[geos-commits] r3242 - in trunk: include/geos/operation/buffer
src/operation/buffer
svn_geos at osgeo.org
Wed Feb 23 10:45:51 EST 2011
Author: strk
Date: 2011-02-23 07:45:51 -0800 (Wed, 23 Feb 2011)
New Revision: 3242
trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
Don't bother adding ring if it is "flat" and will disappear in the output (from TS r261)
Modified: trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h 2011-02-23 15:45:40 UTC (rev 3241)
+++ trunk/include/geos/operation/buffer/OffsetCurveSetBuilder.h 2011-02-23 15:45:51 UTC (rev 3242)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2006 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -13,7 +14,7 @@
- * Last port: operation/buffer/OffsetCurveSetBuilder.java rev. 1.11 (JTS-1.10)
+ * Last port: operation/buffer/OffsetCurveSetBuilder.java r262 (JTS-1.11)
@@ -109,7 +110,7 @@
void addPolygon(const geom::Polygon *p);
- * Add an offset curve for a ring.
+ * Add an offset curve for a polygon ring.
* The side and left and right topological location arguments
* assume that the ring is oriented CW.
* If the ring is in the opposite orientation,
Modified: trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-02-23 15:45:40 UTC (rev 3241)
+++ trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-02-23 15:45:51 UTC (rev 3242)
@@ -4,8 +4,9 @@
+ * Copyright (C) 2005 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
- * Copyright (C) 2005 Refractions Research Inc.
* the terms of the GNU Lesser General Public Licence as published
@@ -14,7 +15,7 @@
@@ -277,6 +278,12 @@
OffsetCurveSetBuilder::addPolygonRing(const CoordinateSequence *coord,
double offsetDistance, int side, int cwLeftLoc, int cwRightLoc)
+ // don't bother adding ring if it is "flat" and
+ // will disappear in the output
+ if (offsetDistance == 0.0 && coord->size() < LinearRing::MINIMUM_VALID_SIZE)
+ return;
int leftLoc=cwLeftLoc;
int rightLoc=cwRightLoc;
#if GEOS_DEBUG
More information about the geos-commits
