[geos-commits] r3247 - trunk/tests/xmltester/tests
svn_geos at osgeo.org
Fri Feb 25 05:22:49 EST 2011
Author: strk
Date: 2011-02-25 02:22:49 -0800 (Fri, 25 Feb 2011)
New Revision: 3247
Added:
trunk/tests/xmltester/tests/bug356.xml
Add test for ticket #356 (not run, as it fails)
Added: trunk/tests/xmltester/tests/bug356.xml
--- trunk/tests/xmltester/tests/bug356.xml (rev 0)
+++ trunk/tests/xmltester/tests/bug356.xml 2011-02-25 10:22:49 UTC (rev 3247)
@@ -0,0 +1,25 @@
+<run>
+ <desc>
+http://trac.osgeo.org/geos/ticket/356
+ </desc>
+ <precisionModel type="FLOATING" />
+ <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+multilinestring buffer artifacts
+ </desc>
+ <a>
+MULTILINESTRING((1676339.95971128 4847443.67952346, 1676340.19 4847443.54, 1676338.44 4847440.65, 1676335.37 4847442.52, 1676337.12 4847445.4, 1676339.95971128 4847443.67952346))
+ </a>
+<test>
+ <op name='buffer' arg1='A' arg2='1.0'>
+POLYGON ((1676334.370908338 4847442.47738721, 1676334.381771572 4847442.672985536, 1676334.430559768 4847442.86271278, 1676334.515400594 4847443.039287834, 1676336.265400594 4847445.919287834, 1676336.383019845 4847446.075914382, 1676336.528914198 4847446.206608688, 1676336.697486246 4847446.306356514, 1676336.882268526 4847446.371330916, 1676337.07617165 4847446.399039078, 1676337.2717563 4847446.388417942, 1676337.461518643 4847446.339875002, 1676337.638178226 4847446.255272662, 1676340.477889498 4847444.534796128, 1676340.477889507 4847444.534796122, 1676340.708178227 4847444.395272662, 1676340.865054944 4847444.277767458, 1676340.995997551 4847444.13191887, 1676341.095975523 4847443.963330074, 1676341.16114793 4847443.778477878, 1676341.189010992 4847443.584463894, 1676341.178494273 4847443.388741704, 1676341.130001801 4847443.19883052, 1676341.04539655 4847443.022026312, 1676339.29539655 4847440.132026312, 1676339.177687757 4847439.974857962, 1676339.031535752 4847439.8
43721232, 1676338.862575756 4847439.743672394, 1676338.6773224 4847439.678569058, 1676338.482918545 4847439.650921426, 1676338.286859869 4847439.661795518, 1676338.096705855 4847439.710772058, 1676337.91978832 4847439.795962644, 1676334.84978832 4847441.665962642, 1676334.693269131 4847441.783769514, 1676334.56272065 4847441.92983049, 1676334.463152898 4847442.098540236, 1676334.398386959 4847442.283424222, 1676334.370908338 4847442.47738721),
+(1676338.816753609 4847443.202781668, 1676337.455985112 4847444.027221212, 1676336.743325995 4847442.854387922, 1676338.10393518 4847442.025612946, 1676338.816753609 4847443.202781668))
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits
