[geos-commits] r3318 - in trunk: include/geos/operation/relate
	src/operation/relate
    svn_geos at osgeo.org
    Thu Apr 28 11:08:56 EDT 2011
Author: strk
Date: 2011-04-28 08:08:56 -0700 (Thu, 28 Apr 2011)
New Revision: 3318
   trunk/include/geos/operation/relate/RelateComputer.h
   trunk/src/operation/relate/RelateComputer.cpp
Plug leak on exception in RelateComputer (exposed by running doc/example)
Modified: trunk/include/geos/operation/relate/RelateComputer.h
--- trunk/include/geos/operation/relate/RelateComputer.h	2011-04-28 15:08:47 UTC (rev 3317)
+++ trunk/include/geos/operation/relate/RelateComputer.h	2011-04-28 15:08:56 UTC (rev 3318)
@@ -1,10 +1,11 @@
- * $Id$
  * GEOS - Geometry Engine Open Source
  * http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
  * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
@@ -28,6 +29,7 @@
 #include <geos/geom/Coordinate.h> // for RelateComputer composition
 #include <vector>
+#include <memory>
 #ifdef _MSC_VER
 #pragma warning(push)
@@ -72,8 +74,6 @@
 class GEOS_DLL RelateComputer {
 public:
-	//RelateComputer();
-	virtual ~RelateComputer();
 	RelateComputer(std::vector<geomgraph::GeometryGraph*> *newArg);
 	geom::IntersectionMatrix* computeIM();
 private:
@@ -88,7 +88,7 @@
 	geomgraph::NodeMap nodes;
 	/// this intersection matrix will hold the results compute for the relate
-	geom::IntersectionMatrix *im;
+	std::auto_ptr<geom::IntersectionMatrix> im;
 	std::vector<geomgraph::Edge*> isolatedEdges;
@@ -97,18 +97,61 @@
 	void insertEdgeEnds(std::vector<geomgraph::EdgeEnd*> *ee);
-	void computeProperIntersectionIM(geomgraph::index::SegmentIntersector *intersector,
-			geom::IntersectionMatrix *imX);
+	void computeProperIntersectionIM(
+	    geomgraph::index::SegmentIntersector *intersector,
+	    geom::IntersectionMatrix *imX);
 	void copyNodesAndLabels(int argIndex);
 	void computeIntersectionNodes(int argIndex);
 	void labelIntersectionNodes(int argIndex);
+	 * If the Geometries are disjoint, we need to enter their dimension and
+	 * boundary dimension in the Ext rows in the IM
 	void computeDisjointIM(geom::IntersectionMatrix *imX);
 	void labelNodeEdges();
+	 * update the IM with the sum of the IMs for each component
 	void updateIM(geom::IntersectionMatrix *imX);
+	 * Processes isolated edges by computing their labelling and adding them
+	 * to the isolated edges list.
+	 * Isolated edges are guaranteed not to touch the boundary of the target
+	 * (since if they
+	 * did, they would have caused an intersection to be computed and hence would
+	 * not be isolated)
 	void labelIsolatedEdges(int thisIndex,int targetIndex);
-	void labelIsolatedEdge(geomgraph::Edge *e,int targetIndex, const geom::Geometry *target);
+	 * Label an isolated edge of a graph with its relationship to the target
+	 * geometry.
+	 * If the target has dim 2 or 1, the edge can either be in the interior
+	 * or the exterior.
+	 * If the target has dim 0, the edge must be in the exterior
+	void labelIsolatedEdge(geomgraph::Edge *e,int targetIndex,
+	                       const geom::Geometry *target);
+	 * Isolated nodes are nodes whose labels are incomplete
+	 * (e.g. the location for one Geometry is null).
+	 * This is the case because nodes in one graph which don't intersect
+	 * nodes in the other are not completely labelled by the initial process
+	 * of adding nodes to the nodeList.
+	 * To complete the labelling we need to check for nodes that lie in the
+	 * interior of edges, and in the interior of areas.
 	void labelIsolatedNodes();
+	 * Label an isolated node with its relationship to the target geometry.
 	void labelIsolatedNode(geomgraph::Node *n,int targetIndex);
Modified: trunk/src/operation/relate/RelateComputer.cpp
--- trunk/src/operation/relate/RelateComputer.cpp	2011-04-28 15:08:47 UTC (rev 3317)
+++ trunk/src/operation/relate/RelateComputer.cpp	2011-04-28 15:08:56 UTC (rev 3318)
@@ -1,11 +1,11 @@
- * $Id$
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
  * Copyright (C) 2005 Refractions Research Inc.
@@ -55,10 +55,6 @@
-RelateComputer::~RelateComputer()
 IntersectionMatrix*
 RelateComputer::computeIM()
@@ -68,17 +64,21 @@
 	const Envelope *e1=(*arg)[0]->getGeometry()->getEnvelopeInternal();
 	const Envelope *e2=(*arg)[1]->getGeometry()->getEnvelopeInternal();
 	if (!e1->intersects(e2)) {
-		computeDisjointIM(im);
-		//delete e1;
-		//delete e2;
-		return im;
+		computeDisjointIM(im.get());
+		return im.release();
-	SegmentIntersector *si1=(*arg)[0]->computeSelfNodes(&li,false);
-	SegmentIntersector *si2=(*arg)[1]->computeSelfNodes(&li,false);
+	std::auto_ptr<SegmentIntersector> si1 (
+		(*arg)[0]->computeSelfNodes(&li,false)
+	std::auto_ptr<SegmentIntersector> si2 (
+		(*arg)[1]->computeSelfNodes(&li,false)
 	// compute intersections between edges of the two input geometries
-	SegmentIntersector *intersector=(*arg)[0]->computeEdgeIntersections((*arg)[1], &li,false);
+	std::auto_ptr< SegmentIntersector> intersector (
+    (*arg)[0]->computeEdgeIntersections((*arg)[1], &li,false)
 	computeIntersectionNodes(0);
 	computeIntersectionNodes(1);
@@ -103,7 +103,7 @@
 	 * If a proper intersection was found, we can set a lower bound
 	 * on the IM.
-	computeProperIntersectionIM(intersector, im);
+	computeProperIntersectionIM(intersector.get(), im.get());
 	 * Now process improper intersections
@@ -114,10 +114,14 @@
 	// build EdgeEnds for all intersections
 	EdgeEndBuilder eeBuilder;
-	std::vector<EdgeEnd*> *ee0=eeBuilder.computeEdgeEnds((*arg)[0]->getEdges());
-	insertEdgeEnds(ee0);
-	std::vector<EdgeEnd*> *ee1=eeBuilder.computeEdgeEnds((*arg)[1]->getEdges());
-	insertEdgeEnds(ee1);
+	std::auto_ptr< std::vector<EdgeEnd*> > ee0 (
+		eeBuilder.computeEdgeEnds((*arg)[0]->getEdges())
+	insertEdgeEnds(ee0.get());
+	std::auto_ptr< std::vector<EdgeEnd*> > ee1 (
+		eeBuilder.computeEdgeEnds((*arg)[1]->getEdges())
+	insertEdgeEnds(ee1.get());
 	//Debug.println("==== NodeList ===");
 	//Debug.print(nodes);
 	labelNodeEdges();
@@ -138,13 +142,8 @@
 	//debugPrintln("Graph B isolated edges - ");
 	labelIsolatedEdges(1,0);
 	// update the IM from all components
-	updateIM(im);
-	delete si1;
-	delete si2;
-	delete intersector;
-	delete ee0;
-	delete ee1;
-	return im;
+	updateIM(im.get());
 void
@@ -295,10 +294,7 @@
- * If the Geometries are disjoint, we need to enter their dimension and
- * boundary dimension in the Ext rows in the IM
+/* private */
 void
 RelateComputer::computeDisjointIM(IntersectionMatrix *imX)
@@ -330,9 +326,7 @@
- * update the IM with the sum of the IMs for each component
+/*private*/
 void
 RelateComputer::updateIM(IntersectionMatrix *imX)
@@ -356,14 +350,10 @@
-* Processes isolated edges by computing their labelling and adding them
-* to the isolated edges list.
-* Isolated edges are guaranteed not to touch the boundary of the target (since if they
-* did, they would have caused an intersection to be computed and hence would
-* not be isolated)
-void RelateComputer::labelIsolatedEdges(int thisIndex,int targetIndex) {
+/*private*/
+void
+RelateComputer::labelIsolatedEdges(int thisIndex,int targetIndex)
 	std::vector<Edge*> *edges=(*arg)[thisIndex]->getEdges();
 	for(std::vector<Edge*>::iterator i=edges->begin();i<edges->end();i++) {
 		Edge *e=*i;
@@ -374,11 +364,7 @@
- * Label an isolated edge of a graph with its relationship to the target geometry.
- * If the target has dim 2 or 1, the edge can either be in the interior or the exterior.
- * If the target has dim 0, the edge must be in the exterior
+/* private */
 void
 RelateComputer::labelIsolatedEdge(Edge *e, int targetIndex, const Geometry *target)
@@ -395,15 +381,7 @@
 	//System.out.println(e.getLabel());
- * Isolated nodes are nodes whose labels are incomplete
- * (e.g. the location for one Geometry is null).
- * This is the case because nodes in one graph which don't intersect
- * nodes in the other are not completely labelled by the initial process
- * of adding nodes to the nodeList.
- * To complete the labelling we need to check for nodes that lie in the
- * interior of edges, and in the interior of areas.
+/*private*/
 void
 RelateComputer::labelIsolatedNodes()
@@ -423,9 +401,7 @@
- * Label an isolated node with its relationship to the target geometry.
+/* private */
 void
 RelateComputer::labelIsolatedNode(Node *n,int targetIndex)
@@ -439,24 +415,3 @@
 } // namespace geos.operation
 } // namespace geos
- * $Log$
- * Revision 1.32  2006/03/21 13:11:29  strk
- * opRelate.h header split
- * Revision 1.31  2006/03/20 16:57:44  strk
- * spatialindex.h and opValid.h headers split
- * Revision 1.30  2006/03/17 16:48:55  strk
- * LineIntersector and PointLocator made complete components of RelateComputer
- * (were statics const pointers before). Reduced inclusions from opRelate.h
- * and opValid.h, updated .cpp files to allow build.
- * Revision 1.29  2006/03/09 16:46:49  strk
- * geos::geom namespace definition, first pass at headers split
- * Revision 1.28  2006/03/06 19:40:47  strk
- * geos::util namespace. New GeometryCollection::iterator interface, many cleanups.
More information about the geos-commits
