[geos-commits] r3205 - trunk/tests/xmltester/tests
svn_geos at osgeo.org
Fri Feb 11 10:59:01 EST 2011
Author: strk
Date: 2011-02-11 07:59:01 -0800 (Fri, 11 Feb 2011)
New Revision: 3205
trunk/tests/xmltester/tests/bug344.xml
Add description
Modified: trunk/tests/xmltester/tests/bug344.xml
--- trunk/tests/xmltester/tests/bug344.xml 2011-02-11 10:51:46 UTC (rev 3204)
+++ trunk/tests/xmltester/tests/bug344.xml 2011-02-11 15:59:01 UTC (rev 3205)
@@ -1,6 +1,7 @@
<run>
<desc>
http://trac.osgeo.org/geos/ticket/344
+ Buffer operation uses a huge amount of memory
</desc>
<precisionModel type="FLOATING" />
More information about the geos-commits
