[geos-commits] r3172 - in trunk: include/geos/geom/util
src/geom/util
svn_geos at osgeo.org
Wed Feb 2 12:57:11 EST 2011
Author: strk
Date: 2011-02-02 09:57:11 -0800 (Wed, 02 Feb 2011)
New Revision: 3172
trunk/include/geos/geom/util/GeometryCombiner.h
trunk/src/geom/util/GeometryCombiner.cpp
Check GeometryCombiner against JTS-1.12
Modified: trunk/include/geos/geom/util/GeometryCombiner.h
--- trunk/include/geos/geom/util/GeometryCombiner.h 2011-02-02 17:41:29 UTC (rev 3171)
+++ trunk/include/geos/geom/util/GeometryCombiner.h 2011-02-02 17:57:11 UTC (rev 3172)
@@ -4,14 +4,19 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2006-2011 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: geom/util/GeometryCombiner.java r320 (JTS-1.12)
#ifndef GEOS_GEOM_UTIL_GEOMETRYCOMBINER_H
#define GEOS_GEOM_UTIL_GEOMETRYCOMBINER_H
@@ -35,8 +40,8 @@
* Input geometries which are already collections
* will have their elements extracted first.
* No validation of the result geometry is performed.
- * (The only case where invalidity is possible is where {@link Polygonal} geometries
- * are combined and result in a self-intersection).
+ * (The only case where invalidity is possible is where {@link Polygonal}
+ * geometries are combined and result in a self-intersection).
* @see GeometryFactory#buildGeometry
Modified: trunk/src/geom/util/GeometryCombiner.cpp
--- trunk/src/geom/util/GeometryCombiner.cpp 2011-02-02 17:41:29 UTC (rev 3171)
+++ trunk/src/geom/util/GeometryCombiner.cpp 2011-02-02 17:57:11 UTC (rev 3172)
@@ -4,13 +4,17 @@
#include <geos/geom/util/GeometryCombiner.h>
More information about the geos-commits
