[geos-commits] r3191 - in trunk: include/geos/geom src src/geom tests/unit/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Feb 10 06:09:55 EST 2011
Author: strk
Date: 2011-02-10 03:09:55 -0800 (Thu, 10 Feb 2011)
New Revision: 3191
Removed:
   trunk/include/geos/geom/Geometry.inl
   trunk/include/geos/geom/Geometry.h
   trunk/include/geos/geom/GeometryFactory.h
   trunk/include/geos/geom/Makefile.am
   trunk/src/geom/Geometry.cpp
   trunk/src/inlines.cpp
   trunk/tests/unit/geom/GeometryFactoryTest.cpp
Introduce a templated version of GeometryFactory::buildGeometry, and test it.
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/include/geos/geom/Geometry.h	2011-02-10 11:09:55 UTC (rev 3191)
@@ -866,10 +866,6 @@
 #pragma warning(pop)
 #endif
-#ifdef GEOS_INLINE
-# include <geos/geom/Geometry.inl>
-#endif
 #endif // ndef GEOS_GEOM_GEOMETRY_H
Deleted: trunk/include/geos/geom/Geometry.inl
--- trunk/include/geos/geom/Geometry.inl	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/include/geos/geom/Geometry.inl	2011-02-10 11:09:55 UTC (rev 3191)
@@ -1,41 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2009  Sandro Santilli <strk at keybit.net>
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: geom/Geometry.java rev. 1.112
-#ifndef GEOS_GEOM_GEOMETRY_INL
-#define GEOS_GEOM_GEOMETRY_INL
-#include <geos/geom/Geometry.h>
-#include <geos/geom/GeometryFactory.h>
-namespace geos {
-namespace geom { // geos::geom
-INLINE const PrecisionModel*
-Geometry::getPrecisionModel() const
-	return factory->getPrecisionModel();
-} // namespace geos::geom
-#endif // GEOS_GEOM_GEOMETRY_INL
Modified: trunk/include/geos/geom/GeometryFactory.h
--- trunk/include/geos/geom/GeometryFactory.h	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/include/geos/geom/GeometryFactory.h	2011-02-10 11:09:55 UTC (rev 3191)
@@ -22,12 +22,13 @@
 #define GEOS_GEOM_GEOMETRYFACTORY_H
 //#include <geos/geom/CoordinateSequence.h>
-//#include <geos/geom/Geometry.h>
+#include <geos/geom/Geometry.h>
 #include <geos/export.h>
 #include <geos/inline.h>
 #include <vector>
 #include <memory>
+#include <cassert>
 namespace geos {
 	namespace geom {
@@ -291,6 +292,72 @@
 	Geometry* buildGeometry(std::vector<Geometry *> *geoms) const;
+  /// See buildGeometry(std::vector<Geometry *>&) for semantics
+  /// Will clone the geometries accessible trough the iterator.
+  /// @tparam T an iterator yelding something which casts to const Geometry*
+  /// @param from start iterator
+  /// @param toofar end iterator
+  template <class T>
+	std::auto_ptr<Geometry> buildGeometry(T from, T toofar) const
+    bool isHeterogeneous = false;
+    size_t count = 0;
+    int geomClass = -1;
+    for (T i=from; i != toofar; ++i)
+      ++count;
+      const Geometry* g = *i;
+      if ( geomClass < 0 ) {
+        geomClass = g->getClassSortIndex();
+      else if ( geomClass != g->getClassSortIndex() ) {
+        isHeterogeneous = true;
+    // for the empty geometry, return an empty GeometryCollection
+    if ( count == 0 ) {
+      return std::auto_ptr<Geometry>( createGeometryCollection() );
+    // for the single geometry, return a clone
+    if ( count == 1 ) {
+      return std::auto_ptr<Geometry>( (*from)->clone() );
+    // Now we know it is a collection
+    // FIXME:
+    // Until we tweak all the createMulti* interfaces
+    // to support taking iterators we'll have to build
+    // a custom vector here.
+    std::vector<Geometry*> fromGeoms;
+    for (T i=from; i != toofar; ++i) {
+      fromGeoms.push_back(const_cast<Geometry*>(g));
+    // for an heterogeneous ...
+    if ( isHeterogeneous ) {
+      return std::auto_ptr<Geometry>( createGeometryCollection(fromGeoms) );
+    // At this point we know the collection is not hetereogenous.
+    if ( dynamic_cast<const Polygon*>(*from) ) {
+      return std::auto_ptr<Geometry>( createMultiPolygon(fromGeoms) );
+    } else if ( dynamic_cast<const LineString*>(*from) ) {
+      return std::auto_ptr<Geometry>( createMultiLineString(fromGeoms) );
+    } else if ( dynamic_cast<const Point*>(*from) ) {
+      return std::auto_ptr<Geometry>( createMultiPoint(fromGeoms) );
+    assert(0); // buildGeomtry encountered an unkwnon geometry type
 	/** \brief
 	 * This function does the same thing of the omonimouse function
 	 * taking vector pointer instead of reference.
Modified: trunk/include/geos/geom/Makefile.am
--- trunk/include/geos/geom/Makefile.am	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/include/geos/geom/Makefile.am	2011-02-10 11:09:55 UTC (rev 3191)
@@ -32,7 +32,6 @@
     GeometryFactory.inl \
     GeometryFilter.h \
     Geometry.h \
-    Geometry.inl \
     GeometryList.h \
     IntersectionMatrix.h \
     LinearRing.h \
Modified: trunk/src/geom/Geometry.cpp
--- trunk/src/geom/Geometry.cpp	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/src/geom/Geometry.cpp	2011-02-10 11:09:55 UTC (rev 3191)
@@ -63,10 +63,6 @@
 #define SHORTCIRCUIT_PREDICATES 1
-#ifndef GEOS_INLINE
-#endif
 using namespace std;
 using namespace geos::algorithm;
 using namespace geos::operation::valid;
@@ -825,6 +821,13 @@
 	return op.isSimple();
+/* public */
+const PrecisionModel*
+Geometry::getPrecisionModel() const
+	return factory->getPrecisionModel();
 } // namespace geos
Modified: trunk/src/inlines.cpp
--- trunk/src/inlines.cpp	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/src/inlines.cpp	2011-02-10 11:09:55 UTC (rev 3191)
@@ -51,7 +51,6 @@
 #include <geos/geom/GeometryCollection.inl>
 #include <geos/geom/LineSegment.inl>
 #include <geos/geom/PrecisionModel.inl>
-#include <geos/geom/Geometry.inl>
 #include <geos/geom/Envelope.inl>
 #include <geos/geom/Coordinate.inl>
 #include <geos/geom/GeometryFactory.inl>
Modified: trunk/tests/unit/geom/GeometryFactoryTest.cpp
--- trunk/tests/unit/geom/GeometryFactoryTest.cpp	2011-02-10 11:09:41 UTC (rev 3190)
+++ trunk/tests/unit/geom/GeometryFactoryTest.cpp	2011-02-10 11:09:55 UTC (rev 3191)
@@ -1237,4 +1237,48 @@
 		//inform("Test not implemented!");
+	// Test of
+  // buildGeometry(from, to, takeOwnership) const
+	template<>
+	template<>
+	void object::test<36>()
+    typedef std::auto_ptr<geos::geom::Geometry> GeometryAutoPtr;
+		typedef std::vector<PointPtr> PointVect;
+		const std::size_t size = 3;
+		geos::geom::Coordinate coord(x_, y_, z_);
+		PointVect vec;
+		PointPtr geo = 0;
+		geo = factory_.createPoint(coord);
+		vec.push_back(geo);
+		coord.x *= 2;
+		coord.y *= 2;
+		coord.z *= 2;
+		coord.x *= 3;
+		coord.y *= 3;
+		coord.z *= 3;
+		// Factory creates copy of the vec collection
+		GeometryAutoPtr go = factory_.buildGeometry(vec.begin(), vec.end());
+		ensure( go.get() );
+		ensure_equals( go->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT );
+		ensure_equals( go->getNumGeometries(), size );
+		// FREE MEMORY
+		PointVect::const_iterator it;
+		for (it = vec.begin(); it != vec.end(); ++it)
+			delete (*it);
 } // namespace tut
More information about the geos-commits mailing list
