[geos-commits] r3192 - in trunk: include/geos/operation/union
src/operation/union tests/unit/operation/union
svn_geos at osgeo.org
Thu Feb 10 08:48:34 EST 2011
Author: strk
Date: 2011-02-10 05:48:34 -0800 (Thu, 10 Feb 2011)
New Revision: 3192
trunk/include/geos/operation/union/CascadedPolygonUnion.h
trunk/src/operation/union/CascadedPolygonUnion.cpp
trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
Add a template interface to CascadedPolygonUnion to relax requirements on used container
Modified: trunk/include/geos/operation/union/CascadedPolygonUnion.h
--- trunk/include/geos/operation/union/CascadedPolygonUnion.h 2011-02-10 11:09:55 UTC (rev 3191)
+++ trunk/include/geos/operation/union/CascadedPolygonUnion.h 2011-02-10 13:48:34 UTC (rev 3192)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2006 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -13,7 +14,7 @@
- * Last port: operation/union/CascadedPolygonUnion.java rev 1.10 (JTS-1.10)
+ * Last port: operation/union/CascadedPolygonUnion.java r320 (JTS-1.12)
@@ -89,7 +90,7 @@
* This algorithm is faster and likely more robust than
* the simple iterated approach of
* repeatedly unioning each polygon to a result geometry.
- * <p>
* The <tt>buffer(0)</tt> trick is sometimes faster, but can be less robust and
* can sometimes take an exceptionally long time to complete.
* This is particularly the case where there is a high degree of overlap
@@ -123,15 +124,35 @@
* Computes the union of
* a collection of {@link Polygonal} {@link Geometry}s.
- * @param polys a collection of {@link Polygonal} {@link Geometry}s
+ * @param polys a collection of {@link Polygonal} {@link Geometry}s.
+ * ownership of elements _and_ vector are left to caller.
static geom::Geometry* Union(std::vector<geom::Polygon*>* polys);
+ * Computes the union of a set of {@link Polygonal} {@link Geometry}s.
+ * @tparam T an iterator yelding something castable to const Polygon *
+ * @param start start iterator
+ * @param end end iterator
+ template <class T>
+ static geom::Geometry* Union(T start, T end)
+ std::vector<geom::Polygon*> polys;
+ for (T i=start; i!=end; ++i) {
+ const geom::Polygon* p = dynamic_cast<geom::Polygon*>(*i);
+ polys.push_back(const_cast<geom::Polygon*>(p));
+ return Union(&polys);
static geom::Geometry* Union(const geom::MultiPolygon* polys);
@@ -140,6 +161,7 @@
* the given collection of {@link Geometry}s.
* @param geoms a collection of {@link Polygonal} {@link Geometry}s
CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
: inputPolys(polys),
@@ -201,11 +223,13 @@
* Unions two polygonal geometries.
* The case of MultiPolygons is optimized to union only
- * the polygons which lie in the intersection of the two geometry's envelopes.
- * Polygons outside this region can simply be combined with the union result,
- * which is potentially much faster.
+ * the polygons which lie in the intersection of the two geometry's
+ * envelopes.
+ * Polygons outside this region can simply be combined with the union
+ * result, which is potentially much faster.
* This case is likely to occur often during cascaded union, and may also
- * occur in real world data (such as unioning data for parcels on different street blocks).
+ * occur in real world data (such as unioning data for parcels on
+ * different street blocks).
* @param g0 a polygonal geometry
* @param g1 a polygonal geometry
Modified: trunk/src/operation/union/CascadedPolygonUnion.cpp
--- trunk/src/operation/union/CascadedPolygonUnion.cpp 2011-02-10 11:09:55 UTC (rev 3191)
+++ trunk/src/operation/union/CascadedPolygonUnion.cpp 2011-02-10 13:48:34 UTC (rev 3192)
@@ -4,6 +4,7 @@
@@ -13,7 +14,7 @@
Modified: trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
--- trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2011-02-10 11:09:55 UTC (rev 3191)
+++ trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2011-02-10 13:48:34 UTC (rev 3192)
@@ -69,7 +69,7 @@
std::vector<geos::geom::Polygon*>* geoms)
using geos::operation::geounion::CascadedPolygonUnion;
- return CascadedPolygonUnion::Union(geoms);
+ return CascadedPolygonUnion::Union(geoms.begin(), geoms.end());
void test_runner(test_unaryuniontest_data& t,
More information about the geos-commits
