[geos-commits] r3241 - in trunk: . include/geos/geom src/geom tests/unit/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Feb 23 10:45:40 EST 2011
Author: strk
Date: 2011-02-23 07:45:40 -0800 (Wed, 23 Feb 2011)
New Revision: 3241
   trunk/NEWS
   trunk/include/geos/geom/LinearRing.h
   trunk/src/geom/LinearRing.cpp
   trunk/tests/unit/geom/LinearRingTest.cpp
Sync LinearRing to JTS-1.12: empty LinearRing are closed by definition now
Modified: trunk/NEWS
--- trunk/NEWS	2011-02-23 14:37:39 UTC (rev 3240)
+++ trunk/NEWS	2011-02-23 15:45:40 UTC (rev 3241)
@@ -25,6 +25,7 @@
   - Polygonizer::getDangles returns by const ref
   - Polygonizer::getInvalidRingLines returns by const ref and retains
     ownership of vector elements
+  - Empty LinearRings are closed by definition
 - Bug fixes:
   - Invalid compound geometries reported as valid (#333)
   - Return up to 15 digits of precision from GEOSisValidReason_t (#329)
Modified: trunk/include/geos/geom/LinearRing.h
--- trunk/include/geos/geom/LinearRing.h	2011-02-23 14:37:39 UTC (rev 3240)
+++ trunk/include/geos/geom/LinearRing.h	2011-02-23 15:45:40 UTC (rev 3241)
@@ -14,7 +14,7 @@
- * Last port: geom/LinearRing.java rev. 1.32 (JTS-1.10)
+ * Last port: geom/LinearRing.java r320 (JTS-1.12)
@@ -59,6 +59,12 @@
 public:
+	 * The minimum number of vertices allowed in a valid non-empty ring (= 4).
+	 * Empty rings with 0 vertices are also valid.
+	static const unsigned int MINIMUM_VALID_SIZE = 4;
 	LinearRing(const LinearRing &lr);
@@ -102,6 +108,8 @@
 	bool isSimple() const;
+	bool isClosed() const;
 	std::string getGeometryType() const;
 	virtual GeometryTypeId getGeometryTypeId() const;
Modified: trunk/src/geom/LinearRing.cpp
--- trunk/src/geom/LinearRing.cpp	2011-02-23 14:37:39 UTC (rev 3240)
+++ trunk/src/geom/LinearRing.cpp	2011-02-23 15:45:40 UTC (rev 3241)
@@ -14,7 +14,7 @@
@@ -71,7 +71,7 @@
-	if ( points->getSize() <= 3 )
+	if ( points->getSize() < MINIMUM_VALID_SIZE )
 		std::ostringstream os;
 		os << "Invalid number of points in LinearRing found "
@@ -98,6 +98,16 @@
 	return true;
+bool
+LinearRing::isClosed() const
+	if ( points->isEmpty() ) {
+		// empty LinearRings are closed by definition
+		return true;
+	return LineString::isClosed();
 string LinearRing::getGeometryType() const {
 	return "LinearRing";
Modified: trunk/tests/unit/geom/LinearRingTest.cpp
--- trunk/tests/unit/geom/LinearRingTest.cpp	2011-02-23 14:37:39 UTC (rev 3240)
+++ trunk/tests/unit/geom/LinearRingTest.cpp	2011-02-23 15:45:40 UTC (rev 3241)
@@ -141,7 +141,7 @@
 	template<>
 	void object::test<4>()
-		ensure( ! empty_ring_.isClosed() );
+		ensure( empty_ring_.isClosed() );
 	// Test of isRing() for empty LinearRing
@@ -149,7 +149,7 @@
 	template<>
 	void object::test<5>()
-		ensure( ! empty_ring_.isRing() );
+		ensure( empty_ring_.isRing() );
 	// Test of isSimple() for empty LinearRing
More information about the geos-commits mailing list
