poly ( geomFact->createPolygon(ring.release(), 0) );
+ return poly;
Modified: trunk/src/util/GeometricShapeFactory.cpp
--- trunk/src/util/GeometricShapeFactory.cpp 2011-04-28 10:04:11 UTC (rev 3312)
+++ trunk/src/util/GeometricShapeFactory.cpp 2011-04-28 10:04:27 UTC (rev 3313)
@@ -47,11 +47,6 @@
-GeometricShapeFactory::~GeometricShapeFactory()
- //delete dim;
void
GeometricShapeFactory::setBase(const Coordinate& base)
@@ -105,22 +100,22 @@
for (i = 0; i < nSide; i++) {
double x = env->getMinX() + i * XsegLen;
double y = env->getMinY();
- (*vc)[ipt++] = createCoord(x, y);
+ (*vc)[ipt++] = coord(x, y);
double x = env->getMaxX();
double y = env->getMinY() + i * YsegLen;
double x = env->getMaxX() - i * XsegLen;
double y = env->getMaxY();
double x = env->getMinX();
double y = env->getMaxY() - i * YsegLen;
(*vc)[ipt++] = (*vc)[0];
CoordinateSequence *cs = geomFact->getCoordinateSequenceFactory()->create(vc);
@@ -146,7 +141,7 @@
double ang = i * (2 * 3.14159265358979 / nPts);
double x = xRadius * cos(ang) + centreX;
double y = yRadius * sin(ang) + centreY;
- (*pts)[iPt++] = createCoord(x, y);
(*pts)[iPt++] = (*pts)[0];
CoordinateSequence *cs=geomFact->getCoordinateSequenceFactory()->create(pts);
@@ -177,7 +172,7 @@
double ang = startAng + i * angInc;
CoordinateSequence *cs = geomFact->getCoordinateSequenceFactory()->create(pts);
LineString* line = geomFact->createLineString(cs);
@@ -202,14 +197,14 @@
vector<Coordinate> *pts = new vector<Coordinate>(nPts + 2);
int iPt = 0;
- (*pts)[iPt++] = createCoord(centreX, centreY);
+ (*pts)[iPt++] = coord(centreX, centreY);
LinearRing* ring = geomFact->createLinearRing(cs);
@@ -255,7 +250,7 @@
Envelope*
-GeometricShapeFactory::Dimensions::getEnvelope()
+GeometricShapeFactory::Dimensions::getEnvelope() const
if (!base.isNull()) {
return new Envelope(base.x, base.x + width, base.y, base.y + height);
@@ -268,7 +263,7 @@
/*protected*/
Coordinate
-GeometricShapeFactory::createCoord(double x, double y) const
+GeometricShapeFactory::coord(double x, double y) const
Coordinate ret(x, y);
precModel->makePrecise(&ret);
@@ -278,13 +273,3 @@
} // namespace geos.util
} // namespace geos
- * $Log$
- * Revision 1.15 2006/03/22 16:58:35 strk
- * Removed (almost) all inclusions of geom.h.
- * Removed obsoleted .cpp files.
- * Fixed a bug in WKTReader not using the provided CoordinateSequence
- * implementation, optimized out some memory allocations.
More information about the geos-commits
