[geos-commits] r3204 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Feb 11 05:51:46 EST 2011
Author: strk
Date: 2011-02-11 02:51:46 -0800 (Fri, 11 Feb 2011)
New Revision: 3204
Added:
   trunk/tests/xmltester/tests/bug360.xml
XML version of test for bug #360
Added: trunk/tests/xmltester/tests/bug360.xml
--- trunk/tests/xmltester/tests/bug360.xml	                        (rev 0)
+++ trunk/tests/xmltester/tests/bug360.xml	2011-02-11 10:51:46 UTC (rev 3204)
@@ -0,0 +1,22 @@
+<run>
+  <desc>
+http://trac.osgeo.org/geos/ticket/360
+  </desc>
+  <precisionModel type="FLOATING" />
+<case>
+  <desc>
+Exception on CascadedUnion (JTS works!)
+  </desc>
+  <a>
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
 124A21B12F11D5241010300000001000000060000009C8CC751B8483A4118E57CB8FD1D52413551951AB9483A41DAABCF0F001E52417E74A8A5BA483A41C45FD389FF1D52415374A8A5BA483A41C45FD389FF1D52417E74A8A5BA483A41B95FD389FF1D52419C8CC751B8483A4118E57CB8FD1D5241</a>
+<test>
+ <op name="union" arg1="A">
+GEOMETRYCOLLECTION EMPTY
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits mailing list
