[geos-commits] r3246 - trunk/src/operation/buffer
svn_geos at osgeo.org
Wed Feb 23 12:13:31 EST 2011
Author: strk
Date: 2011-02-23 09:13:31 -0800 (Wed, 23 Feb 2011)
New Revision: 3246
trunk/src/operation/buffer/BufferInputLineSimplifier.cpp
trunk/src/operation/buffer/BufferInputLineSimplifier.h
JTS-1.12 sync
Modified: trunk/src/operation/buffer/BufferInputLineSimplifier.cpp
--- trunk/src/operation/buffer/BufferInputLineSimplifier.cpp 2011-02-23 16:46:10 UTC (rev 3245)
+++ trunk/src/operation/buffer/BufferInputLineSimplifier.cpp 2011-02-23 17:13:31 UTC (rev 3246)
@@ -13,7 +13,7 @@
- * Last port: operation/buffer/BufferInputLineSimplifier.java rev 1.6 (JTS-1.10)
+ * Last port: operation/buffer/BufferInputLineSimplifier.java r320 (JTS-1.12)
Modified: trunk/src/operation/buffer/BufferInputLineSimplifier.h
--- trunk/src/operation/buffer/BufferInputLineSimplifier.h 2011-02-23 16:46:10 UTC (rev 3245)
+++ trunk/src/operation/buffer/BufferInputLineSimplifier.h 2011-02-23 17:13:31 UTC (rev 3246)
@@ -13,7 +13,7 @@
@@ -54,17 +54,19 @@
* A key aspect of the simplification is that it
* affects inside (concave or inward) corners only.
* Convex (outward) corners are preserved, since they
- * are required to ensure that the eventual buffer curve
+ * are required to ensure that the generated buffer curve
* lies at the correct distance from the input geometry.
* Another important heuristic used is that the end segments
* of the input are never simplified. This ensures that
- * the client buffer code is able to generate end caps consistently.
+ * the client buffer code is able to generate end caps faithfully.
* No attempt is made to avoid self-intersections in the output.
* This is acceptable for use for generating a buffer offset curve,
- * but means that this cannot be used as a general-purpose polygon
- * simplification algorithm.
+ * since the buffer algorithm is insensitive to invalid polygonal
+ * geometry. However,
+ * this means that this algorithm
+ * cannot be used as a general-purpose polygon simplification technique.
* @author Martin Davis
More information about the geos-commits
