[geos-commits] r3317 - trunk/src/geom
svn_geos at osgeo.org
Thu Apr 28 11:08:47 EDT 2011
Author: strk
Date: 2011-04-28 08:08:47 -0700 (Thu, 28 Apr 2011)
New Revision: 3317
trunk/src/geom/Geometry.cpp
Do not leak on exception during relational geometry predicates
Modified: trunk/src/geom/Geometry.cpp
--- trunk/src/geom/Geometry.cpp 2011-04-28 14:16:56 UTC (rev 3316)
+++ trunk/src/geom/Geometry.cpp 2011-04-28 15:08:47 UTC (rev 3317)
@@ -305,9 +305,8 @@
if (! getEnvelopeInternal()->intersects(g->getEnvelopeInternal()))
return true;
#endif
- IntersectionMatrix *im=relate(g);
+ auto_ptr<IntersectionMatrix> im ( relate(g) );
bool res=im->isDisjoint();
- delete im;
return res;
@@ -319,9 +318,8 @@
return false;
#endif
bool res=im->isTouches(getDimension(), g->getDimension());
- delete im;
return res;
@@ -360,9 +358,8 @@
return predicate::RectangleIntersects::intersects(*p, *this);
bool res=im->isIntersects();
- delete im;
return res;
@@ -396,9 +393,8 @@
return false;
#endif
bool res=im->isCrosses(getDimension(), g->getDimension());
- delete im;
return res;
@@ -427,9 +423,8 @@
// return predicate::RectangleContains::contains((const Polygon&)*g, *this);
bool res=im->isContains();
- delete im;
return res;
@@ -441,18 +436,16 @@
return false;
#endif
bool res=im->isOverlaps(getDimension(), g->getDimension());
- delete im;
return res;
bool
Geometry::relate(const Geometry *g, const string &intersectionPattern) const
bool res=im->matches(intersectionPattern);
- delete im;
return res;
@@ -464,9 +457,8 @@
if (! getEnvelopeInternal()->equals(g->getEnvelopeInternal()))
return false;
#endif
bool res=im->isEquals(getDimension(), g->getDimension());
- delete im;
return res;
More information about the geos-commits
