[geos-commits] r3171 - in trunk: include/geos/geom src/geom
svn_geos at osgeo.org
Wed Feb 2 12:41:29 EST 2011
Author: strk
Date: 2011-02-02 09:41:29 -0800 (Wed, 02 Feb 2011)
New Revision: 3171
Added:
trunk/include/geos/geom/Lineal.h
trunk/include/geos/geom/Polygonal.h
trunk/include/geos/geom/Puntal.h
trunk/include/geos/geom/LineString.h
trunk/include/geos/geom/Makefile.am
trunk/include/geos/geom/MultiLineString.h
trunk/include/geos/geom/MultiLineString.inl
trunk/include/geos/geom/MultiPoint.h
trunk/include/geos/geom/MultiPolygon.h
trunk/include/geos/geom/Point.h
trunk/include/geos/geom/Polygon.h
trunk/src/geom/LineString.cpp
trunk/src/geom/MultiLineString.cpp
trunk/src/geom/MultiPoint.cpp
trunk/src/geom/MultiPolygon.cpp
trunk/src/geom/Point.cpp
trunk/src/geom/Polygon.cpp
Add Puntal, Lineal and Polygonal "interfaces"
Modified: trunk/include/geos/geom/LineString.h
--- trunk/include/geos/geom/LineString.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/LineString.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2001-2002 Vivid Solutions Inc.
* Copyright (C) 2005 2006 Refractions Research Inc.
@@ -14,7 +15,7 @@
- * Last port: geom/LineString.java rev. 1.46
+ * Last port: geom/LineString.java r320 (JTS-1.12)
@@ -24,6 +25,7 @@
#include <geos/export.h>
#include <geos/platform.h> // do we need this ?
#include <geos/geom/Geometry.h> // for inheritance
+#include <geos/geom/Lineal.h> // for inheritance
#include <geos/geom/CoordinateSequence.h> // for proper use of auto_ptr<>
#include <geos/geom/Envelope.h> // for proper use of auto_ptr<>
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
@@ -51,10 +53,22 @@
namespace geom { // geos::geom
- * \class LineString geom.h geos.h
- * \brief Basic implementation of LineString.
+ * Models an OGC-style <code>LineString</code>.
+ * A LineString consists of a sequence of two or more vertices,
+ * along with all points along the linearly-interpolated curves
+ * (line segments) between each
+ * pair of consecutive vertices.
+ * Consecutive vertices may be equal.
+ * The line segments in the line may intersect each other (in other words,
+ * the linestring may "curl back" in itself and self-intersect.
+ * Linestrings with exactly two identical points are invalid.
+ * A linestring must have either 0 or 2 or more points.
+ * If these conditions are not met, the constructors throw
+ * an {@link IllegalArgumentException}
-class GEOS_DLL LineString: public Geometry {
+class GEOS_DLL LineString: public Geometry, public Lineal {
public:
Copied: trunk/include/geos/geom/Lineal.h (from rev 3170, trunk/include/geos/geom/MultiLineString.inl)
--- trunk/include/geos/geom/Lineal.h (rev 0)
+++ trunk/include/geos/geom/Lineal.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -0,0 +1,35 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: geom/Lineal.java r320 (JTS-1.12)
+#ifndef GEOS_GEOM_LINEAL_H
+#define GEOS_GEOM_LINEAL_H
+namespace geos {
+namespace geom { // geos::geom
+ * Identifies {@link Geometry} subclasses which
+ * are 1-dimensional and with components which are {@link LineString}s.
+class Lineal {};
+} // namespace geos::geom
+#endif // ndef GEOS_GEOM_LINEAL_H
Modified: trunk/include/geos/geom/Makefile.am
--- trunk/include/geos/geom/Makefile.am 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/Makefile.am 2011-02-02 17:41:29 UTC (rev 3171)
@@ -49,4 +49,7 @@
Polygon.h \
PrecisionModel.h \
PrecisionModel.inl \
- Triangle.h
+ Triangle.h \
+ Puntal.h \
+ Lineal.h \
+ Polygonal.h
Modified: trunk/include/geos/geom/MultiLineString.h
--- trunk/include/geos/geom/MultiLineString.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/MultiLineString.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: geom/MultiLineString.java rev. 1.40
+ * Last port: geom/MultiLineString.java r320 (JTS-1.12)
@@ -23,7 +24,7 @@
#include <geos/geom/GeometryCollection.h> // for inheritance
-//#include <geos/platform.h>
#include <string>
@@ -42,8 +43,8 @@
namespace geos {
-/// Basic implementation of MultiLineString objects.
-class GEOS_DLL MultiLineString: public GeometryCollection {
+/// Models a collection of (@link LineString}s.
+class GEOS_DLL MultiLineString: public GeometryCollection, public Lineal {
public:
Modified: trunk/include/geos/geom/MultiLineString.inl
--- trunk/include/geos/geom/MultiLineString.inl 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/MultiLineString.inl 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
* Copyright (C) 2005-2006 Refractions Research Inc.
@@ -13,7 +14,7 @@
Modified: trunk/include/geos/geom/MultiPoint.h
--- trunk/include/geos/geom/MultiPoint.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/MultiPoint.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: geom/MultiPoint.java rev. 1.30
+ * Last port: geom/MultiPoint.java r320 (JTS-1.12)
@@ -23,7 +24,8 @@
-#include <geos/geom/GeometryCollection.h>
+#include <geos/geom/GeometryCollection.h> // for inheritance
+#include <geos/geom/Puntal.h> // for inheritance
#include <geos/inline.h>
@@ -42,10 +44,12 @@
- * \class MultiPoint geom.h geos.h
- * \brief Models a collection of Point objects.
+ * Models a collection of Point objects.
+ * Any collection of Points is a valid MultiPoint.
-class GEOS_DLL MultiPoint: public GeometryCollection {
+class GEOS_DLL MultiPoint: public GeometryCollection, public Puntal
public:
Modified: trunk/include/geos/geom/MultiPolygon.h
--- trunk/include/geos/geom/MultiPolygon.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/MultiPolygon.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: geom/MultiPolygon.java rev 1.34
+ * Last port: geom/MultiPolygon.java r320 (JTS-1.12)
@@ -25,7 +26,8 @@
#include <string>
#include <vector>
+#include <geos/geom/Polygonal.h> // for inheritance
@@ -43,8 +45,15 @@
namespace geos {
-/// Basic implementation of <code>MultiPolygon</code>.
-class GEOS_DLL MultiPolygon: public GeometryCollection
+/// Models a collection of {@link Polygon}s.
+/// As per the OGC SFS specification,
+/// the Polygons in a MultiPolygon may not overlap,
+/// and may only touch at single points.
+/// This allows the topological point-set semantics
+/// to be well-defined.
+class GEOS_DLL MultiPolygon: public GeometryCollection, public Polygonal
public:
Modified: trunk/include/geos/geom/Point.h
--- trunk/include/geos/geom/Point.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/Point.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: geom/Point.java rev. 1.37 (JTS-1.10)
+ * Last port: geom/Point.java r320 (JTS-1.12)
@@ -23,7 +24,8 @@
-#include <geos/geom/Geometry.h>
+#include <geos/geom/Geometry.h> // for inheritance
@@ -55,12 +57,15 @@
- * \class Point geom.h geos.h
- * \brief Basic implementation of Point.
+ * Implementation of Point.
+ * A Point is valid iff:
+ * - the coordinate which defines it is a valid coordinate
+ * (i.e does not have an NaN X or Y ordinate)
-class GEOS_DLL Point : public Geometry
- // NOTE: in JTS Point implements Puntual
+class GEOS_DLL Point : public Geometry, public Puntal
public:
@@ -87,7 +92,6 @@
size_t getNumPoints() const;
bool isEmpty() const;
bool isSimple() const;
- //bool isValid() const;
/// Returns point dimension (0)
Dimension::DimensionType getDimension() const;
Modified: trunk/include/geos/geom/Polygon.h
--- trunk/include/geos/geom/Polygon.h 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/include/geos/geom/Polygon.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
- * Last port: geom/Polygon.java rev. 1.50
+ * Last port: geom/Polygon.java r320 (JTS-1.12)
@@ -25,7 +26,8 @@
#include <string>
#include <vector>
@@ -62,7 +64,8 @@
* Specification for SQL</A> .
-class GEOS_DLL Polygon: public Geometry{
+class GEOS_DLL Polygon: public Geometry, public Polygonal
public:
@@ -190,10 +193,6 @@
} // namespace geos
-//#ifdef GEOS_INLINE
-//# include "geos/geom/Polygon.inl"
-//#endif
#endif // ndef GEOS_GEOM_POLYGON_H
Copied: trunk/include/geos/geom/Polygonal.h (from rev 3170, trunk/include/geos/geom/MultiLineString.inl)
--- trunk/include/geos/geom/Polygonal.h (rev 0)
+++ trunk/include/geos/geom/Polygonal.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -0,0 +1,35 @@
+ * $Id$
+ * Last port: geom/Polygonal.java r320 (JTS-1.12)
+#ifndef GEOS_GEOM_POLYGONAL_H
+#define GEOS_GEOM_POLYGONAL_H
+namespace geos {
+ * are 2-dimensional and with components which are {@link Polygon}s.
+class Polygonal {};
+#endif // ndef GEOS_GEOM_POLYGONAL_H
Copied: trunk/include/geos/geom/Puntal.h (from rev 3170, trunk/include/geos/geom/MultiLineString.inl)
--- trunk/include/geos/geom/Puntal.h (rev 0)
+++ trunk/include/geos/geom/Puntal.h 2011-02-02 17:41:29 UTC (rev 3171)
@@ -0,0 +1,35 @@
+ * $Id$
+ * Last port: geom/Puntal.java r320 (JTS-1.12)
+#ifndef GEOS_GEOM_PUNTAL_H
+#define GEOS_GEOM_PUNTAL_H
+namespace geos {
+ * are 0-dimensional and with components which are {@link Point}s.
+class Puntal {};
+#endif // ndef GEOS_GEOM_PUNTAL_H
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/LineString.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
Modified: trunk/src/geom/MultiLineString.cpp
--- trunk/src/geom/MultiLineString.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/MultiLineString.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
Modified: trunk/src/geom/MultiPoint.cpp
--- trunk/src/geom/MultiPoint.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/MultiPoint.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
Modified: trunk/src/geom/MultiPolygon.cpp
--- trunk/src/geom/MultiPolygon.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/MultiPolygon.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -13,7 +14,7 @@
Modified: trunk/src/geom/Point.cpp
--- trunk/src/geom/Point.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/Point.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
@@ -90,8 +91,6 @@
return true;
-//bool Point::isValid() const {return true;}
Point::getDimension() const
Modified: trunk/src/geom/Polygon.cpp
--- trunk/src/geom/Polygon.cpp 2011-01-27 18:01:29 UTC (rev 3170)
+++ trunk/src/geom/Polygon.cpp 2011-02-02 17:41:29 UTC (rev 3171)
@@ -4,6 +4,7 @@
@@ -14,7 +15,7 @@
More information about the geos-commits
